Old 07-28-2013, 10:53 AM   #326
Zane M
Re: 86 Silverado Father and Son project
Great job so far guys!
Zane M is offline   Reply With Quote
Old 07-28-2013, 05:03 PM   #327
Crash_OK
Crash_OK's Avatar
Is it running yet?
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 07-28-2013, 10:16 PM   #328
EightiesOnly
EightiesOnly's Avatar
Originally Posted by Crash_OK View Post
Is it running yet?
No, I had to help do a roofing job this whole weekend for my grandpa who got hit by a tornado. WIlLL work on it tomorrow
LC.
My Truck Build (1986 LS powered c10)
EightiesOnly is offline   Reply With Quote
Old 08-02-2013, 09:14 PM   #329
EightiesOnly
Mcbassin blasted and welded the hole in these exhaust manifolds.
LC.
Old 08-02-2013, 09:52 PM   #330
rfmaster
rfmaster's Avatar
That's an EGR port, right? I would just make a plate to seal it off. But then again it is my thinking process.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 08-02-2013, 10:07 PM   #331
EightiesOnly
//RF
Yeah I guess that would have worked well too.
I painted them with some VHT high temp...
and put them on.
LC.
Old 08-02-2013, 11:29 PM   #332
EightiesOnly
Motor mounts are on.
LC.
Old 08-03-2013, 01:18 AM   #333
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Nice work!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 08-03-2013, 08:50 AM   #334
Crash_OK
Crash_OK's Avatar
looks great.. getting closer.
Mark
Crash's 69 4x4 SWB
Old 12-14-2013, 09:49 PM   #335
EightiesOnly
Well it's been a good long while since I've posted, August 8th to be exact. Once the college semester got started I just never found any time to work on it. Well now it's winter break and I've got 30 days of glory.
Today I started on changing the rear main seal and outer gasket. It has been leaking oil. Got into and it appears to be the outer metal gasket that was leaking, not the rear main.
Removing the bolts attaching the flywheel to the torque converter.
I'll finish this in the morning.
LC.
Old 12-15-2013, 11:33 AM   #336
scotts62
One day...
scotts62's Avatar
Thats going to be sweet in your truck
Scott
93 crew cab build
Project 62
Old 12-15-2013, 03:20 PM   #337
EightiesOnly
I have to agree.
So I turns out that the O'reileys brand rear main seal is not up to OEM standards. I've found several reports of them going out quick, so I'm gonna pick up an OEM one probably tomorrow.
LC.
Old 12-16-2013, 11:13 PM   #338
EightiesOnly
Got them back together.
Also got the old 350 TBI out...
Thanks mcbassin and P-DAWG85 for the help.
Let me just say that I'm not doing the swap because the old 350 was a bad engine, because it was an excellent engine. It was surprisingly reliable with 300k miles on it and a lot more left in it. I'm doing the swap because these newer LQ's are so dang good. I hope to see solid horsepower gains, slightly better fuel economy, more reliability, and just more coolness.
LC.
Old 12-17-2013, 11:51 AM   #339
scotts62
One day...
scotts62's Avatar
Dang you guys dont mess around
Scott
93 crew cab build
Project 62
Old 12-17-2013, 07:06 PM   #340
EightiesOnly
Yeah my Dad said "I just get in there and get it out."
The trans cooling lines were trashed from the wreck. So why not use the lines off of the old 700r4? Luckily the fittings from the 700r4 (left) are completely compatible with the 4l60e (right).
Installed
I also got started on the split looming.
LC.
Old 12-17-2013, 11:07 PM   #341
EightiesOnly
I got almost all of it finished.
LC.
Old 12-17-2013, 11:15 PM   #342
EightiesOnly
I got it backwards. It is 700r4 on the right, 4l60e on the left.
LC.
Old 12-18-2013, 11:54 AM   #343
Crash_OK
Crash_OK's Avatar
Wow.. You are on a mission... Looks great..
Mark
Crash's 69 4x4 SWB
Old 12-18-2013, 12:32 PM   #344
rfmaster
rfmaster's Avatar
Before I forget - make sure to replace exhaust manifold bolts with high quality heat treated bolts. Do not skip on this as it is well known weak point in all LQ/LS installations:
Frrom GM via Alldata
Notes
Bulletin No.: 06-06-01-026
Date: December 22, 2006
INFORMATION
Subject:
L59, LR4, LM4, LM7, LQ4, LQ9, LS1, LS6 New Exhaust Manifold Bolts and Torque Specifications for GEN III Vortec(TM) Engine
Models:
1999-2003 Cadillac Escalade
1999 Chevrolet Forward Control Chassis, P32 R/V Van Chassis, P42 Commercial Chassis
1998-2002 Chevrolet Camaro
1999-2003 Chevrolet Corvette, Express, Silverado, Suburban, Tahoe, W-Series Medium Duty Truck
1999 GMC Forward Control Chassis, P32 R/V Van Chassis, P42 Commercial Chassis
1999-2003 GMC Savana, Siera, Yukon, W-Series Medium Duty Truck
2003 GMC Siera Denali
1998-2002 Pontiac Firebird Formula, Firebird Trans Am
2003 HUMMER H2
1999-2003 Isuzu N-Series Medium Duty Truck
with GEN III Vortec(TM) Engine (VINs V, G, P, S, T, N, U, Z, - RPOs 4.8L, 5.3L, 5.7L, 6.0L)
A new exhaust manifold bolt and torque specification was introduced to the GEN III Vortec(TM) small block V8 engines beginning with the 2004 model year. When servicing any GEN III Vortec(TM) small bock exhaust manifolds, the exhaust manifold bolts should be replaced.
- P/N 11518860 Exhaust Manifold Bolts
Apply a 5 mm (0.2 in) wide bead of high temperature threadlocker to the threads of the exhaust manifold bolts before installing.
- P/N 12345493 - GM High Temperature High Strength Threadlocker (U.S.)
- P/N 10953488 - GM High Temperature High Strength Threadlocker (Canada)
When tightening the exhaust manifold bolts it should be done with two passes. First tighten the two center bolts on the exhaust manifold. Then tighten the rest of the bolts, alternating from side to side, while working towards the outside bolts.
Install the exhaust manifold bolts.
Refer to the following torque sequence:
Tighten
Tighten to 10 N.m (89 lb in) on the first pass.
Tighten to 20 N.m (15 lb ft) on the final pass.
//RF
"The Beast"
Old 12-18-2013, 06:20 PM   #345
EightiesOnly
//RF
Thanks for the info RF.
I'm getting ready to wire up the fuse block. I made a diagram for it.
LC.
Old 12-19-2013, 04:00 PM   #346
EightiesOnly
Revised schematics.
LC.
Old 12-19-2013, 09:06 PM   #347
scotts62
One day...
scotts62's Avatar
Sweet, you may laminate those and keep them in a safe place for many years down the road when something stupid happens haha
Scott
93 crew cab build
Project 62
Old 12-20-2013, 03:47 PM   #348
EightiesOnly
I definitely am going to make some charts to save.
So here is what I think I am going to do with my fuel system. I have read of some people that have done it with no problems. It is running an inline fuel pump in front of the switch for the dual tanks. This is what I have been running for 3 1/2 years with no problems, granted it was a low pressure pump.
The dark grey is high pressure rubber hose and the silver is the original fuel lines off of the 2001 truck. Anyone have major objections?
LC.
Old 12-20-2013, 09:43 PM   #349
EightiesOnly
I got myself a fuel pump. Big thanks to Mark (Crash_OK). If you haven't seen his build thread, you should. It is, in my opinion the best 4X4 build on this site and on of the best builds on here period.
LC.
Old 12-24-2013, 06:48 PM   #350
EightiesOnly
Bout time I tackled the fuse block.
Putting terminals and grommets (because it's going to be in the engne bay) on first.
Placing jumpers in first.
Then all of the power wires.
Then the fuses and relays.
This was an interesting process. Just make sure you double, triple, and quadruple check before soldering stuff. I had to do many things over again.
LC.
