Old 05-09-2013, 10:37 PM   #301
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Originally Posted by Bomp View Post
I turned away for a moment and you guys stabbed that sucker in there. Great Job.
I was stoked to get it installed, now I have other issues to deal with, I wish someone would have told me in advance that the intermediate crossmember wasn't going to work with an automatic so don't even bother trying because it would have saved me a headache.
With that in mind here's the official warning; Remove the intermediate crossmember if you are installing an automatic transmission.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-11-2013, 07:38 PM   #302
gdavis
gdavis's Avatar
Brian if you remember I had to cut mine out for the transmission pan. But I guess you didn't see that post. I know what you are going or went thru on cutting the ribbits out on that cross member. Did you jack up the front of the cab 4 to 6 inches to cut the ribbits. That is what I did as you know from our phone conversation the other day. I hope it worked for you.
gdavis is offline   Reply With Quote
Old 05-11-2013, 11:54 PM   #303
Xeen
Xeen's Avatar
The problem is I would like to have known about the issue from the jump when I had it down to the bare frame.
This is my first ever C10 build though and I had it torn down to the frame within a couple weeks of buying it and I just didn't know enough about the pickup yet.
It's one of those deals where I wish I knew then what I know now.
Old 05-12-2013, 10:27 AM   #304
Vic1947
Vic1947's Avatar
I guess that's why they call it the school of hard knocks.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 05-13-2013, 08:24 PM   #305
gdavis
gdavis's Avatar
The school of no knocks I like better. But that is not possible.
Old 05-14-2013, 03:18 AM   #306
Xeen
Xeen's Avatar
Hey all;
I removed the Intermediate crossmember yesterday, so now I can get on with the build.
Things on the punch list for this week:
Rebleed brakes.
Install Shift linkage.
Install Fuel Lines and filter.
Install standalone engine/transmission harness.
Hopefully I can get it all done.
Old 05-14-2013, 08:25 AM   #307
Low Elco
We got faith in ya. Git after it!
Low Elco is offline   Reply With Quote
Old 05-14-2013, 05:17 PM   #308
Xeen
Xeen's Avatar
Hey all;
I installed my cruise control and steering wheel today.
It wasn't on my punch list but I needed to be able to steer.
Old 05-14-2013, 08:07 PM   #309
gdavis
gdavis's Avatar
I like the wheel. If you are going to take it off I will give you 50.00 for it. Ha Ha
Old 05-14-2013, 11:10 PM   #310
502ms
502ms's Avatar
Very nice, Brian!
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 05-15-2013, 07:42 AM   #311
Low Elco
Looks good! Tip: wrap it in a trash/ grocery bag and tape it up. Ours got all kinna nasty. Keep it up!
Old 05-15-2013, 09:50 AM   #312
67c10rustbuket
67c10rustbuket's Avatar
Now thats a fresh looking motor! I really like that steering wheel, I was unsure until I saw it mounted. Hey did you know you have to remove that manual trans x member? I tried that too before removing it. DOH! Keep it up its looking real good
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-15-2013, 04:08 PM   #313
Xeen
Xeen's Avatar
Hey all;
It's hotter than the Devils backyard outside.
All I did today is swap some rallys and check one of the tires for punctures.
I switched the tire that was on the 6" rim to the 7" rim and the tire that was on the 7" rim to the 8" rim.
It turns out there was nothing wrong with the tire, the 6" rim just had so much corrosion inside the lip it was leaking out of the sidewall.
Old 05-15-2013, 07:43 PM   #314
gdavis
gdavis's Avatar
I am glad you got it figured out. Now come down here and do mine. it leaks also. the same tire
Old 05-16-2013, 01:42 PM   #315
Xeen
Xeen's Avatar
Hey all;
I thought I could buy a 37 degree flaring tool locally, boy was I wrong.
I ordered one off of ebay it probably won't be here untill next week, so there goes my plans to do my fuel lines this week.
Old 05-16-2013, 04:06 PM   #316
Xeen
Xeen's Avatar
Hey all;
The business I bought my cold air intake kit from called and they are replacing the scratched aluminum pipe and sending the missing MAF adapter also.
I installed my Lokar shift linkage today.
Old 05-16-2013, 04:39 PM   #317
~Whitey~
~Whitey~'s Avatar
Looking good. Love that steering wheel.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 05-16-2013, 05:18 PM   #318
Xeen
Xeen's Avatar
Hey all;
This one is for all you guys who have 71-72 tilt automatic columns.
After restoring one of these alot of guys find out that the pin used to hold the shift arm in place wont go back in tight well I came up with a great solution for this problem.
You will need to buy the following;
1x 8-32x3/4" stainless allen bolt.
1x 8-32 internal threaded sleeve with end stop.
Then drill out the bottom ear to fit the sleeve with a 9/32 bit and then countersink the shift arm approximately 1/8th of an inch with the same bit.
Old 05-16-2013, 06:32 PM   #319
oldman3
oldman3's Avatar
Very nice on the shift lever repair...Jim
oldman3 is offline   Reply With Quote
Old 05-18-2013, 08:17 PM   #320
gdavis
gdavis's Avatar
You are doing a bang up job I'am watching. Go to my page and see the wing windows I pick up in the mail today.
Old 05-21-2013, 06:16 PM   #321
Xeen
Xeen's Avatar
Hey all;
Today I got the holes drilled in the frame for the canister style filter and installed it.
I also installed the return side of the fuel line and after looking at how much line it used I may have to buy some more.
Here are some pictures of the fuel system so far.
Old 05-21-2013, 08:13 PM   #322
gdavis
gdavis's Avatar
It's like the cat said when he got his tail cut caught in the door. It want be long now. You really looking good. You said you will be driving in a week. Well you just might make that dead line.
Old 05-21-2013, 08:39 PM   #323
Xeen
Xeen's Avatar
LOL I said I could be driving it in a week if I worked really hard, which I have no intention of doing, so it will most likely be weeks from now.
Old 05-21-2013, 09:17 PM   #324
gdavis
gdavis's Avatar
Thanks for all the help tonight.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
Old 05-21-2013, 09:19 PM   #325
Xeen
Xeen's Avatar
Any time.
1968, chevrolet, restomod, stepside, swb
