Old 03-07-2015, 06:46 PM   #301
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
It's been a long five weeks of vehicle repairs and crappy weather, but we got back to the '65 today. We spent some time picking through our doors to decide which two we'll use. We were able to settle on this one for the drivers side, but I'm not sure what we're doing for the passenger side door yet. I started welding up cracks and bumping out dents while Dad sandblasted and rebushed the hinges we'll use for both doors.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-07-2015, 11:52 PM   #302
Ta2Don
Ta2Don's Avatar
Glad to see you back in action...
Our weather forecast shows Old Man Winter taking his vacation finally… ready to get back after mine...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-08-2015, 02:55 PM   #303
racecougar
racecougar's Avatar
Very glad here, too. We're soooo ready for winter to be over.
Today was another good day at the shop. While the inside front lower corner of this door wasn't rusted through, it was pretty beat. A piece of a York air conditioner will make a good patch panel. Cutting out the old sheetmetal exposes the mud collected between the inner structure and the sheetmetal. This corner wasn't far from rusting through. After cleaning up everything I could reach and shooting a little zinc primer, I welded it up. Using a flux-core MIG on super-thin parent metal isn't much fun, but it is doable with a little patience.
Dad and I slapped on a pair of rebuilt hinges and installed and aligned the door to the cab.
It's actually starting to look like a truck again.
Old 03-12-2015, 08:27 PM   #304
racecougar
racecougar's Avatar
Dad took the trailing arms, rear coils, and rear shock mounts to the blaster yesterday. I stopped by the shop after work today and we primed it all.
Old 03-12-2015, 10:03 PM   #305
Ta2Don
Ta2Don's Avatar
DON
Proverbs 27:17
Old 03-14-2015, 03:12 PM   #306
racecougar
racecougar's Avatar
Today we installed the rear axle, bumped a couple of dents out of the driverside door, and started looking at our steering column/box options. The rear axle, trailing arms, springs, etc. will come back out later once we've determined parking brake cable bracket placement, desired axle width, panhard bar mounting, shock relocation, etc. It's all just installed for mock up currently.
Old 03-15-2015, 07:29 PM   #307
racecougar
racecougar's Avatar
Another dusty day in the shop. We got the driverside door, door jam, rocker, and cab corner stripped down to bare steel.
While DA'ing the door we noticed a couple of pinholes in the front lower corner. Cutting away the outer skin revealed the dirt and rust we expected to find lurking there. Dad whipped up a new corner out of another piece of that York air conditioner, and I buzzed it into place.
Old 03-22-2015, 04:41 PM   #308
racecougar
racecougar's Avatar
We finished up the body work on the inside of the drivers door and door jamb yesterday, then shot both with primer today.
Old 03-22-2015, 09:36 PM   #309
SayBye
SayBye's Avatar
Nice work!
SayBye is offline   Reply With Quote
Old 03-23-2015, 08:15 PM   #310
racecougar
racecougar's Avatar
Thanks! I stopped by the shop after work today to reinstall the door so Dad can do the final body work on the exterior of the door and the cab corner.
Old 04-05-2015, 03:57 PM   #311
racecougar
racecougar's Avatar
I drilled the trim holes in the door today while Dad worked with filler on the cab corner.
Old 04-05-2015, 07:48 PM   #312
Ta2Don
Ta2Don's Avatar
Closer and Closer!
DON
Proverbs 27:17
Old 04-07-2015, 05:16 PM   #313
racecougar
racecougar's Avatar
After an exciting drive home in the Mustang from the alignment shop this morning (insane downpour plus a little hail for good measure), I went over to the shop to work on the '65. I tackled the power steering box install using Captainfab's special spacer/adapter plate, while Dad spread some filler on the door. Hopefully we'll get time to shoot some primer this coming weekend.
Old 04-11-2015, 07:31 PM   #314
racecougar
racecougar's Avatar
Spent the day getting dusty. It's ready for primer. I may get over there and shoot it tomorrow after I hit up a swap meet in the morning.
Old 04-12-2015, 05:00 PM   #315
racecougar
racecougar's Avatar
Scored a few items at the swap meet this morning, but didn't find the rust free passenger door I'm looking for. I went over to the shop afterward for a little prime time.
Old 04-14-2015, 08:43 PM   #316
racecougar
racecougar's Avatar
Swung by the shop after work, blocked it all out, and threw another coat on. It's getting there.
Old 04-14-2015, 10:30 PM   #317
Ta2Don
Ta2Don's Avatar
Lookin' good!!! Closer and closer...
DON
Proverbs 27:17
Old 04-18-2015, 05:09 PM   #318
racecougar
racecougar's Avatar
Thanks! Blocked it all out and shot another coat today.
Old 04-19-2015, 04:54 PM   #319
racecougar
racecougar's Avatar
I pulled a muscle or pinched a nerve in my neck yesterday, so I couldn't accomplish much today, but we did locate and begin to prep a few interior parts for paint.
Old 04-25-2015, 02:23 PM   #320
racecougar
racecougar's Avatar
It might not look like much has changed, but I just need to finish up the one door panel and bump a few dings out of it, sand the other panel, then clean and hang everything for primer. I had to knock off early today to go to my friend's wedding, but I hope to shoot some primer tomorrow.
Old 04-26-2015, 04:12 PM   #321
racecougar
racecougar's Avatar
Primed all those little interior panels today.
Old 04-28-2015, 09:39 PM   #322
racecougar
racecougar's Avatar
Painted those pieces tonight, though I forgot my camera at home and had to make do with my less-than-up-to-date camera phone.
Old 05-02-2015, 06:14 PM   #323
racecougar
racecougar's Avatar
We weren't happy with the color/texture match with these parts to the dash, so I sanded them down and re-shot them today. Managed to get it right this time.
Dad wet-sanded the driverside door jam today as well. I'm hoping to spray a coat of satin black on the jam and interior side of the door tomorrow after we hit up a swap meet in the morning. Fingers crossed that we find a workable passenger side door tomorrow.
Old 05-03-2015, 04:53 PM   #324
racecougar
racecougar's Avatar
Woke up at 4AM and saw the sun rise at Gateway Motorsports Park with Dad while searching for parts at the swap meet. We unfortunately came home empty handed, but the day wasn't a loss, as we were able to get the first coat of satin black on the interior side of the drivers door and door jam. One more coat, then the door can go back on for the last time.
Old 05-04-2015, 07:55 PM   #325
racecougar
racecougar's Avatar
Darker than a black steer's tookus on a moonless prairie night.
