09-28-2022, 09:21 AM | #3426 |
Re: PO has me PO'd
Yeah, I think Ray Charles could weld better than me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-01-2022, 09:05 AM | #3427 |
Re: PO has me PO'd
16646293177813820326499128216283 by James Jaros, on Flickr
Ok second attempt, spot welds weren't strong enough, more weld Turned heat up, wire speed down
10-01-2022, 09:16 AM | #3428 |
Re: PO has me PO'd
16646300026108707310386517396770 by James Jaros, on Flickr
I like the idea GMC had on the access holes, may cut 2 more, top and bottom, for my C clamps
10-01-2022, 03:46 PM | #3429 |
Too Dumb To Know Better
Re: PO has me PO'd
Jim,
I like how you are keeping at it, It has been a long haul for you. I'm excioted to see the end result. Doug |
10-02-2022, 09:51 AM | #3430 |
Re: PO has me PO'd
Thanks for the encouragement, I call it my therapy
Glad I bought my camaro back in 15, at least I have something fun to drive.... Doug, thanks for stopping by and posting up, sometimes I wonder if anyone really reads this stuff, glacially slow Going on 7 weeks of lower back pain, twice to the hospital and once to doctors office, to no avail,just injections and pills, that's not the lifestyle I want I think I may have found my welder problem someone switched to 035 welding wire, I'm used to 023
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-08-2022 at 09:26 AM. |
10-15-2022, 09:23 AM | #3431 |
Re: PO has me PO'd
16658400680457579285331816009724 by James Jaros, on Flickr
Apparently, lead work falls in the same category as welding, if you can’t lead good,lead alot Start over
10-17-2022, 12:31 PM | #3432 |
Re: PO has me PO'd
Clean up on isle 3
Ledd zep gave me a smoking deal on a speed warning buzzer, last part of that system, now I have to wire and mount, any clues on mounting location welcomed 16660239156701578065190211596116 by James Jaros, on Flickr
10-17-2022, 01:31 PM | #3433 |
Re: PO has me PO'd
16660275236377039429056022507464 by James Jaros, on Flickr
Identify the use of this tool, it was in my Dewalt drive set Has a Phillips head but no threads, sleeve is magnetic OEM prize available for correct answer No internet search or calling Dewalt lol
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-17-2022 at 01:37 PM. |
10-17-2022, 06:29 PM | #3434 |
Re: PO has me PO'd
Is it one of those bit holders, where the bit slides in, and the sleeve contacts what you are screwing into.
Thus disengaging the screw to prevent overdriving it? Like for drywall? |
10-18-2022, 08:22 AM | #3435 |
Not a bad nut after all..
Re: PO has me PO'd
It holds the screw for you so you don't drop it?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
10-19-2022, 09:56 AM | #3436 |
Re: PO has me PO'd
Can't say that either of you are wrong, because I don't know what it is.?..
10-19-2022, 12:32 PM | #3437 |
BlahBlahBlah
Re: PO has me PO'd
Mine is a version of yours. Basically you can put one of your bits in there and I makes it magnetic. They are a bugger to get back out though. Kinda works like a socket locks onto a socket wrench. Here is a pic of mine with the diagram that is in the mini holder
Almost looks like yours has a screw stuck in it. Kinda hard to tell in the pic
10-20-2022, 06:28 AM | #3438 |
Re: PO has me PO'd
OK CG, tried it and it works, just really snug, didn't want to break it.
So it looks like we have a winner
10-20-2022, 06:33 AM | #3439 |
Re: PO has me PO'd
10-20-2022, 09:36 AM | #3440 |
BlahBlahBlah
Re: PO has me PO'd
I have a few of those sets so it’s kinda like I cheated =)
I picked them up when I worked at Lowes, the people that worked in tools always let me know when something went on clearance.
10-21-2022, 10:09 AM | #3441 |
Re: PO has me PO'd
16663611590767148743234464889880 by [url=https://www.flickr.com/photos/97391199@N06
How about a w/s knob, do you need it, I think it's a 67 or 68 I put the set screw in it to check thread size..............?..
10-21-2022, 10:37 PM | #3442 |
BlahBlahBlah
Re: PO has me PO'd
No prize necessary, happy to have contributed =)
10-22-2022, 10:00 AM | #3443 |
Re: PO has me PO'd
11-02-2022, 10:22 AM | #3444 |
Re: PO has me PO'd
16673984703773450446192185152939 by James Jaros, on Flickr
Just wanted to make a fillet, for added strength and fill in my burn through Need to practice welding, no burn through Lead work sucked, dirty work area probably the cause Need to move forward on this area, so this was the only solution so far This stuff has been laying around for ever and still works
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-02-2022 at 10:30 AM. |
11-05-2022, 10:51 AM | #3445 |
Re: PO has me PO'd
16676596374944128832282892444689 by James Jaros, on Flickr
Looking like a B post to me, or at least 1/2 of a B post
11-05-2022, 08:15 PM | #3446 |
Re: PO has me PO'd
Keep at it Jim.
Looking good. |
11-06-2022, 07:17 PM | #3447 |
Re: PO has me PO'd
Thanks bud, I think you may be one of the few people who actually follow this stuff, but now I have to figure out what the piece looks like that bolts to the area I'm working on.
I suppose it mounts to the torsion box, may have to buy one.....
11-07-2022, 11:37 AM | #3448 |
Re: PO has me PO'd
16678352221473917045362126754143 by James Jaros, on Flickr
Now I have to build the flange wit square nuts welded on, I think I have them, bought from McMaster Carr Paper cut outs
11-07-2022, 03:50 PM | #3449 |
Re: PO has me PO'd
I’m sure there’s a bunch of us that have been following along. I don’t usually comment but I do check every time you post an update.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-07-2022, 08:38 PM | #3450 |
Re: PO has me PO'd
