08-07-2011, 01:58 PM | #3301 |
Re: How about some pics of 73-91 crew cabs
i love the interiors on those choo choo customs
08-07-2011, 02:12 PM | #3302 | |
Conversion Truck Addicted
yeah i love the seats in mine and when i stripped mine i found it was very good craftman ship, its incredible work they put into them, eventhough its mass produced, thats what i love about these conversion trucks its mass produced but it quality better than what todays custom shops and resto shps can put out
Thomas Quote:
08-07-2011, 02:17 PM | #3303 |
C35 Crew Dually
this choo choo is awsoe love the over head console.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
08-07-2011, 02:27 PM | #3304 | |
mine had the same consol but sadly i coundt save it. they wernt ment to be removed lol
Thomas Quote:
08-07-2011, 02:48 PM | #3305 |
C35 Crew Dually
hard to re create?
08-07-2011, 03:25 PM | #3306 | |
not really but it would been better to reuse the old one
Thomas Quote:
08-08-2011, 09:37 AM | #3307 |
I agree on the Choo Choo seats. I could ride for days in mine.......
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
08-08-2011, 10:44 AM | #3308 |
Resident of Here
Slamly Reunion show.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
08-08-2011, 11:17 AM | #3309 |
^ Wow. I like that.
08-08-2011, 08:25 PM | #3310 |
heres a couple recent pics of mine, before and after shots of the front springs. I had put in a used 4 inch lift but the front springs were junk, not only did they nearly collapse under the weight of the 454, they didn't even have a secondary leaf running the length of the primary, so it looked like they were going to snap. I was discouraged by the lack of lift in the front, and the ridiculous rake with 4 inch blocks and a big new 1 ton spring pack in the rear, so I decided to go with a 6 inch front instead of a beefier 4 inch. It looks lifted now, maybe a hair higher in the front but I'm hoping the new springs will settle down a bit for a nice level look. A little worried how it's going to look towing; some heavy tongue weight will probably drop the back enough to make it look like it's skying the front end when it's really not. Grounds not level in the pictures here, but you get the point.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
08-08-2011, 08:56 PM | #3311 |
6>8 Plugless........
Looks good. Put some air bags in the rear for towing. Did you use a cab chassis 14 bolt in the back?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-08-2011, 09:32 PM | #3312 |
I had airbags in the back of my 97 dually, but I want to try to get away without them on this truck. It's got a ton of spring to it, plus it sits about 4 inches away from the overloads. I just meant that if the tongue weight settles the rear 3 or 4 inches, and the front is already high, it may look like it's struggling to tow. I hate that look. Might have to go with airbags just to level it, or I could put the plow frame on and add some weight to the front.
Funny, in those pics the first one looks pretty level, doesn't show the ugly rake it had. And the newer ones look like the fronts a lot higher than the rear, but it really isn't. It was originally a cab & chassis truck, the fleetside pickup bed is the modification, not the rear axle. It's probably the coolest thing about the truck, gets a lot of second looks when people relaize theres dual wheels under there.
08-09-2011, 10:12 AM | #3313 |
What Hump?
Detroit Dan, looks great. Question why do some duallies have fleetside beds while others have dually fenders?
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
08-09-2011, 10:29 AM | #3314 |
C35 Crew Dually
2 diffrent rear ends. one is stock (needs flairs) and the other is Cab and chassis (can fit under the stock bed) cab and chassis are narrower to fit utility beds over them or in this case a fleet side.
08-09-2011, 11:28 AM | #3315 | |
Also, this really works best with a crewcab. Regular cab cab & chassis' are longer. So you either need to shorten the frame, lengthen the bed or go the simple route and put a c&c axle under a regular pickup truck. But, who wants a regular cab anyway? This is a crewcab thread, after all.
08-09-2011, 12:42 PM | #3316 | |
C35 Crew Dually
08-10-2011, 11:25 AM | #3317 |
Heres mine its 2 wheel drive. I bought it as is. I had a lowered obs before n now since Driving this one im thinking I should of bought a 4x4. Will 255/85/16 clear front?
There is 265/75/16 on there now stock suspension |
08-10-2011, 11:30 AM | #3318 |
08-10-2011, 11:39 AM | #3319 |
Another one of my old 89 had before the 98 then sold. Then locked 98 vortec up and decided I always liked the square body way better.
08-10-2011, 12:41 PM | #3320 |
[><]Sofa King Dirty 4x4[><]
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
08-10-2011, 07:45 PM | #3321 |
What are those wheels from, on the newer white truck?
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
08-10-2011, 08:45 PM | #3322 |
What was the drop on it in that pic (any specs you can remember/provide)?
08-10-2011, 10:01 PM | #3323 |
Ridin' Dirty
Parked next to my Bro's truck..
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
08-11-2011, 10:15 AM | #3324 |
08-12-2011, 11:15 AM | #3325 |
Heres one i saw...
Oops! |
Tags |
crew, crew cab, square body, squarebody, squarebody.net |
