Old 04-17-2012, 05:43 PM   #326
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
The reason I mentioned it is because the peddles are different.
I ran into this when I went from the V6 to an inline 6 and had to move the bell crank location.
It is pretty simple but I don't have a hydraulic setup so I have no idea what the peddle looks like. As far as I know, they all hang the same way. Since you have upgraded your brakes you will need a new setup anyway.
I will try to get some photos uploaded as soon as I can.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 04-17-2012, 09:53 PM   #327
McMurphy
McMurphy's Avatar
Mine is set up for mechanical too.
Probably wont help you any if you are going to put in the hydralic.
The yolk under the dash, that your brake pedal and e-brake mount to should already be set up to accept a clutch pedal, just a matter of getting the right hardware for the application you want to use.
I can still post pics of mine if you want them though!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-17-2012, 10:16 PM   #328
66ChevyMax
66ChevyMax's Avatar
I don't think it matter hydro or mech. I just need the pedal and the hardware to mount it. I will make the rest. This is what I have now and I would like to se a pic with a clutch installed.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 04-17-2012, 10:18 PM   #329
66ChevyMax
66ChevyMax's Avatar
Does any after market company make one. If so I haven't found it.
Craig
Old 04-17-2012, 10:48 PM   #330
McMurphy
McMurphy's Avatar
Ok fresh off the digital camera for you!
When I got mine from a donor rig at the junk yard, I installed it the very next day while I could still remember how. (I have to do things like that because I really am not as smart as people pretend I am...)
Hope these photos help, if you have any questions of course ask, I will answer what I can.
Name:  17apr12 clutch pedal assy (1).jpg
Name:  17apr12 clutch pedal assy (2).jpg
Name:  17apr12 clutch pedal assy (3).jpg
Name:  17apr12 clutch pedal assy (4).jpg
Name:  17apr12 clutch pedal assy (5).jpg
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 04-17-2012, 11:01 PM   #331
66ChevyMax
66ChevyMax's Avatar
Thanks Murph you the man
Craig
Old 04-18-2012, 08:49 AM   #332
dean jendro
Old and crusty
dean jendro's Avatar
66Chevymax,
I went the opposite direction, from stick to automatic. I still have the clutch side stuff for some reason. If you want it you can have it.
Dean
dean jendro is offline   Reply With Quote
Old 04-18-2012, 09:15 AM   #333
66ChevyMax
66ChevyMax's Avatar
PM Sent
Originally Posted by dean jendro View Post
66Chevymax,
Dean
Craig
Old 04-18-2012, 09:56 PM   #334
dean jendro
Old and crusty
Craig,
Here's what I have from my old clutch setup. The only thing I couldn't find was the return spring but that is the easy part. I have pictured the whole assembly but I will send you the clutch arm assembly only. You may have to pull the shaft out of your brake arm assembly and clean out the crud from both ends because those 2 plastic bushings pictured on the clutch shaft go in the ends of the brake shaft, then the clutch shaft goes thru the center of the brake shaft. Kinda hard to explain but it will all be clear when you get all the pieces together. If this is what you need I'll ship it to you this week. The complete clutch arm assembly is shown in the last picture. The retainer bracket slips on the knurled end of the shaft and is secured with a bolt and nut. There's a hole in the opposite end of that bracket that secures it to the clutch actuator rod. You can see most of that in McMurphy's photos.
Dean
Old 04-18-2012, 10:50 PM   #335
66ChevyMax
66ChevyMax's Avatar
That's perfect Dean i can't thank you enough. Let me know if I can ever help you
Craig
Old 07-06-2012, 10:23 AM   #336
fattyarbuckle
any updates?
I feel like I need a fix....lol
fattyarbuckle is offline   Reply With Quote
Old 07-06-2012, 02:12 PM   #337
66ChevyMax
66ChevyMax's Avatar
I have done very little as of late, work is taking most of my time along with summer things like the pool, yard and lake, mostly work
Should be able to get back to the truck in August.
Originally Posted by fattyarbuckle View Post
any updates?
Craig
Old 07-06-2012, 04:14 PM   #338
duallyjams
duallyjams's Avatar
pool & lake sound like great progress to me ( Md = 100 + temp )
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-06-2012, 04:22 PM   #339
jimmydean
jimmydean's Avatar
Still one of my favorite builds.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-07-2012, 12:19 AM   #340
McMurphy
McMurphy's Avatar
I didnt want to be obvious about it, but .... I miss you man.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Old 07-07-2012, 05:15 PM   #341
66ChevyMax
66ChevyMax's Avatar
The problem is they are far a few between, my big deadline at work will pass on Monday the 16, after that I'm on vacation and life will be back to normal. Trust me I am thankful to be this busy, as I am self employed.
Thanks man, I hope to keep it that way.
Same here Murph, I've been checking in now and then, I just haven't posted much.
Craig
Old 07-08-2012, 10:57 AM   #342
1enick72
1enick72's Avatar
Just found this build, very nice work.
65 short step
edited by staff
1enick72 is offline   Reply With Quote
Old 07-09-2012, 10:11 PM   #343
Shooters_7
The issues your facing and figuring out will help me with my on going build! Great work so far and can't wait to see the finished product! I'm fixing to drop an LY6/4L80 into my 65 SWB BBW once I get the frame back from powder coat.
Shooters_7 is offline   Reply With Quote
Old 08-02-2012, 06:46 PM   #344
Dubnova
Bump...... This is good........
Dubnova is offline   Reply With Quote
Old 09-14-2012, 08:48 PM   #345
66-PMD-GMC
66-PMD-GMC's Avatar
I am just starting a 63 build for my brother. He wants to go LS motor... If you have any tips it would be great! By the way, just noticed... don't see any of your photos??? Sup wit dat?
Projects..
440CID 2X4 Pontiac
Old 09-15-2012, 12:28 AM   #346
Captainfab
60-66 Nut
Pics work for me.......
Old 09-15-2012, 02:41 AM   #347
66-PMD-GMC
66-PMD-GMC's Avatar
You can see the pics??? All I see are small boxes with an X in them... is my computer messed up again?? I still need those parts Cap.. waiting on my brother... I will be in touch soon
Love this build
Projects..
440CID 2X4 Pontiac
Old 09-15-2012, 03:03 AM   #348
likaroc13
Rollin' Old Skool
maybe? because I can see them too
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 09-21-2012, 07:24 PM   #349
jesse1972
This build is awesome man, and I like your shop a lot too! Just the kind of build I would like to do someday, gotta sell a 72 Nova first though!
jesse1972 is offline   Reply With Quote
Old 09-21-2012, 08:03 PM   #350
66-PMD-GMC
66-PMD-GMC's Avatar
Had my computer fixed today. Can see the photos now.
I am doing an ls motor in a 63 (frame is the same as 64-66) what motor mounts and header combo did you end up with? I read about clearance issues but do you have numbers for the final setup?
Anyone have any knowledge as to the wires I will need to feed this engine on a 4L80E?
Projects..
440CID 2X4 Pontiac
