Old 11-25-2020, 10:55 AM   #326
jimbosprint
jimbosprint's Avatar
Re: '72 Cheyenne K10
Lol. I deserve that probably.
The scout motto is "be prepared". Like all recovery gear or an umbrella, you bring it and hope you won't have to use it.
jimbosprint is offline   Reply With Quote
Old 11-25-2020, 06:08 PM   #327
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good point. Now I'm going to add some chains to the winter kit in my Suburban. No snow at present but we've had over seven inches this season.
Old 11-27-2020, 04:02 PM   #328
jimbosprint
My headlights didn't match so I replaced them today. I tried out these Hoppy adjusters that a friend let me borrow. We'll see how it looks at night.
Old 11-27-2020, 05:16 PM   #329
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Those adjusters will probably get ya close. I wish I still had some of those adjusters.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-04-2020, 11:59 AM   #330
jimbosprint
I am man enough to admit when I make mistakes. I never checked the transfer case oil when I started driving this truck, and it was empty until I filled it the other day. Now I know why it always made a loud clunk noise going between drive and reverse. I don't have that many miles on it, but it could not have been good for it. I have another NP205 to swap in if it fails down the road.
The transmission has also starting to leak more recently, and probably should get rebuilt or at least re-sealed. It works fine otherwise. I also have another TH350 to swap in (needs rebuilding). I'd prefer to fix it all at the same time, but I am going to drive it as is for now.
Old 12-04-2020, 04:49 PM   #331
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good you caught that. I need to replace the speedometer drive seals in mine this spring.
Old 12-04-2020, 06:06 PM   #332
jimbosprint
I'm sure it will leak there now that it has oil. It would also be nice if my speedometer wasn't way off. When it says 60, GPS speedometer says 40.
Old 12-05-2020, 10:05 AM   #333
DeadheadNM
Carpe manana
DeadheadNM's Avatar
This shop can build a gear ratio adapter to replace the OE example in a ratio that gives you an accurate speedo reading. https://speedometercablesusa.com/
They assembled one for my Blazer and now the speedo is dead accurate.
This shop can supply the inner and outer seals for the adapter nut at the tcase or a brand new nut with the seals already in place. I’ve got their seals with the intent to install this spring.
https://torqueking.com/product/30091...chevy-and-gmc/
Old 12-06-2020, 11:57 AM   #334
Ol Blue K20
You just reminded me to check mine too.
Dale
Old 12-10-2020, 10:11 PM   #335
jimbosprint
The lumber rack had a couple cracks in it, so I had a local welder add some reinforcement. I just have to spray some paint on it so it doesn't rust.
Old 12-18-2020, 02:12 PM   #336
jimbosprint
A little spray paint should keep the rack from rusting. I know, I know... I should have just taken it off and done the whole thing.
Old 12-20-2020, 08:53 AM   #337
Ol Blue K20
Attachment 2068357
I didn't say a word....
Dale
Old 12-23-2020, 01:44 PM   #338
jimbosprint
With the factory tow hooks being so expensive, these 3/4" thick steel bolt-on recovery points are perfect for this truck. They are made to go under the factory bumper. I bought them off a guy on Facebook - $90 shipped for the pair. I need to buy paint, nuts/bolts/washers, and a 5/8" drill bit to go through the frame.
Old 12-23-2020, 09:30 PM   #339
jimbosprint
Now that I have them on the truck, I don't like where the holes are drilled in these. They are so close to the top and bottom edge of the frame that there isn't room for a washer on the inside of the frame. Since my frame doesn't have any holes drilled, the maker offered to get me replacement hooks with a different drill pattern. I just have to wait a couple weeks.
Old 12-24-2020, 06:49 AM   #340
Ol Blue K20
They look pretty nice and they look strong too.
Dale
Old 12-30-2020, 03:44 PM   #341
jimbosprint
I traded a friend my chrome reproduction bumper for a factory painted bumper. The metal is easily twice as strong. I wonder if I can get the silver paint off without destroying the white paint underneath. Looks great as is.
Old 12-30-2020, 10:09 PM   #342
Ol Blue K20
It does look good....
Dale
Old 12-31-2020, 08:26 PM   #343
jimbosprint
So the guy that made these shackle hooks said it would cost extra for a custom set. I decided to go ahead and drill the frame out for the ones that I have. Sandblasted, painted, and installed.
There was no room for a washer on the top bolt, and I had to cut down the inside washer on the bottom bolt, but I would say it is still a lot stronger than factory tow hooks.
Old 12-31-2020, 09:51 PM   #344
Ol Blue K20
I like them, they should be pretty strong too.
Dale
Old 02-06-2021, 10:04 PM   #345
jimbosprint
I used the truck to help a friend pick up a temporary PG&E power pole from up in Paradise. His house in Boulder Creek burned down last year. I'm glad I can help him rebuild.
Old 02-07-2021, 01:04 AM   #346
bobvilla67
[QUOTE=jimbosprint;8853709]With the factory tow hooks being so expensive, these 3/4" thick steel bolt-on recovery points are perfect for this truck. They are made to go under the factory bumper. I bought them off a guy on Facebook - $90 shipped for the pair. I need to buy paint, nuts/bolts/washers, and a 5/8" drill bit to go through the frame.
I like these. Have contact info? I’m not on Facebook.
1968 Custom 10 SWB
1970 2wd Blazer 350/400
1972 K20 292/350
bobvilla67 is offline   Reply With Quote
Old 02-07-2021, 06:42 AM   #347
72 tigger
72 tigger's Avatar
Attachment 2080117
That’s really great that you’re helping him
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 02-07-2021, 11:52 AM   #348
Ol Blue K20
Truck looks good working. I'm sure he appreciates any help he can get.
Dale
Old 02-26-2021, 07:57 PM   #349
jimbosprint
This should be pretty cool when I get around to swapping out the transfer case.
Old 02-26-2021, 09:37 PM   #350
Ol Blue K20
Attachment 2084362
So you're double sticking the 205?
Dale
ochre
