Old 02-07-2011, 07:06 PM   #326
thelonerife
thelonerife's Avatar
Re: Chucks SWB Fleetside
Yeah just make sure it looks like the rusty one with a thick wall around the hole. I didn't even look at it before all this.
thelonerife is offline   Reply With Quote
Old 02-07-2011, 07:08 PM   #327
67chevy1series
67chevy1series's Avatar
thats sucks chuck! the trucks comin along nicely i need to get my truck to were your at...
67chevy1series is offline   Reply With Quote
Old 02-07-2011, 07:34 PM   #328
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Originally Posted by thelonerife View Post
Well, two steps forward one step back. I went to put the heater hose fitting into the water pump and got it about a 1/2 inch in and something hit the floor. It was a little piece of the casting around the hole. It has a thicker side and a smaller side.It looks like they got it too thin and when I started it couldn't take the pressure. I couldn't believe it, it wasn't even getting tight. Just my luck I guess. I'll take the pump off and see if I can get a refund. I posted a pic of the old pump and you can see the difference in the holes edges thickness. Check this if you guys buy a pump.
Hey Chuck,
If the old one is the one that I had on it, it is brand new. The water pump failed on the drive back from Colorado and so I had to replace it. Less than 2000 miles.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 02-07-2011, 09:17 PM   #329
thelonerife
Thanks Drew. I remembered that you had replaced it but didn't know how many miles it had on it. I wire brushed it a little and the surface rust came off easy. So I figured it must not have been that old. I put the fitting back in and painted it. Put it on too. Just need to touch up some paint and its done. I put my balancer on the shaft and it looks like the timing tab is too far from the balancer. I'll have to do some research.
Old 02-07-2011, 11:17 PM   #330
67chevy1series
well that is just pure luck! time to turn in the new one and get some money to dump in to the truck!
Old 02-10-2011, 12:04 AM   #331
thelonerife
Well I learned that the original harmonic balancer was an 8''. I got a 6 3/4''. So when I put it up to the shaft the tab was farther away from the balancer than I wanted. I ordered a tab for 6 3/4''. I got the advice from some members here in the engine and drivetrain section.
Old 02-11-2011, 07:22 PM   #332
thelonerife
Took the bad cast water pump back today and got my money back no problem.
Old 02-11-2011, 07:32 PM   #333
67chevy1series
good to know every thing went smoothly!
Old 02-11-2011, 10:17 PM   #334
VA72C10
VA72C10
VA72C10's Avatar
cool! Glad they didn't hassle you.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-11-2011, 10:54 PM   #335
thelonerife
Me too. They were pretty cool about it. The guy just looked at it and said it was a bad cast.
Old 02-23-2011, 01:27 AM   #336
67chevy1series
any progress?
Old 02-24-2011, 07:55 PM   #337
thelonerife
Sorry to say no. I have been trying to sell some parts to help fund this project.
Old 02-24-2011, 10:09 PM   #338
67chevy1series
as have i haha well good luck to you! ill be waiting for more progress
Old 02-25-2011, 11:58 AM   #339
Cyclone44
Step Brother
Cyclone44's Avatar
Nice truck build Chuck.....If it is going to be a power steering truck, I would love to have part numbers or measurements of the pulleys if possible!.....Or if you could snap a picture, I have two five gallon buckets of GM pulleys that I can go thru if I only knew which ones I need!!...lol....Thanks George
Cyclone44 is offline   Reply With Quote
Old 02-26-2011, 08:31 PM   #340
thelonerife
Thanks George. I got these off my 350 w/ ac. have some #s
1st pic
Inner crank 2 groove
a little less than 6 3/4'' wide
3744043BA
2nd pic
Outer crank 1 groove
3751232
3rd pic
those together
4th pic
water pump 2 groove
5 3/4'' wide
3995646AH
5th & 6th pic
ps pulley
5 3/4'' wide
3770509-CE
Old 02-26-2011, 08:33 PM   #341
thelonerife
6th pic
Old 02-26-2011, 09:03 PM   #342
Cyclone44
Step Brother
Cyclone44's Avatar
2nd pic
3751232
That's the one I need to look for!!....That helps me alot!!...Thanks for your time once again Chuck!!
Old 02-26-2011, 09:51 PM   #343
thelonerife
no problem George. I might be able to look for it next week if you don't have one.
Old 03-04-2011, 07:59 PM   #344
Cyclone44
Step Brother
Cyclone44's Avatar
I didn't have that one!!
Old 03-22-2011, 09:36 PM   #345
thelonerife
Moving at a snails pace. But moving. I got the fuel line on. I Hooked up the gas pedal linkage. I got the Harmonic balancer and lower pulleys on. I also got an electronic dist. and some rear wheel wells. I got the parts off of the board. I haven't got the wells yet though. Their new Goodmark ones.
Old 03-22-2011, 09:54 PM   #346
VA72C10
VA72C10
VA72C10's Avatar
Hey, progress is progress!!!! Looking great!!!
Old 03-23-2011, 01:27 AM   #347
67chevy1series
i have the same distributor!
Old 03-23-2011, 02:10 PM   #348
tatman
Nice build chuck, I was wondering if you could direct me to a step by step process in shortning a 1969 LWB box .
tatman is offline   Reply With Quote
Old 03-23-2011, 02:29 PM   #349
67cheby
67cheby
67cheby's Avatar
try searching for a build by Purpedo...i think he had some pretty good pics on doing this , also Drewskiren just did it on his crew cab he has some good pics also
67cheby is offline   Reply With Quote
Old 03-23-2011, 02:53 PM   #350
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Coming along nicely buddy!
--Josh
