#3301 |
Re: What did you do to your truck today? Chapter II
I installed a tach/vacuum cluster, floor shift tilt column, steering wheel and buddy buckets.
#3302 |
The gauge cluster and BuddyBuckets look great .
#3303 |
Painted my wheels and got some new rubber installed...
#3304 |
![]() Join Date: Sep 2005
OK will allow you to use an old license plate. You have to get a "real" tag and keep it in the truck w/you. It costs $21.50 to use the old one.
#3305 |
Nice. Go to their website and they'll let you post before/after pics. I sent them some a couple weeks ago, but haven't checked the site.
#3306 |
More pics.... Was quite a bit of decay along the bottom of the skin so had my upholstery guy sew a strip along the bottom. I thought the mismatching colors was better than a ragged finish.
I glued the skin to a metal door panel. The wrinkles are from where the foam separated from the vinyl and I did not peel all that off from the backside of the skin to reglue it. I did it on the driver side door skin, and it's a miserable job. There's the vinyl, the foam and then the paper, and the foam/paper is heat sealed to the embossed areas on the door panel. Hard to explain. I need some matching color estucheons!! |
#3307 |
Hood. Not sure if I'm going to be able to save it, or have to get it repainted..... I did the passenger side and it came out OK. The spots that have paint on them shine like new. Found myself buffing a lot of black primer to a shine.... Very delicate balance to get the dead paint off to find some that I can work, without going all the way to the bare metal.
#3308 |
Rear sport bumper. Patina truck needs a patina bumper, although am toying w/putting a new one on.
My little helper in the lower left on the 1st picture. |
#3309 |
And redid a wheel... Lots of sanding, some SEM primer, more sanding and Rustoleum professional gloss white. Magic!!
#3310 |
Started my front suspension rebuild and disc brake conversion.
#3311 |
![]() Join Date: Jun 2012
Installed my dash-pad and did some interior wiring
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#3312 |
a little further today
#3313 |
waiting for rad support to test engine ,hasn't been run yet, drive shaft coming checked out wiring harness .gotta paint headers ,but I'm gonna take a break tonight
#3314 |
Finished these up yesterday. I didn't notice they screwed up and gave me 3/4" bolts for the hooks gotta go back and get 5/8".
The knob on the hubs has some pits in them that took black paint when I sprayed the letters. they look good enough 4 me. Wrap m box m and on the self they both go for a while till I'm ready for them.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#3315 |
![]() Join Date: Dec 2012
Polishing up my bed strips in anticipation of the new boards
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3316 |
#3317 |
not a lot but dash is done
#3318 |
![]() Join Date: Dec 2015
Replaced the transmission mount. Some of you might get a kick out of my sophisticated "shade tree mechanic" jack.
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#3319 |
new booster, master, proportional valve, brackets, and lines, lines and brackets from scratch.
#3320 |
Almost done with the strips
#3321 |
One more
#3322 | |
RAT1968 '68 Cab/'71 Parts
It stumps me, though. Then again, I'm pretty loggy tonight.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#3323 |
![]() Join Date: Jul 2015
#3324 |
You guys crack me up.
#3325 |
![]() Join Date: Jan 2013
Got Rusty's cab markers glowing . Cleaned, greased, bulbs, replaced lenses with mo betta oem ones.
72 Cheyenne k/20, Custom Camper 72 Cheyenne k/20 71 blazer K/5 2WD 454, 6 sp. 67 Chevy Napco c30 Dump 56 GMC Napco 4x4 short step 66 Chevy K10 68 Chevy C/30 4x4 |
