Old 06-20-2016, 08:21 PM   #301
aotte1
Re: 64' K10 Project Long Bed
John,
Thanks for the information on the Dana 44 in your K10 too.
Kimble,
Not sure if the calipers are different for the 1" and HD 1 1/4" rotors, if their is a difference the piston bore may be bigger. Will find out more tomorrow, going to parts stores and will look at the calipers. Will have my originals back too.
Also, putting all new seals in the T221, along with resealing the cover plates too. Most are leaking a little.
Thanks,
Les
aotte1 is offline   Reply With Quote
Old 06-21-2016, 12:23 PM   #302
61K10
61K10's Avatar
Les--be careful with the ones with shims. and use thin gasket mat like the org ones. I also after it was back together i put a bead of sealer around each cover plate. these are tough to keep from weeping.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-21-2016, 10:12 PM   #303
aotte1
Kimble,
Thanks for the heads-up on resealing the T221. The shaft seals are "CR" 17386 and shifter " National" 480954. They came from shop in MN, that does a lot of 4x4 work. He also warned me about the shims, go slow, "no impacts- breaks the cover", hand wrench only.
Going to try double seals on the shafts per suggestion.
DD thanks for the information on how much your front end settled once built!
Les
Old 06-21-2016, 10:22 PM   #304
aotte1
Got the front calipers to work, just needed to trim a little nub at the top and bottom with cut off wheel. Now on to brake hoses, looking hard at P vans.
Kimble do you like a 90 degree or 45 line on the banjo connection, does the 90 make for a shorter hose connection?
Les
Old 06-21-2016, 10:26 PM   #305
aotte1
Right side caliper.
Old 06-29-2016, 09:44 PM   #306
aotte1
Rockwell T221
The Rockwell T 221 seals and gaskets have been replaced/ resealed. Used Permatex Gasket Maker. It works really well. Put a little bit on surfaces where the seals go, to prevent any leakage around the outside of the seals, which happens sometimes. Did install the double seals on the output/input shafts. All the seals were original from 1964. The small shifter seals were almost gone, just touch them and they came apart. The inside looked and felt good, should run a lot more. Did not clean the inside with solvent, concerned bearing could be compromised. Did drain for a day, and flushed with one quart of fresh grease. Photos of the original shaft seal below, it is a one piece double seal.
Also installing Spicer magnetic fill and drain plugs, part number 064254, they are 3/4 pipe thread .
Old 06-29-2016, 09:53 PM   #307
aotte1
Another photo of drain plug. Also grease I am using, it is a little heavier, should be ok as not driving in cold weather. Using it as it is for bigger heavy duty trucks and has more additives for wear/pressure.
Old 06-29-2016, 10:30 PM   #308
_mg
Active Member
_mg's Avatar
Interesting you are using the heavier lube, is that a usual practice for this transfer case?
_mg is offline   Reply With Quote
Old 07-03-2016, 03:23 PM   #309
aotte1
MG,
Probably overkill, however, not a lot more expensive. Since not using in cold weather, the extra wear protection additives may help.
Les
Old 08-30-2016, 10:38 PM   #310
Captainfab
60-66 Nut
It's been almost 2 months since your last post here. Do you have anything new to post Les?
Old 09-01-2016, 02:58 PM   #311
mattbert56
mattbert56's Avatar
Nice build. Been peeking at it here and there. Fun times with the t221. Hah mine was plenty a pain also.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 09-06-2016, 09:23 PM   #312
aotte1
Mattbert56,
Your T221 looks nice too. Mine was a little worn in a few place, but overall good and bearings were all tight.
Selling our house and moving to a smaller one, hope to get back working on it later this week.
Les
Old 09-06-2016, 09:53 PM   #313
aotte1
John,
As mentioned about, selling our home and have been thinning stuff out, a lot. Also, was under the weather for a little bit.
Back at it now, cleaning up a bunch of bolts and brake/fuel line fasteners right now. Almost done with welding on bell housing for the NV4500 too. Hope to get the trans in before moving to new, much smaller garage!!
Brakes and brake lines next. Ordered a set of new brake line, not correct for "K" trucks, going to send originals for them to copy.
The engine is making some slow progress too.
Plan to get back posting soon, after we close on selling our home.
Thanks for asking,
Les
Old 09-07-2016, 12:34 AM   #314
Captainfab
60-66 Nut
Glad to hear all is well Les. I am looking at having to move to a different home so that I can keep my projects and parts stash. New regulations at my shop prohibit any outside storage. I'm not looking forward to the move.
Old 09-07-2016, 12:02 PM   #315
61K10
61K10's Avatar
les--looking forward to the rest of your build. Moving isn't fun as you probably know lol. smaller garage, good or bad. just add a shed outside. I worked out of a 2 car garage for 23yrs and tried to keep the wife's car in it most of the time.
take care----------------kimble
1961 chevy K10
Old 09-08-2016, 01:46 AM   #316
aotte1
Kimble,
Have not figured out the garage space, yet. Definitely vehicles will have to stay outside for a while. And will likely insulate the garage walls and doors too, along with adding 220 volt power outlets. The good news is that their is a large basement with garage access through double doors only half a level down. So basement has all the hand tools, tool box, parts storage, some machines, and work bench. Welder will likely be in garage, air compressor and media cabinet not sure - leaning garage for noise,
Also, using current garage to the last day we own.
John,
Sorry for your move too, sounds like very stringent ordnance, you are facing not grandfathering you or not allowing fence to meet their new objective. Hopefully the move will have some benefits for you.
Thanks for support in making the move to smaller home,
Les
Old 10-09-2016, 08:57 PM   #317
aotte1
Some progress lately, a little time on the truck now and then. Still working on getting settled in our new to us home,and it will take a while. Mainly working on small parts cleaning and coating. First remove the crud and rust, then surface prepare them for ceramic coating, in media cabinet using Aluminum oxide 120 grit. Immediately after surface prep, apply the ceramic coating in dry air.
Use an aluminum sheet to hold the bolts, drill and tap it to fit the different bolt sizes.
Les
Old 10-09-2016, 09:06 PM   #318
aotte1
Cab Mount Bushing
Photos of the cab mounting bushings. Their are some additional large washer not shown below.
Old 10-09-2016, 09:19 PM   #319
aotte1
Additional coating photos. Getting ready to sort parts into groups. The rear spring shackles show an "M" on the top.
Old 10-09-2016, 09:34 PM   #320
aotte1
Cab Clutch and Brake Pedal Springs
The springs look like they were painted a green color before cleaning. After cleaning the color looks gray, the cleaner/rust remover solution may have changed the color. Not sure which color they were, kind of leaning toward the green. Photos below show before cleaning and after. The before photos do not show the green color very well, it is more visible looking at the springs.
Les
Old 10-09-2016, 09:36 PM   #321
DPowers
DPowers's Avatar
Love the attention to detail and the documentation.
DPowers is offline   Reply With Quote
Old 10-09-2016, 09:48 PM   #322
aotte1
Hood Hinge Bolts
The hood hinge bolts have a different washer (GM has a name for them) and are correct for 65', 64'....?, 66' uses a flat washer. These have a head marking of "ELH" with circles around the ELH. The lencth of threads is 3/4". Have seen others with an anchor figure.
The group is 8.016, part number 3846202 ,sup by 3744646, and listed as hex hd 5/16-18 x 7/8 and another reference listed as 3/8-16 x 3/4 with 8.391 lock washer for the other mounting.
Note: Certain Chevrolet parts catalogs have a bolt section appendix, that lists their GM name, size description,, w or wo washer, illustration, and part number. I will list a reference later. ( sure wish we had a longer time edit posts).
Les
Old 10-09-2016, 10:50 PM   #323
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Can't believe how much I have missed out on! So many awesome builds I can't keep up with them all. haha Had to re-read the whole thread.
Looks good Les!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-10-2016, 01:03 PM   #324
61K10
61K10's Avatar
Les--Glad you are getting settled in you new house. keep plugging along.
kimble
1961 chevy K10
Old 10-10-2016, 10:33 PM   #325
aotte1
TJ,
Thanks for the compliment, your build is great too.
Kimble,
Making indirect progress for the most part currently. Starting to build a 8x16' storage shed, to move a bunch of stuff out of the garage.
Did have some fun saturday, picked up a sport bumper with rock guards, mounting brackets, license plate bracket and light. Nice condition and straight bumper. Also got custom bed molding, and fleetside braces. It will likely be for a fleet side short bed in the future.
Les
