10-02-2018, 12:23 PM | #326 |
Re: 1978 Russet Metallic 4x4
I want to say I'm surprised that they didn't hook up the IAT, however, we once got an install back and it was running terrible. Started poking around and they had just laid the IAT (which was plugged into the harness) on top of the intake manifold and called it good. It was at that point I started learning to do it myself. Cannot believe what people will charge you to do, and then do it terribly. I'm glad you found a reputable shop to take care of this for you!
10-04-2018, 11:32 AM | #327 |
First off, wow, just made my way through this thread.
Second off, RamJet 350, epic! On the transmission front a well built 4L65e will handle everything that RJ350 can throw at it, just make sure and put a nice big cooler on it. I 100% agree about 1st gear in a 4L80e. When the time comes to LS swap my '89 it will likely get a 65e. Not sure on hooking the 203 up to the newer tranny, however.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
10-04-2018, 12:42 PM | #328 | |
10-16-2018, 07:52 PM | #329 |
I've grown frustrated with the twin stick. The shifting is easy, but the linkage likes to bump the transmission tunnel and I need my little spacer bar to keep the kids from accidentally shifting the levers. So I dug up the old shifter that looked more like a heavy turd and started chiseling away the baked shell of 40 years of mud. Then I worked it with some brake cleaner. Disassembled. More brake cleaner, then soaked it in Evaporust for a day. Reassembled with a bunch of lithium grease, and its ready to go back in the Blazer. Found new bushings for the levers here: https://www.ebay.com/itm/1970-79-All...e7d7%7Ciid%3A1
These little refurb projects are fun. I'm also moving away from the 4-speed auto idea. It just feels like I lose too much identity with that upgrade. Last edited by buffydores; 10-16-2018 at 08:48 PM. |
10-16-2018, 11:23 PM | #330 | |
Posted via Mobile Device |
10-17-2018, 11:58 AM | #331 |
I like the idea. I'd want a fully electronic setup. I just always get in a constant cycle of always changing factory stuff. Sometimes its better, but sometimes, its not worth the hassle. The truck is fast enough off the line already. I'd get better fuel economy at highway speed, but I'm not roadtripping this rig anywhere. It's not a daily driver. I'm sitting at 3000rpms at 75mph. It's high, I know, but it's not gonna hurt anything.
10-23-2018, 07:32 PM | #332 | ||
Moderator
Breeze Liner doesn't make their liner clamps smaller than 3/4" or so. That's why I recommend the Fuel Injection Clamps or Rotor Clip type spring band clamps. My 1994, 1998, 2000, and 2005 GM trucks use(d) a lot of the spring type clamps rather than Jubilee worm clamps. No extrusion. You can put a quick and dirty bubble on the end of the steel lines with a brake line flare tool and then you only need one clamp.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-23-2018 at 07:38 PM. |
10-26-2018, 10:17 PM | #333 |
Pretty sharp looking:
10-27-2018, 10:16 AM | #334 |
Nice, clean, stock.
10-27-2018, 11:41 AM | #335 |
Hell yeah, that looks awesome!!
10-27-2018, 04:26 PM | #336 |
11-20-2018, 08:10 PM | #337 |
Installed some pimp valve covers. Starting to look pretty good under the hood.
11-22-2018, 02:21 PM | #338 |
Hi from England Cameron,
I have never wanted a K5 in 4WD form before, but your thread has me wondering about that. Just read through it all. I have a 66 C10 in “kit form” in my garage thread here http://67-72chevytrucks.com/vboard/s...d.php?t=585901 And on the 6th October, I bought a 79 Blazer in 2WD form here in England. Thread http://67-72chevytrucks.com/vboard/s...d.php?t=774451 I come to the USA every year to do road trips, and almost made it to Longview this year, as I had thought of looking up Karl, Aggie on here as he lives there too, but ended up doing 8 states in 2.5 weeks. http://forum.retro-rides.org/thread/...2018-humdinger Looking at your restoration, and constant evolution, my brain got stuck on one piece of kit you fitted..... That rear wind deflector. Where did you order that from, and are they ever around used, as my Blazer is as rough as a badgers butt. I also saw Bill “Palf” fitted a 4x4 front lip/airdam to his 82 Square stepper, does one see them around to buy or new? Thanks, and awesome build as everyone has said so far. I love the fact that you use it, and the photoset of it working off-road etc was great.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
11-22-2018, 03:58 PM | #339 |
Moderator
That is sharp looking. Nice touch that isn't over the top.
And please let us know if and how your repairs were successful. |
11-22-2018, 06:33 PM | #340 |
Grizz: Thanks so much for the kind words. The rear deflector shows up used periodically. It was a GM accessory. I saw a used one last week on here for $150. They are designed to keep the dust from gathering on the back glass.
11-22-2018, 06:39 PM | #341 |
03-11-2019, 09:51 PM | #342 |
I finally got around to replacing the beat up door handles. Amazing how well new ones with fresh springs work. Also allowed me to lube up the window apparatus.
03-11-2019, 09:54 PM | #343 |
Definitely amazing what we learn to put up with, nice work!
03-12-2019, 11:42 AM | #344 |
Nice handles. Did you find GM ones or are they Repops?
03-12-2019, 01:57 PM | #345 |
Got them from LMC; reman., but they look like quality stuff. It feels tight.
03-13-2019, 03:54 AM | #346 | |
Excellent Always good changing for the better. Love the security tape around the work area, such a simple insurance.
03-13-2019, 09:25 AM | #347 |
Thanks Rian Cheers.
03-26-2019, 06:28 PM | #348 |
When I was growing up, we had a late 70's GMC Jimmy that had a factory lift and granny gears. Where is the best place to find one if I'm looking to purchase something similar at a reasonable price?
Here is a pic that I found of a similar looking rig. I remember many amazing hunting and 4-wheeling trips in that beast. |
03-26-2019, 08:37 PM | #349 | |
Here's a few on Hemmings: https://www.hemmings.com/classifieds...min=&year_max= Last edited by buffydores; 03-27-2019 at 08:42 AM. |
03-28-2019, 05:43 PM | #350 | |
Until I get the real-deal, I'll need to pick up one of these RC rides. It's the next closest thing. https://traxxas.com/products/landing/blazer/ |
