01-22-2018, 06:08 PM | #326 |
6>8 Plugless........
Re: 1971 K20- project just get driveable!!
Hi Jud! Nice to see you back posting on here! Nice work ont he engine. I was hoping you were tired of that Longhorn by now. I was also curious how the big red K30 was going.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-23-2018, 08:33 PM | #327 |
Vintage 4x4s
Yep! Maybe someday I will put a diesel in the longhorn. I have a cummins plow truck at my brothers place that would be a good donor
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-23-2018, 08:53 PM | #328 |
Roadtrip!
Good to see you are still playing with trucks!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-24-2018, 09:54 PM | #329 |
Vintage 4x4s
Yep! Found any more 67 gmcs or done more with your teal 2wd?
01-25-2018, 01:00 PM | #330 |
Roadtrip!
Saw one in a junkyard awhile back, but nothing worth saving. Still have the teal one and tinker a little and drive it in the summer.
01-28-2018, 01:29 AM | #331 |
Vintage 4x4s
It’s been a pretty stressful last couple of weeks but this weekend my buddy and I took a trip that is helping me rest a bit. Here is an original k20 Custom camper we grabbed. Not sure what I’ll do with this one. It’s not running and it’s a bit banged up but it’s not real rusty.
01-28-2018, 09:38 AM | #332 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-28-2018, 11:02 AM | #333 |
Nice save. I had responded to that add a couple times. Good to see it go to a good home.
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
01-29-2018, 07:33 PM | #334 |
That looks to be pretty solid for a MN truck
02-02-2018, 11:06 PM | #335 | |
Vintage 4x4s
She's pretty tough but not real rusty. Typical ranch truck. Check out the mudflaps, not a MN truck
02-05-2018, 01:15 AM | #336 |
Vintage 4x4s
Got the new engine install done. Took awhile to get distributor timed since valve covers were pretty much glued on. I gave up on removing them when they were showing signs of bending, even while be tapped from below with a pine 2x4 on the lip. Didn't have a spare set of gaskets so I left them and had to watch the #7 cylinder valves from the oil fill port and then count 1/2 turn of the flywheel and then line up the timing mark. It worked, and I fired it up today and set the timing quick to 10 deg before TDC then did the cam break in by running between 2000-2500 rpm for 25 mins. All went well, no leaks, great oil pressure the whole time, and temps around 180or so. What a great feeliing! I was pretty relaxed after that. I then pulled it back in the shop and drained the oil and then watched the superbowl.
02-05-2018, 10:16 AM | #337 |
That's great, that truck has come a long way.
02-06-2018, 01:02 AM | #338 |
Very nice! That has to be a great feeling!
02-11-2018, 02:55 PM | #339 |
Vintage 4x4s
Snapped a pic of the underside yesterday. Still looks pretty clean even though this truck has been living outside.
02-12-2018, 01:48 AM | #340 |
GEARHEAD
Congrats on the engine. It is a great feeling getting them going. Tears your heart when it goes south.
Now finish it up!
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
02-14-2018, 01:12 AM | #341 | |
Vintage 4x4s
I've decided the instrument cluster needs an upgrade. Want to have more accurate gauges to keep an eye on the engine and add tach and vac. Also the old Stewart Warner gauges are interesting looking in my opinion. Its a little mini project to convert the stock cluster to better gauges. I see the Stewart Warner gauges have a bit of a following and people are collecting them. Oil pressure guage is on its way here, disregard the 160psi one in there now.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 02-14-2018 at 02:07 AM. |
02-18-2018, 05:24 PM | #342 |
Vintage 4x4s
So one thing I wanted to tell you guys about is "Randolph". I was busy with this project a couple years ago when not posting on here. This ended up becoming my winter daily driver. I was drawn to the truck for parts because it had a rebuilt upgraded TBI engine in it and i could use the trans for my 72K20 and the seat for my 86K30. It turned out to be a pretty solid truck despite the body needing some work. It just drove too nice to take apart so I spent a couple months restoring the body, different fenders, bed, inner fender, POR15'ing the frame, new gas tank and fuel lines, and new snow tires. Body still isn't show quality but thats ok because I drive it in the winter here. Interior was in amazing shape to start with. It had a chevy front end on it but I took it back to GMC. Here are before and after pics.
02-18-2018, 06:16 PM | #343 |
Wow! That looks nice
02-18-2018, 11:00 PM | #344 |
Sharp looking DD
02-20-2018, 09:45 AM | #345 |
GEARHEAD
You know that it's too nice now to drive in the winter. LOL
Time for another beater with a heater.
02-22-2018, 12:30 AM | #346 |
Vintage 4x4s
Thanks guys! Mike, the thought did cross my mind. I still think the GMT400's will someday be just as popular as the 67-72's are now.
02-22-2018, 01:31 AM | #347 |
Vintage 4x4s
Pulled out the front axle that was damaged. Plowing the driveway probably put a lot of torque on this axle. I ordered a good used set off ebay that the guy said were out of a '70. They are much heavier though, so I think they are actually from a squarebody. I've read in the past that they will fit, but the oil seal area is about 2.25 and the old ones were 2 inch. Also they use a different type of seal as shown in 3rd pic below. The last pic is conventional seal for 71/72 application. I am trying to figure out what seal to use.
I do like how even the u joint area is heavier on these.
02-22-2018, 11:30 PM | #348 |
Wow, very nice work on the new to you winter driver. Did you do the paint work on it? I really like that color.
02-23-2018, 11:06 AM | #349 |
Yeah I found that out the hard way lol.
1970 Chevy K/20 truck 350 4 speed. Soon putting in a mild built 400 small block. My daily 1970 k20 - http://67-72chevytrucks.com/vboard/s...=1#post7568564 |
03-07-2018, 09:28 PM | #350 |
Vintage 4x4s
Nope, I just put the new sheetmetal on and took it to Maaco. I opted for the 2 stage setup and am pretty happy with it so far. For the money and how quick they were it was a good deal. I wouldn't take my show truck there but its 2 years old now and has held up well so far.
