12-29-2011, 09:01 PM | #326 |
Re: Bolt in steering rack
I have got to say that afterreading through this entire thread, it is very hard to resist buying one of these kits for my '84. I was prepared to drop over $300 to replace all of my steering components anyways, I'm wondering if instead it would be better to put my money in one of these and hold off on buying new springs and drop spindles for now. From everyone who has set one of these up already on a 73-87, how much money needs to be spent on top of the kit from rob? I am running factory pspump and steering column. Is this sonething that can be done for $1000 or less?
Shawty: '84 C10 Silverado SWB, 700r4, SBC 350 - 4 bolt main, bored 60 over w/ Weiand aluminum intake and moderate cam, 2" true dual exhaust, Thrush mufflers, 3.42:1 gears -- Build Thread The Tranny (wrecked ): '86 Trans Am, SBC 350 (now in above truck), Borg-Warner T-5, 2" true dual, Thrush mufflers, 2.73:1 gears |
12-30-2011, 07:31 AM | #327 | |
12-30-2011, 11:41 AM | #328 |
No fix is needed for any '63-'72 LCA. Any stock or aftermarket arm is fine. The only arms we had a problem with are the OEM '73-'87 LCA.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
12-30-2011, 11:49 AM | #329 |
Thanks for the update
12-30-2011, 02:57 PM | #330 |
Great!
New customer from Norway! Posted via Mobile Device |
01-02-2012, 03:46 AM | #331 |
Interested to hear feedback on these. I am looking for an easy to bolt in solution for my 67' but not sure I want to spent $$ on this and then more $$ on putting in PS. :\
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
01-05-2012, 01:03 AM | #332 |
Can someone please post up pics of a 67-72 LCA and a 73-87 LCA
Some progress is better then no progress |
01-05-2012, 05:08 AM | #333 |
At the body shop.
73 upper and 72 lower. The bushing style is difference. Hope that helps. Posted via Mobile Device
" That didnt make it any newer " " Dont antique the equipment " |
01-16-2012, 12:20 PM | #334 |
just keeping this at the top
I just know somebody is going to install this and give us some feedback.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-23-2012, 07:34 PM | #335 |
Hey rob I really need this setup any luck with those of us running stock 73-87 lower control arms
01-27-2012, 07:38 AM | #336 |
TTT for updates
02-02-2012, 03:57 PM | #337 |
hey rob,will this work on stock 3/4 ton trucks. everything on your web site and in this thread shows c10 trucks? or did I mis something..
thanks Lance |
02-02-2012, 08:44 PM | #338 |
Yes, no problem.
02-02-2012, 10:45 PM | #339 |
so after looking at my engine mounts I find that they are in the front 2 holes on the frame. my truck is 396 big block. so it looks like there are more issues to overcome here. I assume that all big blocks used the front 2 holes?
rob, can you provide any help here. sure would like to use your r&p upgrade on my truck. Lance |
02-12-2012, 03:29 AM | #340 |
BUMP!!!
ANY INFO FOR THOSE OF US RUNNING STOCK LCA 73-87...(FIX) Posted via Mobile Device
02-12-2012, 02:28 PM | #341 |
We have thre going in now, with the fix in place.Waiting for driver feedback. Should be a done deal, all the math is right.
02-15-2012, 09:46 PM | #342 |
hey Rob,
i have a question for you, i'm having some difficulties installing my rack... i know i have to do a little (read alot lol) of modifications for my specific truck to get your kit to work. here's a brief overview of whats going on, i have a '61 gmc that i have grafted a '65 front cross member onto this solved some of my problems. my main problem now is my truck has X'd frame rails, which means that my front and rears rails are boxed and narrower... i've already cut a hole into my frame to allow the first u-joint to pass through. so since my frame is different i don't have any reference holes for the where to drill for the bearing mount. i've included a few pictures to help give you an idea what i'm talking about. i decided against PMing this to you in case some one else was in my boat, thought it might be decent information to get out there one last thing ignore the two holes for the motor mounts... those are not in reference to anything, just holes i drilled to keep the engine in place right after i swapped it in x_x thanks in advance mike edit: yes I Know i need to put a grommet on the airline in my first pic |
02-15-2012, 09:51 PM | #343 |
one more pic for reference
02-15-2012, 09:55 PM | #344 |
would help if i attached the pic...
02-15-2012, 11:30 PM | #345 |
Well it looks like your on the right track. The '60 - '62 frame makes it a chore, but it can be done. The catch now is the lower steering shaft and bearing. The shaft and bearing should come threw the top of the frame in the center of the rail. I think the best bet here is to insert a tube threw the rail and weld it in. With all you've done so far this isn't too bad. 2nd, you may be able to locate the bearing support we provided ender the top of the rail, but it doesn't look wide enough. I'll post up some picts and dimensions thurs. If opt 2 is a no go, give me a call, and I'll send you a tube cut for the bearing.
02-16-2012, 02:01 PM | #346 |
well good news is that the bearing does fit inside the rail just need those dimensions and i should be good to go
02-22-2012, 03:05 PM | #347 |
man I know somebody has got to be close to completing and driving this swap... Dont make me get one and install it to do the "comparison" write up...
02-25-2012, 12:00 AM | #348 |
not to sound needy lol, but rob, man i could really use those dimensions buddy
02-29-2012, 06:14 PM | #349 |
Its taken awhile, but here are some pics of my project. Also incorporated some after market a-arms, bet you cant tell whos.
02-29-2012, 07:10 PM | #350 |
Registered Cruiser
I think you may have posted this in the wrong thread....??
By the way killertruck, your upper A-Arms (Porterbuilt) look like they're upside down...
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
