Old 04-10-2015, 10:25 PM   #326
BigRed76
BigRed76's Avatar
Re: 67-72 Electric speedo
So I looked through the whole thread again and did not see it, but how do I change the odometer reading? I messed with it a little but it felt like I was going to break it.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 04-13-2015, 11:58 AM   #327
1965Impala
PM sent to Eric on Wednesday.
1965Impala is offline   Reply With Quote
Old 04-13-2015, 08:16 PM   #328
1965Impala
I receive my face plate and stencil to today. Great work, as always, Eric!
Old 04-13-2015, 09:51 PM   #329
68c10airstream
68c10airstream's Avatar
Eric is like allstate ins, you are in good hands
68c10airstream is offline   Reply With Quote
Old 04-14-2015, 12:01 AM   #330
ls1nova71
ls1nova71's Avatar
Ok, cool, I sent it on Friday, so was pretty sure it should have been there today.
Thanks Brian!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-14-2015, 12:04 AM   #331
ls1nova71
ls1nova71's Avatar
I don't know exactly how to explain it, but you need to take it out and just play with it a bit. You need to be sure to line up the little tabs on the bottom when you put it back together though. I think as long as you don't get too aggressive with it, you won't break it.
Old 04-15-2015, 04:49 PM   #332
67Mal
Is there anymore faceplate available? I am interested in purchasing one if possible.
Thank you for your work on this conversion.
67Mal is offline   Reply With Quote
Old 04-26-2015, 02:05 AM   #333
Beaumont@
PM sent
Beaumont@ is offline   Reply With Quote
Old 05-31-2015, 01:15 PM   #334
jks67ss396
so, i took my cluster out (using the old choke hole as a subwoofer bass control) and i want to finally paint the correct numbers on the lens , wanted to make sure everything worked first...
But i also wanted to change out my crappy little too small sockets.
can you guys confirm that the STANDARD MOTOR PRODUCTS. HP 4060 works in the socket holes
thanks all!
jks67ss396 is offline   Reply With Quote
Old 05-31-2015, 07:09 PM   #335
68c10airstream
I was the one to suggest the standard motor products socket. I chose those sockets because I couldn't find a source for the push in metal sockets and I wanted to wire in a "cruise light on" indicator that requires 2 wires, one 12+, and the ground supplied from the cruise module once it's engaged. These sockets are a somewhat flexible plastic and are 4 lug. You only use 2 lugs so I took an exacto knife and trimmed off 2 lugs. The sockets use 194 bulbs and I needed to make a harness for the back of the cluster anyway because of all of the changes, Voltmeter, 8000rpm tach, electric speedo, VSS input, cruise input,etc. I used green 194 style leds for dash lights and it looks great at night, only problem is the leds don't dim properly. They start to dim and then drop out, but for my aging eyes I love it!
Old 05-31-2015, 09:19 PM   #336
jks67ss396
did you try these sockets in the standard instrument panel lighting socket holes?
i like your idea of the cruise light. i put a "check engine" light in one of those holes. i cruise would look good in the other!!
thanks
Old 05-31-2015, 10:18 PM   #337
68c10airstream
Yes the socket worked in all the holes. As a suggestion, order just one and see how it works out for you!
Old 06-10-2015, 07:47 PM   #338
eagleuh1
eagleuh1's Avatar
Ordered 12 from RockAuto. Like $1.60 each, $5 shipping. Got them today. Thanks 68C10AS.
eagleuh1 is offline   Reply With Quote
Old 06-13-2015, 09:09 PM   #339
fast70swb
The temples stil available for 25?
fast70swb is offline   Reply With Quote
Old 06-14-2015, 03:22 PM   #340
ls1nova71
ls1nova71's Avatar
Yes, PM sent
Old 06-14-2015, 06:04 PM   #341
engairuph
Interested in template also
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 08-25-2015, 09:23 PM   #342
Curtb1971
Curtb1971's Avatar
Hey Eric,
Picked up a 97 S-10 cluster at the junk yard today and now I need your template kit. Do you still have any available? Also had a couple questions. Will the LS tach output run the factory tach and is the LS temp sensor the same resistance as the older chevy to run the temp gauge? Been reading your threads for a couple of years and your creativity has inspired many areas of my 71 lsx build. You the man dude
Thanks, Curt
Curtb1971 is offline   Reply With Quote
Old 08-25-2015, 10:51 PM   #343
ls1nova71
ls1nova71's Avatar
Originally Posted by Curtb1971 View Post
Hey Eric,
Thanks, Curt
Yes, they are still available, I will send you a PM with payment details.
As for the tach, they will work with the output from the PCM, but you will need to change the 'tach resolution' in the tune from 6 to 3. LS engines run on a 4 cylinder mode and changing the resolution will double it to an 8 cylinder.
The temp sender has been the topic of MANY threads, but what I usually do if keeping the stock gauge is to use the stock sender that was made for it. This requires drilling and tapping the head to accept the larger sender, but it's not all that hard to do and it's the best way to assure the gauge is going to be accurate.
Old 08-27-2015, 01:34 AM   #344
Curtb1971
Curtb1971's Avatar
Cool, I had a feeling I was going to have to tap the head. I was thinking of putting a bung in the radiator, but that's not as fail safe as monitoring actual engine temp on the other side of the t-stat. Sent the payment lastnight and will post some pics when I get working on the cluster, hopefully sooner then later.
Thanks again,
Curt
Old 09-05-2015, 02:12 PM   #345
Curtb1971
Curtb1971's Avatar
Originally Posted by 67c10rustbuket View Post
So right now I have 5 sets ready to go, box and plate. I obviously cannot ship until next week due to the holiday and that little child birth event on tuesday. Please do not buy one if you do not already have the kit from LS1NOVA.
If you buy a kit from LS1NOVA I can make these for you. I can supply both pieces or just the plate. Just let me know what you need. Personally I dont see much need for the box as long as you have a windshield and/or you dont put your beer err I mean soda on the dash
First two are reserved for:
CJOHNSON
WGEYER
unless they pass
Note: I do not know or guarantee that this rear box will not interfere with an original tach. I did the best I could referencing pictures but without a tach on hand its a gamble.
I will design another version without the S10 odo reset and use LED light but this is it for now. I will be away from work for the next 5 weeks so I don't expect to have that anytime soon.
The plates will need some minor deburring (with a file) due to our turret press being an antique, cant wait for the new water jet to arrive also these plates may need to be clearanced slightly below the upper speedo mount hole and the right speedo mount hole (see arrows in pic). There are a few cosmetic issues I will fix later but nothing that causes any functional issues.
I attached a couple production pics just to show how these are made. The plates are easy I just shear a sheet to size and set up the machine and push a few buttons. The box on the other hand has to be formed on our press brake and then spotwelded together. A lot of time goes into that stinkin' box, arrrgh. The punched sheet of boxes is actually an old version if you happened to notice the difference.
So the deal... Technically I can do this "for personal use only" so I am not in the position to profit on this, rather just sharing with you guys what I was doing for myself anyway. Considering the cost of steel, countless hours in design development, 3d modeling design, CNC programming, machine set up, machine run time, "G job time" ( me off the clock making these)...So I will price this at $30 shipped to your door in the CONUS only. Or just the plate only for $10. The plates are .056" galvanized steel and the rear cover box is .032" galvanized steel. I can make them thicker or thinner, what ever works best. One condition, you must tell me your opinions, complaints, suggestions, and I will work with you guys to improve these. I get paid plenty and have no reason to capitalize off my fellow truck lovers.
Hey Dan,
By chance are these still available to purchase or fab up?
Old 09-05-2015, 09:11 PM   #346
ls1nova71
ls1nova71's Avatar
Hey Dan,
Captainfab is making the mounting plate and rear cover boxes, he makes some really nice parts.
Old 09-05-2015, 09:31 PM   #347
Curtb1971
Curtb1971's Avatar
Awesome,
Captianfab is custom making me a hydro boost plate so I'll ask him if he can throw one of these on the order. Thanks for letting me know
Old 09-05-2015, 11:29 PM   #348
Captainfab
60-66 Nut
Thanks ls1nova71
Here is the for sale thread for the plates and boxes as well as the template.
http://www.67-72chevytrucks.com/vboa...d.php?t=630862
Old 09-09-2015, 08:47 PM   #349
68c10airstream
Hi Curt, ls1nova is correct on drilling the head for the original sender. I was reluctant and my water pump has a nice flat boss on the forward area that worked great. As i've stated in prior posts that when i was done my temp gauge read about 3/4 scale as the LS runs hotter than my original 68 small block. Once it was installed and at 3/4 scale i cut the wire close to the sender, temporarily installed a variable resistor and dialed in some additional resistance and dialed the temp gauge back to 1/2 scale. Removed the resistor and read the value. It was 4 ohms, so i soldered in a 4 ohm, 1/2 watt resistor inline. All is good!
Old 09-10-2015, 08:16 PM   #350
Curtb1971
Curtb1971's Avatar
Sure do appreciate the insight on the 4ohm resistor. I'm thinking of installing the temp sensor in the water pump as well as it would be easier to get the aluminum shavings out of the pump then the head. Thanks
