Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-23-2013, 11:06 PM   #326
xxboondockxx
xxboondockxx's Avatar
Re: Power Steering Adapter Plates
Hello Captain. I need info on pricing for an adapter plate and the steering column shaft adapter/rag joint.
1966 C20, 350 engine
May have PM'd twice.
xxboondockxx is offline   Reply With Quote
Old 04-23-2013, 11:11 PM   #327
Captainfab
60-66 Nut
I replied to your PM.......
Old 04-25-2013, 02:38 AM   #328
Gabriel314
Thanks for the spacers Captin will keep you informed on the install!!!!
Gabriel314 is offline   Reply With Quote
Old 04-26-2013, 12:32 PM   #329
My66
My66's Avatar
Hello Captain, i pm'd you about an adapter plate.
I need a address and an amount to send the funds to.
My66 is offline   Reply With Quote
Old 04-26-2013, 04:09 PM   #330
Captainfab
60-66 Nut
I replied to your PM. Sorry I did not have a computer last night as I usually do......had to take it in to have viruses and spyware removed.
Old 06-09-2013, 02:13 PM   #331
BK'66Step
BK'66Step's Avatar
Hey Captain, I plan on PM'ing you soon to order one of your power steering box brackets but I have a question. I have the cab off of the frame and am in the process of cleaning it up and painting it. Will I need to put the cab and steering column back on the truck to install the bracket properly or do the directions already locate it where it needs to be without having to line it up with the steering column? I would wait until later to do it but I would rather weld this in place now before painting. Thanks!!
BK'66Step is offline   Reply With Quote
Old 06-09-2013, 11:19 PM   #332
Captainfab
60-66 Nut
You do not have to have the cab on the frame to install the power steering box and adapter plate. The installation instructions and the template make it easy to get the steering box located just where it needs to be. You probably will want to have the cab in place when you shorten the steering column with either the original flange or the tube and flange that I also sell.
Old 06-11-2013, 03:00 AM   #333
BK'66Step
BK'66Step's Avatar
Thank you much!! I'll be in touch soon! :-)
Old 06-20-2013, 10:05 PM   #334
Formanbob
do you have to drill the frame?
Formanbob is offline   Reply With Quote
Old 06-20-2013, 11:23 PM   #335
Captainfab
60-66 Nut
Yes the frame has to be drilled for the power steering box. There is no way around it.
Old 07-03-2013, 09:37 PM   #336
Formanbob
You got pm
Old 07-03-2013, 11:01 PM   #337
Captainfab
60-66 Nut
I sent you a reply......
You got pm
Old 07-08-2013, 11:13 AM   #338
Formanbob
back at you
Old 07-16-2013, 08:36 PM   #339
williamsboys
williamsboys's Avatar
I would like to get one of the brackets from ya.
Williamsboy
williamsboys is offline   Reply With Quote
Old 07-16-2013, 11:31 PM   #340
Captainfab
60-66 Nut
I'll send you a PM with order and payment details.
Old 07-26-2013, 01:28 PM   #341
MisterC
MisterC's Avatar
PM sent, but this is mostly a bump for your product since you always respond timely.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 07-26-2013, 11:55 PM   #342
Captainfab
60-66 Nut
Thanks MisterC
Old 07-27-2013, 12:31 AM   #343
myles66
Hey capt., I have a chance of getting a fairly cheap 59-70 impala brake booster/ master cylinder. My question is will you're brake booster adapter work with that setup on a 66 c1000?
myles66 is offline   Reply With Quote
Old 07-27-2013, 02:00 AM   #344
Captainfab
60-66 Nut
I'm not sure on that wide of a year spread, but the '70-'74 Impala/Caprice booster does fit the booster brackets that I make and sell.
Old 07-29-2013, 09:14 PM   #345
dmgibbs
I need one of your power steering adapter plates and a drawing of where i need to drill the holes Will you take a money order?
David Gibbs
Mount Olive Al
dmgibbs is offline   Reply With Quote
Old 07-29-2013, 11:26 PM   #346
Captainfab
60-66 Nut
Every power steering box adapter plate comes with the template and installation instructions. Yes I accept money orders. I'll send you a PM with details.
David Gibbs
Mount Olive Al
Old 07-30-2013, 10:32 AM   #347
dmgibbs
Send me your address and the amount to;
David Gibbs
Dmgibbs5980@Gmail.com
I need one to fit a 1966 chev
Old 07-30-2013, 11:45 PM   #348
Captainfab
60-66 Nut
All of that info was in the PM I sent you last night. I will send it again in an email to you.
David Gibbs
Old 08-19-2013, 11:35 PM   #349
J3500HD
Junior Member
J3500HD's Avatar
Hi CF,
I need one of your steering adapter plates for my '60 K10. Please let me know what I need to do to get this.
Thanks, Jerry
J3500HD is offline   Reply With Quote
Old 08-20-2013, 12:37 AM   #350
Captainfab
60-66 Nut
I'll send you a PM with ordering info.
Originally Posted by J3500HD View Post
Hi CF,
Thanks, Jerry
