Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 12-07-2023, 04:46 AM   #326
LT7A
Re: Another Blue Chevy
Sometimes the build threads stop once the rig is all put together. More fun to see it incorporated into daily/weekly/or monthly life after that. Once in awhile updates is just great.
Old 12-07-2023, 11:02 PM   #327
3757chevy
3757chevy's Avatar
They are never done IMOA.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 12-08-2023, 11:46 AM   #328
VWNate1
VWNate1's Avatar
Post 'Finished'
As they're machines they cannot be finished unless you never use them .
Not using your truck is a mean thing to do .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 12-09-2023, 05:59 PM   #329
3757chevy
3757chevy's Avatar
Re: 'Finished'
Yep.
MIKE
Old 12-22-2023, 10:09 PM   #330
3757chevy
3757chevy's Avatar
I've been chasing a coolant leak , thought it was a loose lower hose but a closer look shows it to be the radiator . There is no one around that repairs them anymore. I don't just want a patch , so I found a new aluminum replacement and received it today . Now I have to figure out how to change it . I'm hoping I don't have to dismantle the front of the truck to change it.
MIKE
Old 12-23-2023, 10:50 AM   #331
VWNate1
VWNate1's Avatar
Thumbs up Radiator
That's a thing of beauty .
I hope you remember to flush and clean the cooling system annually regardless of mileage or it will have a short lifespan .
I'm curious to see what's involved with swapping it out .
? How many rows in the core does the new one have ? .
-Nate
Geezer
Old 12-23-2023, 06:02 PM   #332
3757chevy
3757chevy's Avatar
Re: Radiator
Three row.
I've been looking on line to try to find info on changing it out without any luck. I guess I will learn as I go. I'm pretty sure the hood assembly has to come off . I hope the grille surround can stay put.
MIKE
Old 12-24-2023, 08:01 PM   #333
VWNate1
VWNate1's Avatar
Post Radiator Replacement
I don't know if the old car manual project . com will have the factory shop manual, they may well .
I had a 1946 3100 in the 1970's and IIRC the grille was about the only thing I didn't have to remove when doing radiator service .
-Nate
Geezer
Old 01-12-2024, 03:56 PM   #334
3757chevy
3757chevy's Avatar
I've not gotten far ,was feeling under the weather for a week now the weather is changing. I have gotten the hoses removed and the fan blade off. there is no drain plug that I can see so I've gotten coolant every where but the drain pan. I bought a new upper hose and am still researching what lower to use. I want molded hoses and I think I may have come up with a couple of candidates, but I don't know the exact dimensions of that first picture. I guess the second one could be spliced to make it work.
MIKE
Old 01-12-2024, 04:05 PM   #335
3757chevy
3757chevy's Avatar
Re: Radiator Replacement
I don't know if the https://oldcarmanualproject.com will have the factory shop manual, they may well .
I found no info there about removal of the radiator, but thanks for the help.
MIKE
Old 01-13-2024, 10:07 AM   #336
VWNate1
VWNate1's Avatar
Post Coolant Hoses
I don't supposed there's a F.L.A.P.S. near you you regularly trade with ? .
My old local NAPA store (now closed) use to let me wander the aisles with an (very clean) old sample hose in my hand, peering up inmto the gloom where the hew hoses were hung on hooks .
Once in a while I'd buy a hose I couldn't cut down and use, I never took those one back so I was able to make my own molded hose selections .
-Nate
Geezer
Old 01-14-2024, 06:12 PM   #337
3757chevy
3757chevy's Avatar
Re: Coolant Hoses
My old local NAPA store (now closed) use to let me wander the aisles with an (very clean) old sample hose in my hand, peering up into the gloom where the hew hoses were hung on hooks .
I worked in auto parts for 45 years in town so they let me have the run of the stores. That is how I got dimensions on the hose they had in stock. The other hose would have to come from out of state with freight involved. I have a friend with a car I can get measurements from . I'm pretty sure that will be the hose I need.
MIKE
Old 01-20-2024, 03:46 PM   #338
3757chevy
3757chevy's Avatar
Well I found a drain plug after all. After I figured out that the whole front of the truck DID have to come apart to get the radiator out. Time to clean up a few things before it goes back together.
MIKE
Old 01-21-2024, 09:40 PM   #339
3757chevy
3757chevy's Avatar
When I showed my three year old grandaughter that picture she did a double take took my phone studied the picture and handed it back saying "that's broken".
MIKE
Old 01-21-2024, 10:07 PM   #340
Getter-Done
Getter-Done's Avatar
That is so Precious that she noticed that.
I see the drain plug.
84 Chevy K-20
Old 01-21-2024, 11:40 PM   #341
3757chevy
3757chevy's Avatar
Yep I didn't see it till I had it out of the grille shell. The new radiator doesn't have one.
Her and her big sister really like Papas Trucks.[this picture is one and a half years ago]
MIKE
Old 01-24-2024, 01:13 AM   #342
3757chevy
3757chevy's Avatar
Re: Wile E Coyote Hood Ornament
Today I added a hood ornament. My wife has been wanting me to do this for a while now. I finally found one she liked. I wanted Wiley Coyote riding a rocket. (she said no to that.)
Son of a gun, I found it ! .
https://www.amazon.com/s?k=wile+e+co...s_ts-doa-p_6_5
I think I'll buy one the next time I make an Amazon order .
Nate did you get the ornament and if so was it a decent quality?
... I've had to hard mount mine to the grille surround cause the new radiator has a cap mounted in the engine compartment. I was to trying figure out how to do it . I had an extra radiator cap that was inoperable so I drilled a hole through it and used a stud to mount it under the other to hold it on. I cut out a rubber pad from a sheet of rubber. I am pretty sure this will work just fine.
MIKE
Old 01-24-2024, 09:03 PM   #343
VWNate1
VWNate1's Avatar
Post Rad.Cap. Ornament
No, I didn't I don't order a whole lot of things .
I spent some time looking at the various ones for sale, some look really bad, others less so so take the time to read all the comments from each and every different vendor .
-Nate
Geezer
Old 02-01-2024, 02:02 AM   #344
3757chevy
3757chevy's Avatar
Well I got the hose for a passenger car and it fit like a dream.
MIKE
Old 02-01-2024, 02:09 AM   #345
3757chevy
3757chevy's Avatar
I've gotten it ready for someone to help install the hood back on. I'm hoping to get that in the next day or two.
MIKE
Old 02-01-2024, 02:14 AM   #346
3757chevy
3757chevy's Avatar
The top hose was simple.
MIKE
Old 02-09-2024, 02:31 AM   #347
3757chevy
3757chevy's Avatar
I changed fuel filters, cap, rotor, and plugs Today. Then I took the truck for a test drive. Stopped and took this picture.
MIKE
Old 02-09-2024, 10:12 AM   #348
Rickysnickers
Nice!
Old 02-09-2024, 02:22 PM   #349
3757chevy
3757chevy's Avatar
Originally Posted by Rickysnickers View Post
Nice!
Thank you sir.
MIKE
Old 02-20-2024, 04:49 PM   #350
3757chevy
3757chevy's Avatar
Today I modified a part to make my compression tester work for my truck. I posted this in tool threads as well......I bought a compression tester to use on my '35 Chevy with a '67 Chevy 250cid inline 6cyl engine. The engine uses long reach spark plugs but the threads in the head start aways down in the head.[as seen in picture #2 in fitting #3] The fittings that came with it would not work for my engine so I bought a package of spark plug non-foulers and modified one to work . I thought I would share my fix in case anyone else ever has this issue.
MIKE
