03-22-2016, 05:53 PM | #3226 | |
Re: Restoring Rusty
For example: http://zddplus.com/ |
03-22-2016, 06:14 PM | #3227 |
I know the pieces fit
Re: Restoring Rusty
Doesn't Comp Cams still sell their break-in oil? I can't imagine they wouldn't. Break it in with that and be done with it, run something like Valvoline VR1 or anything w/some zddp in it after that. One episode of pretrol primates they blew up a new motor trying to break it in with cheap motor oil and a bottle of zddp additive. They used a good break in oil after getting it rebuilt again. Use something decent made for break-in and fuggetaboutit.
03-22-2016, 07:59 PM | #3228 |
Re: Restoring Rusty
Greg, Get some of this:
http://www.summitracing.com/parts/crn-99002-1/overview/ Coat all the lobes with it, rub it in good, Also the bottoms of the lifters before installation. Has served me well for years. Valvoline VR-1 conventional oil in the silver bottle or Brad Penn breakin oil is what I use for flat tappets. |
03-22-2016, 09:03 PM | #3229 | |
Moderator
Re: Restoring Rusty
The bearings in a diesel engine are made from the same steel copper and babbit as the gasoline engines. Detergent in the oil keeps crud in suspension and can knock loose filth in a sludged up motor. Diesel oils have more detergents to keep the carbon suspended so it doesn't sludge up your motor to begin with. The origination of this rumor is probably that you can get into real trouble on old poorly maintained motors that were run on non detergent or poor detergent oils by changing to high detergent diesel oils... Detergents and dispersants tend to knock a lot of the sludge loose in a hurry and plug stuff up. Diesel oils tend to have more generous quantities of anti-wear additives like Boron, Zinc & Phosphorous (Zinc Dialkyl Dithio Phospahte), and Molybdenum than Spark ignition only oils. With the tightened emissions requirements put in place around 2007 they don't have the phosphorous or zinc levels they used to. If you're installing a new cam I'd run a break in oil like Joe Gibbs till it's fully broken in and then run the Rotella T5. I run 5W40 Rotella T6 in my LS4 Impala, 2 6.5L diesels, and my Polaris Sportsman 500HO ATV. The 6.2L CUCV and the LDT 465 Continental in the M35A2 get 15W40 Rotella T5. Look at the API seal on the back of the jug. Rotella T5 is at least SM and CJ-4 rated. S is Spark ignition C is Compression (diesel) ignition.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-22-2016, 09:31 PM | #3230 |
Post Whore
Re: Restoring Rusty
well gentlemen when the Greg gets in the zone he gets in the zone, I'm sure you've been there where you just put you head down and git 'er done, well today was such a day, a good day, so lets get to the updates
came home from work and turned up the paint booth to 61*F plus and dropped the humidity to the low 40% and busted out my paint guns check it out this dude's shooting primer on his tin first, he's Legit! painted the timing cover |
03-22-2016, 09:33 PM | #3231 |
Post Whore
Re: Restoring Rusty
painted the valve covers
03-22-2016, 09:35 PM | #3232 |
Post Whore
Re: Restoring Rusty
even the oil pan joined the party, for a light dusting of a touch up
03-22-2016, 09:41 PM | #3233 |
Post Whore
Re: Restoring Rusty
a while back the Alan Grove knock off mid mount alternator bracket showed up so it got a coat of sexy Semi Flat black paint too
the bracket is painted black in the last pic, whether the sun wants us to see it that way or not, lol |
03-22-2016, 09:45 PM | #3234 |
Post Whore
Re: Restoring Rusty
than the fraternal twins showed up and they wanted to get in on the action, apparently they were not too happy with their white "silver" coating, and I don't blame them - so they opted for the Cast Iron sheen but of a higher temperment than the engine Enamel
these are the as before shots |
03-22-2016, 09:50 PM | #3235 |
Post Whore
Re: Restoring Rusty
and after the upteenth coat they turned out great, I absolutely love this color now
used the same VHT brand as before except a darker color - do you like? |
03-22-2016, 09:59 PM | #3236 |
Post Whore
Re: Restoring Rusty
and don't forget this little feller
03-22-2016, 11:19 PM | #3237 |
Re: Restoring Rusty
http://www.drivenracingoil.com/#prettyPhoto/0/
This man knows what he is talking about. It might sound like just an ad to sell oil but I have met him and read a lot from other people, he knows what he is talking about. Diesel motor oils have had a lot of the ZDDP's removed from their oils. It used to be a common thing to used Delo or Rotella but not anymore. Also the ZDDP's work at a different operating temp. A diesel motor has higher internal engine temps compared to a gas motor. Straight 30 weight is a thing of old. Either use a break-in oil or use a 10-30 with the additive. If you are going to use synthetic then wait about 5,000 miles before making the change. I have a camshaft at work from a brand new motor. 5 lobes went flat instantly because the mechanic decided he did not need to put in the additive that we gave him. There are so many opinions on this and its an on going debate. Again watch the video its explains a lot. |
03-23-2016, 12:43 AM | #3238 |
Re: Restoring Rusty
I have a lumpy flat-tappet cam with some fairly stiff valve springs.
I used Comp Cams break-in oil for the first 20 minutes to break in the cam. Then drained the oil (don't look at it, trust me). I then used Comp Cams break-in-oil to go break in the rings for about 100kms. Then drained the oil. I currently use Lucas Hot Rod oil with every oil change.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
03-23-2016, 12:50 AM | #3239 |
Re: Restoring Rusty
That's funny!
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
03-23-2016, 12:55 AM | #3240 |
Re: Restoring Rusty
Oh, I also bought a 7/8" ball hone to make sure the lifter bores would allow the new lifters to rotate. No lobes lost yet (over two years of daily driving).
03-23-2016, 02:13 AM | #3241 |
Post Whore
Re: Restoring Rusty
this was the least favorite part of the evening, wire wheelin the pourus intake manifold, but we got her shinin' and cleared it for good measure, maybe the shine will hold
03-23-2016, 02:16 AM | #3242 |
Post Whore
Re: Restoring Rusty
then it was time for the Main Event
here's how to paint an engine block the hard way, LOL I swear I spent more time masking this thing than actually shootin it, when its all masked you realize there aint that much to paint after all used high temp primer on this bad boy first, then the paint went on that last pic of the can of primer refuses to get posted vertically, sorry fellas Last edited by Gregski; 03-23-2016 at 02:24 AM. |
03-23-2016, 02:23 AM | #3243 |
Post Whore
Re: Restoring Rusty
so first the primer, this is the primer for things like the headers, the guy at O'Reillys ordered the wrong one from another store for me, the one I wanted is for painting engines, but oh well this one withstands more heat, if it was the other way around I would not have used the engine primer on the headers, confused yet, good
03-23-2016, 02:26 AM | #3244 |
Post Whore
Re: Restoring Rusty
and the first coat of paint goes on the engine block
03-23-2016, 02:29 AM | #3245 |
Post Whore
Re: Restoring Rusty
and here it is the finished product, after two light coats and one medium coat as per the instructions
it has been a long time coming fellas, but I love how it turned out, I know it looks like bare metal, but I like that look, no orange, or blue engines for The Greg that's for sure |
03-23-2016, 02:48 AM | #3246 |
Post Whore
Re: Restoring Rusty
well while we are still beating the break-in oil horse to death, I wanted to share that Summit still sells what I was hoping to find at the local parts houses, an old school 30 weight break-in motor oil, now I aint gonna order my oil, I am just gonna git some cheap 10W-30 and dump some Zinc additive to it, and call it good, it aint needed for more than about a 100 miles anyway
03-23-2016, 08:01 AM | #3247 |
Re: Restoring Rusty
100 miles?! The break oil is only required for the first 25 minute run @ 2,000rpm. Once you have done that you drop the oil and replace it with fresh oil.
Once you have fresh oil then you drive the truck like you stole it for 500 miles then drop the oil again and put fresh oil in and then stick to regular intervals. You need to change the oil immediately after the break in to remove all the small pieces of metal that may come off from all the new parts or you can risk damage internally. |
03-23-2016, 08:41 AM | #3248 | |
Re: Restoring Rusty
Keep going Greg the end is in sight!
"Orange Crush" |
03-23-2016, 11:28 AM | #3249 |
Re: Restoring Rusty
This is why I said "don't look at it." The sparkling metalflake glimmer in the oil will make you think you just ruined your motor. Don't look at it. If the NEXT oil change looks like that, you have problems. But the first one - don't look.
03-23-2016, 05:59 PM | #3250 |
Re: Restoring Rusty
I'm curious since he didn't replace the bearings will he have as much metal flake in his oil from just the cam swap. I have no idea I'm just curious. Whenever we broke in a new cam we used cheap oil with GM additive(straight six for racing) and run it at 2500rpm for twenty minutes or so. Changed the oil. Went to VR oil and Lucas oil additive and never seemed to have a problem. Though this was on a racing engine.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
