Old 08-30-2014, 08:27 AM   #326
aknovaman
Re: 1954 3100 C4 Tube Chassis Build
Are you suggesting removing some of the the spring length or planing it down for thickness ?
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 08-30-2014, 12:43 PM   #327
Nut Case
Nut Case's Avatar
Get all the weight engine, front clip, cab doors and box on. measure the height, then remove approx. 1/8 from each side with a table saw, then see how much it lowers. When you get loose approx. 25-30% of the highest travel point start to test the shockwave with air pressure to see what happens. Due to the shockwave not being able full support the full weight of the truck, use the fiberglass leaf like a booster for the shock wave. By sneaking up on the narrowing of the leaf you find the optimum use with both. buy having 70% of the leaf in tack you could run if one of the bladders fails. This is my plan, it is only a theory, I'm still about 6-8 months before I can test this on my truck. Just and idea that I thought that I would share.
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-01-2014, 12:44 AM   #328
ccreddell
ccreddell's Avatar
Since when can't a Shockwave hold up the vehicle?
ccreddell is offline   Reply With Quote
Old 09-01-2014, 02:28 AM   #329
Nut Case
Nut Case's Avatar
I'm told by the manufacture that in a 57 GMC with a 454 that the weight would exceed the limits of the shockwave. So I'm investigating viable alternatives. Any suggestions?
Old 09-01-2014, 11:55 AM   #330
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
ccreddell, I see what youre talking about, (when you first mentioned this I thought you were talking about a Watts link for some reason) It seems cool but a crazy amount of extra work when you can just run Shockwaves instead. Definitely adds to the WOW factor though. Ill be watching to see how your project progresses. Good luck and post lots of pics.
--Josh
Old 09-02-2014, 03:13 PM   #331
ccreddell
ccreddell's Avatar
I need a little more movement than a Shockwave would give me, and Ive never been comfortable using shock mounts to hold a car up (or a truck), plus it will ride better.
Old 09-02-2014, 03:15 PM   #332
ccreddell
ccreddell's Avatar
Stock suspension?
Old 09-06-2014, 12:44 PM   #333
STOCKISH
STOCKISH's Avatar
Going to be parting this out soon if it doesn't sell whole. Everything available for sale.
--Josh
Old 09-10-2014, 10:32 AM   #334
FarmerSid
FarmerSid's Avatar
Not happy to hear this Josh! Not happy one bit! LOL! So what are you gonna work on now?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-28-2016, 01:00 AM   #335
tiddlar
Pretty girl you have. I like the stance too, I wanted my front wheels tucked more away from the fenders gives it a very aggressive look imo. You chose to have yours closer to the fenders, looks exceptional with wheel/tire combo. I'll stalk this thread.
Purgatorio
tiddlar is offline   Reply With Quote
Old 09-28-2016, 10:05 AM   #336
STOCKISH
STOCKISH's Avatar
This truck has been sold a while ago, I am starting another one right now, Project Redemption. Its here in the build section as well.
--Josh
Old 08-18-2019, 11:22 AM   #337
Gregski
Post Whore
Gregski's Avatar
Wow, Skill Level: Expert
Gregski is offline   Reply With Quote
