04-01-2016, 12:32 AM | #3376 |
Post Whore
Re: Restoring Rusty
I think these pics are after only the 1st coat, things looked even more awesome after the second one
04-01-2016, 12:35 AM | #3377 |
Post Whore
Re: Restoring Rusty
the crossmember support brackets got some POR15 love too
04-01-2016, 12:40 PM | #3378 |
Re: Restoring Rusty
Looking good. Keep it up.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
04-02-2016, 09:07 AM | #3379 |
Post Whore
Re: Restoring Rusty
04-02-2016, 09:10 AM | #3380 |
Post Whore
Re: Restoring Rusty
since I had more than half a can left over of the POR15 I decided to do my best to store it, as always the lid was warped so it would not snap back on properly, so I put it on the best I could and tapped the can shut, then I put it in an air tight zip loc bag, we'll see if it will dry up or not in a few weeks / months
04-02-2016, 09:14 AM | #3381 |
Post Whore
Re: Restoring Rusty
and here's some pics with the aluminum foil off, as well as the blue tape, to be honest with you the aluminum foil did stick to the frame in two tiny places where I had to wedge it between the brake line and the frame and where I did not pull the brake line far enough from the frame, but I just removed it with a razor blade
also the blue tape did not come off as easily as I would have hoped, POR15 is more like glue than paint, maybe next time I need to remove the blue tape while it is wet instead of waiting on it to dry completely, I may use a razor to remove the blue tape residue, its barely visible around the base of each bolt head, but The Greg knows its there, ha ha so I would consider this frame ER - Engine Ready!!! |
04-02-2016, 09:21 AM | #3382 |
Post Whore
Re: Restoring Rusty
so my Mopar buddy Seth swung by the other day and pointed out that my air cleaner base had like a 2" drop in it, something I totally overlooked, and suggested I try a flatter base plate
one trip to a hot rod shop and $15 bucks later, we had ourselves a solution I appreciate all your suggestions, they were all correct, but at this time The Greg must go this cheapest route as this project(s) is really costing me lots, as I'm sure you understand, plus who's to say I can't try your suggestions, the Crossfire distributor cap (love that thing), a 1 inch carb spacer, or even a smaller H.E.I. model all together, but for now this will do, I will have to paint it black of course, but hey, whats more fun than having to strip and paint brand new shinny parts [/sarcasm] |
04-02-2016, 09:31 AM | #3383 |
Post Whore
Re: Restoring Rusty
check out all the clearance now, hewk you could drive a Prius through there, ha ha
and what's that below the air cleaner, why it's a shinny almost still new Holley carburetor, who knew that was under there? ha ha The Greg is happy(er) since now my hold down shaft is too short, hee hee, hey that's how the game is played right, fix one thing, find out another one needs a fixin' (no I'm not posting a pic of my short shaft) again thank you all for trying to help with this one |
04-02-2016, 09:36 AM | #3384 |
Re: Restoring Rusty
The engine bay looks great. Wonderful job.
04-02-2016, 09:37 AM | #3385 |
Post Whore
Re: Restoring Rusty
also I think I have the passenger side plug wire runs figured out using some of the stock Vortec wire loom clips all be it in a slightly unconventional way, but hey isn't this what Hot Rodding is all about, and does it get any more quintessential than routing your own wires? - don't answer that, jk
I went out and bought an individual 26E Duralast plug wire (which matches those that came in my set) and replaced one of the longer 32 inch ones to take some slack out of it |
04-02-2016, 09:38 AM | #3386 |
Post Whore
Re: Restoring Rusty
04-02-2016, 09:42 AM | #3387 | |
Post Whore
Re: Restoring Rusty
04-02-2016, 09:47 AM | #3388 |
Post Whore
Re: Restoring Rusty
alright Greg, so...
1. Top End rebuilt (engine painted) - check! 2. Frame & Crossmember (painted) - check! lets put that engine back in, what are you waiting for? wait what? what's next? you gotta be kidding us Smallz |
04-02-2016, 09:49 AM | #3389 |
Post Whore
Re: Restoring Rusty
Why yank that mint core support?
To quote Ogre from Revenge of the Nerds (yes I'm dating myself), "Here's why" |
04-02-2016, 09:55 AM | #3390 |
Post Whore
Re: Restoring Rusty
so lets disassemble the radiator core support
make a note that there was a bolt missing so we don't go cussin' up a storm looking for it upon assembly time, ha ha (no I have NEVER done that before) and man I always forget that middle bolt, it is nicely tucked in under the housing, so don't yank on this thing if it won't come off easily |
04-02-2016, 09:58 AM | #3391 |
Post Whore
Re: Restoring Rusty
than the radiator hold down bracket and the radiator can come off, so easy, such good access on the side of your house, ha ha
04-02-2016, 10:01 AM | #3392 |
Post Whore
Re: Restoring Rusty
and document how the horn goes on there, looks like just one bolt, but hey, we've been tricked before
04-02-2016, 10:04 AM | #3393 |
Post Whore
Re: Restoring Rusty
then we flip her over and remove the plastic grille, we make a note of all the little crusty white clips we will brake pulling off and will have to find and replace when re assembling, fun, fun
04-02-2016, 10:09 AM | #3394 |
Post Whore
Re: Restoring Rusty
all you purists may wanna skip this part and go watch a commercial or something, hee hee
I will be painting all the chrome pieces black, so in order to do that I need to scuff up the chrome, so I figured lets do that with these long strips mounted to the radiator support so that they stay in one place may be hard to see but what I am trying to show here is one side all scuffed up already (left) and the right one still sorta shinny trust me in person that one side looks nice and dull and ready for some primer |
04-02-2016, 11:18 AM | #3395 |
Re: Restoring Rusty
Just wondering how your spray bomb parts are holding up with install and general abuse.I find some of mine scratch easy and I,ve done the sanding and a good wipe with alcohol and prime and paint.I don,t think I like the dupli color bombs thou.Any thing that you have come across company wise or techniques in you process ?One of my rust primers I bought said CAN SPRAY A SECOND COAT IN AN HOUR OR WAIT 3 DAYS I can,t figure that one out.So If I don,t make the second coat in a hour I have to wait for 3 days to apply second coat or do I have to scuff it before second coat.Even the paint store couldn,t explain that one to me.
04-02-2016, 12:06 PM | #3396 | |
I know the pieces fit
Re: Restoring Rusty
04-02-2016, 07:25 PM | #3397 |
Post Whore
Re: Restoring Rusty
i kid you not it has taken me the better part of two days to disassembly this monstrocity
ok, there finally done with the back, oh wait, forgot the horn, see what I'm talking about, lol |
04-02-2016, 07:28 PM | #3398 |
Post Whore
Re: Restoring Rusty
so we turn her over, loose the grille, and then the chin comes off
let me tell you something, this trim is high quality stuff, it is bolted on and does not use those infuriating brake them at all cost clips men and women who built these trucks I salute you |
04-02-2016, 07:30 PM | #3399 |
Post Whore
Re: Restoring Rusty
and I managed to get all the nuts off the trim piece without breaking a single bolt, thank you Mr PB Blaster
04-02-2016, 07:35 PM | #3400 |
Post Whore
Re: Restoring Rusty
you all remember a while back when I reported that the hood popped open on me on the freeway, well let's meet the culprit
see that little broken baby spring I swear I knew it was going to be something so minor |
