Old 01-28-2017, 05:46 PM   #301
Aus69c20
Aus69c20's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Looks as though you need a c10. That would have fit the boxes easier.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 01-30-2017, 12:20 AM   #302
6t9camaro
6t9camaro's Avatar
Originally Posted by Couch View Post
which mounts are these, 73+, are the small block and big block towers/perches the same?
I Pulled the lower half of the mount ( part that bolts to the frame ) off a 75 chevy 1/2 ton that had a small block. It bolted right up to my 67 frame, and I used the rubber and the clamshell mount off a 1975 3/4 ton big block truck. It all fit together pretty good so far!
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 01-30-2017, 12:20 AM   #303
6t9camaro
6t9camaro's Avatar
LOL Yup!
Build
67 Green Gobblin
Old 01-30-2017, 12:27 AM   #304
6t9camaro
6t9camaro's Avatar
Heres a few pics of the goodies I just pulled out of the boxes! A bunch of stuff from LMC, Summit, CPP, MCB.
Build
67 Green Gobblin
Old 01-30-2017, 12:33 AM   #305
6t9camaro
6t9camaro's Avatar
Just a few more things from summit! Flowmaster 40's with a nice x-pipe kit with some misc stuff. This should keep me busy for a bit. I don't actually know where I'm going to put the x-pipe since i have no room under the cab? I might have to try and fit it under the box somewhere???
Build
67 Green Gobblin
Old 01-30-2017, 11:06 AM   #306
Couch
Daily Driver
Couch's Avatar
thats what i was thinking. which works well because i have some parts trucks that i can pull from to get just what i need. thank you and keep up the good work man, this build seems to be going together nicely!
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 01-31-2017, 11:06 PM   #307
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
nice work
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 02-03-2017, 06:50 AM   #308
Elliot949
Elliot949's Avatar
On Board... Your Craftsmanship is awesome...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 02-03-2017, 02:13 PM   #309
6t9camaro
6t9camaro's Avatar
Originally Posted by hotrodchevy1999 View Post
nice work
Thanks guys! She's getting there!
Build
67 Green Gobblin
Old 02-23-2017, 11:14 PM   #310
6t9camaro
6t9camaro's Avatar
Time for another update! I had to get a few things painted before I could continue with assembly. I had to buy a new rear sport bumper as i just couldn't find a nice matching piece. So i did some interesting paint work to try and get it to mach the front bumper and the rest of the truck. Check it out it didn't turn out to bad and i will tweak the "patina" a little one its on the truck.
Build
67 Green Gobblin
Old 02-23-2017, 11:17 PM   #311
6t9camaro
6t9camaro's Avatar
More
Build
67 Green Gobblin
Old 02-23-2017, 11:21 PM   #312
6t9camaro
6t9camaro's Avatar
Bumper matched a little better once I put a coat of matt clear over it. Heres a few pics of painting the Rad cradle and Fender liners Flat black as well.
Build
67 Green Gobblin
Old 02-23-2017, 11:35 PM   #313
Jason7121
Jason7121's Avatar
Bumper looks awesome
Jason7121 is offline   Reply With Quote
Old 02-23-2017, 11:35 PM   #314
6t9camaro
6t9camaro's Avatar
Now that all that was done I needed to get the cab back on the frame to get some of my space back. I pulled the diff and trailing arms out so I could drop the frame onto the ground as the Hoist is being used and had to do it the hard way! Sorry for the bad pics but my boy was happy to see it go together AGAIN! lol
Excuse the old rad as thats just in there so i could run it up to temp and pressure test everything.
Build
67 Green Gobblin
Old 02-24-2017, 09:21 AM   #315
Bennett68C10
Bennett68C10's Avatar
Really nice job on the bumper, I like how you did the patina on the bolt heads too.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-24-2017, 11:42 AM   #316
6t9camaro
6t9camaro's Avatar
Yup couldn't have some shiny bolts there!
Lol
Build
67 Green Gobblin
Old 02-24-2017, 12:43 PM   #317
67seaten
67seaten's Avatar
that rear and front bumper look great
mike
67seaten is offline   Reply With Quote
Old 02-25-2017, 12:23 AM   #318
BlueBullet
BlueBullet's Avatar
Looks good. You could hit the front bumper with barkeeper's friend and it will clean up quite a bit of the surface rust. Did that on the white of my wife's truck and was surprising how it cleaned up but still looks worn.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 03-04-2017, 06:05 PM   #319
6t9camaro
6t9camaro's Avatar
Since the cabs back on I've been able to tackle a lot of little things like hook up the cpp shifter linkage and steering joints. I put the rebuilt heater box/core back in and finished that up. Pulled off the carb and gave it a rebuild and installed the new Msd wires and installed the fuse panel and ran some of the wiring.
Build
67 Green Gobblin
Old 03-04-2017, 06:13 PM   #320
6t9camaro
6t9camaro's Avatar
Next up we (my boy and I ) decided to tackle the heavy duty 4 core radiator and fan shroud from LMC. It didn't fit to bad after a little trimming of the lower cradle supports to drop the rad lower. Here's a few mock up pics.
Build
67 Green Gobblin
Old 03-04-2017, 06:18 PM   #321
6t9camaro
6t9camaro's Avatar
Pulled it all back out for trimming and final assemble and to install the fan.
Build
67 Green Gobblin
Old 03-04-2017, 06:20 PM   #322
6t9camaro
6t9camaro's Avatar
Just a Few More installed. Ignore the trans lines as it's going to get a separate cooler later on!
Build
67 Green Gobblin
Old 03-04-2017, 06:56 PM   #323
GR8-68
GR8-68's Avatar
Looks great !! 😆 Coming toge5her nicely, love the rear bumper
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 03-04-2017, 07:33 PM   #324
6t9camaro
6t9camaro's Avatar
Thanks!
Build
67 Green Gobblin
Old 03-04-2017, 09:02 PM   #325
jhama78
jhama78's Avatar
Nice build, looking forward to more updates.
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
