View Poll Results: which paint job looks best?
1 0 0%
2 0 0%
3 1 5.88%
4 0 0%
5 0 0%
6 0 0%
7 6 35.29%
8 2 11.76%
9 4 23.53%
10 1 5.88%
11 1 5.88%
12 4 23.53%
Multiple Choice Poll. Voters: 17. You may not vote on this poll
Old 10-09-2014, 12:00 AM   #326
71' Custom
71' Custom's Avatar
Re: 71' (gonna be) a one of a kind custom
Originally Posted by Ozzy2013 View Post
So did you sand blast the frame?Did it have undercoat on it?Love the gauges where did you find ones that fit?I know this was back in 2013 but any info would be greatly appreciated .Thank Oz
Hi Oz, I did have the frame blasted before the powder coating. The frame originally did not (as far as I could tell) have any under coating. I say that because the frame you see before the coating was so covered in mud and grease, you couldn't see the actual frame. If it did have the under coating on it, it got blasted off. Now technically those gauges did not fit my bezel. The speedo and tach were just 5 inch gauges and the smaller gauges I believe we're 2 3/4 inch gauges. I had to shave the holes out to fit the gauges. Interesting tidbit: The clock in the center, I had to make a filler piece to fit that one in. It was too small of a hole to fit a 5 inch gauge and too big for a 2 3/4. I was really happy with how it turned out. Although I did end up selling them. Any other questions are very welcome. I love talking trucks!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 10-09-2014, 12:02 AM   #327
71' Custom
71' Custom's Avatar
Originally Posted by Bomp View Post
Totally Killer Wheels.
Thanks Bomp!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 10-09-2014, 01:15 AM   #328
Ozzy2013
Ozzy2013's Avatar
Wow you made those look awesome im going to steal your idea gauges look great!Reason i asked about the frame mine is covered in undercoat and i need to get it off .Thanks for the info!
Ozzy2013 is offline   Reply With Quote
Old 10-09-2014, 09:48 AM   #329
BossHogg69
motor exploder
BossHogg69's Avatar
Your powdercoater is a BEAST!!! Can you PM me his number?
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-09-2014, 10:49 AM   #330
71' Custom
71' Custom's Avatar
Well the blasting will definitely take off the undercoating as well as everything else that needs to come off. And those gauges I used were the Auto Meter Phantom II style gauges if it helps. Good luck and happy building! Need anything else let me know!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 10-09-2014, 10:54 AM   #331
71' Custom
71' Custom's Avatar
Just in boxed you Adam
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 10-09-2014, 03:16 PM   #332
71' Custom
71' Custom's Avatar
Oops, new page new picture........
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 10-09-2014, 03:33 PM   #333
BigDaddyV
BigDaddyV's Avatar
Those turned out killer!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 10-09-2014, 04:01 PM   #334
71' Custom
71' Custom's Avatar
Thanks! I can not wait to get some rubber on them now!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 11-16-2014, 08:07 PM   #335
71' Custom
71' Custom's Avatar
So not much going on lately, was cleaning up in the garage getting ready for the next part....... the drive train!!! Be looking out for progress after the New Year
Thought I would snap a quick picture for my buddies!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-03-2014, 04:30 PM   #336
71' Custom
71' Custom's Avatar
So had to jump on this deal a little earlier than I wanted to. But it was on sale for Black Friday from Summit so I just had to go for it!
I had heard horror stories about these blocks, however, aside from the tiniest amount of surface rust around the holes for the head bolts, this is a great block! 880 casting, clearances for a 383, factory roller, 4.030 bore, and a 4 bolt main! This thing will rock!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-04-2014, 04:59 PM   #337
71' Custom
71' Custom's Avatar
The first meet between engine and frame.....
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-04-2014, 11:52 PM   #338
BigDaddyV
BigDaddyV's Avatar
Very nice!!!!!
Old 12-05-2014, 07:16 PM   #339
71' Custom
71' Custom's Avatar
Very nice!!!!!
Thanks, getting excited for the next part. Which will be the rotating assembly. Here are the specs:
Brand:SCAT Engine Components
Manufacturer's Part Number:1-40410BI
Part Type:Engine Rotating Kits
Product Line:Scat Engine Rotating Assemblies
Summit Racing Part Number:SCA-1-40410BI
Actual Engine CID:364
Bore (in):4.030 in.
Bore (mm):102.362mm
Engine Stroke (in):3.562 in.
Balanced:Yes
Pistons Included:Yes
Piston Rings Included:Yes
Piston and Ring Oversize (in):0.030 in.
Piston Material:Forged aluminum
Piston Style:Flat top, with two valve reliefs
Piston Head Volume (cc):+5.00cc
Wrist Pin Style:Floating
Piston Ring Facing Material:Plasmamoly
Crankshaft Included:Yes
Crankshaft Material:Forged 4340 steel
Rear Main Seal Style:2-piece
Engine Balance:Internal
Connecting Rods Included:Yes
Connecting Rod Material:Forged 4340 steel
Connecting Rod Beam Style:H-beam
This is Scat brand and I had heard from friends who claim they know someone that had a Scat crankshaft grenade their engine or something. But I have friends, that I know directly, that have used Scat's forged 4340 crankshaft on boosted and nos'd motors without issue. So I am going to give them a shot.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-07-2014, 06:12 AM   #340
Orangetonicclicc
Orangetonicclicc's Avatar
Did you use those CPP tubular mounts? I have those same ones. I had to do the same thing and drill a hole and move my motor back. My headers were hitting the frame. I have headman headers shorties. I cleared it on my frame on the passenger side, but I'm still catching the inner part of my frame on the driver side. I decided to notch my frame ever so slightly. As for the firewall. I had room to spare. Nice tight and clean. I love the look of your truck. We are polar opposites tho. You don't do chrome and I do! Lol! Didn't want to ruin your build with all that bling to show you the outcome of the mounts. But you can go to my last thread and see it. I just did it. So it will be easy to find. Those mounts are really a pain. You will need a certain header to fit so research it. I actually have different header part numbers that will fit those mounts. I just don't know how they will match your other applications? Let me know if you want those header part numbers.
Orangetonicclicc is offline   Reply With Quote
Old 12-08-2014, 01:42 AM   #341
71' Custom
71' Custom's Avatar
Just looked/read through your entire build, man you weren't kidding, that's a lot of chrome! Those are the same mounts I am using. I already have a pair of Hooker super comp headers for mine. I will notch the frame if it comes to it. It is good to know that you were able to clear the firewall though. I have been really nervous about that. I would love to see a picture of the space you have between the engine and firewall as well as the space between your belt and your radiator fans. All in all you have a really bad ass truck man, nice build! Can't wait to see more!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-08-2014, 07:52 AM   #342
Orangetonicclicc
Thanks man! I will take a picture and post the firewall and radiator space on my thread for you. The frame is no biggie, I just hope your header clears that mount. That's the big dilemma! I just don't want you to be caught unexpectedly in the middle, like I was. Luckily I was warned early about the mount. The frame was a different story!
Old 12-10-2014, 03:54 PM   #343
71' Custom
71' Custom's Avatar
Rotating assembly should be here by the 22nd of next month. Can't wait, I haven't put a lower end together in years!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-29-2014, 08:13 PM   #344
71' Custom
71' Custom's Avatar
Ordered a bunch of parts today. Ordered the diff cover, trans pan, oil pan, valve covers, breather, and a few other smaller parts. I know, I know, seems a bit premature, but remember, I have to get these all powder coated in two tone and that takes a while! Pictures to come!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-30-2014, 12:50 AM   #345
Hankster
Hankster's Avatar
Frame and engine look good! Can't wait to see it all together.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 12-31-2014, 07:42 PM   #346
71' Custom
71' Custom's Avatar
Got almost everything in today
Still waiting on the valve covers
Shipping straight from CalCustoms
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 12-31-2014, 07:43 PM   #347
BigDaddyV
BigDaddyV's Avatar
Very nice!
Old 12-31-2014, 09:00 PM   #348
71' Custom
71' Custom's Avatar
Thinking about these now,
These are the valve cover hold down bolts.
Do them black or do them blue? That is the question
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 01-07-2015, 12:11 AM   #349
71' Custom
71' Custom's Avatar
The engine build had to start somewhere
Very modest beginning. I also gave the block a new paint job. Kinda hard to see from these pictures though.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Old 01-07-2015, 12:16 AM   #350
71' Custom
71' Custom's Avatar
I also moved the engine build into my back living room inside the house. With all the cold and the rain my garage is way too humid to keep in there. I kept getting small spotts of rust.
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
