#3476 |
Re: What did you do to your truck today? Chapter II
Not a big Toyota fan compared to old iron but like the idea, perfect powertrain that's bullet proof compared to American built and cool old style Gm body, thumbs up, hope it all works out. I like different projects that take a thinker to build.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#3477 |
Well one more task down. Got the new seat covers installed. Thanks to Rick's Custom Upholstery. Came out really nice.
#3478 |
Nice!.. How do you like the one piece windows? I'm struggling with buying a kit from a guy that didn't use it...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#3479 |
I did! Both of them built right here in our States!
And thank you Don "Ole dollar", I'll post pics soon!
I would rather have a free bottle in front of me than a prefrontal lobotomy!!!! |
#3480 |
Got started on the patching of the front of the hood today... hope to get the rest of the metal work done tomorrow and get started on the finish work. About tired of screwing with this hood...
#3481 |
I was able to get some metal on the truck today, doors, inner fenders, fenders and grill along with a few trim pieces.
#3482 |
![]() Join Date: Feb 2009
Pulling wire mode today. Next up is score some hose line to see if the windshield washer system works. I'd like to see what I've got before I remove the LH dash panel components. Since I've owned this (1989) its never been hooked up, including a missing bottle. But it makes noise when I trigger it. I noticed the jets might be a bit clogged, could be why they disconnected. Will find out soon enough. 70/30 it works.
All new to me...........This is pretty cool. I've managed to avoid the windows and door latches so far (ha!). But I'll soon run out of parts to remove as I keep her running. Speak of, safe to assume I can remove the entire emergency brake system and still have brakes? Believe it or not, I've never even done a brake job outside a master cylinder and bleeding brakes...........Meanwhile, I'm taking this down to nuts and bolts.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#3483 |
#3484 |
Looks perfect. Let me know if I'm off base, but it seems the best way is to mount the inside of the bumper first, snug, not tight............line up the outer brackets, then tighten it all down.
Have to admit I butchered my rear bumper along time ago. Something wasn't right. When I tightened it down the brackets bent the bumper in places (whoops). Can't/won't happen again. I figure the brackets weren't positioned right.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-03-2016 at 01:35 AM. |
#3485 | |
#3486 | |
Thanks for the info. Looks great.
#3487 |
Got my dash painted today. Now I can install it and start on the wiring, which is what I was planning on doing before I realized the dash needed to be replaced. One step forward.....
Dennis '70 CST/10 '55 Bel Air wagon |
#3488 |
Installed a new adjustable vacuum advance and set the timing on the 462CI BB in ol Samson today.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#3489 |
Well, I'm currently in "ID that wire" mode for under the hood. Honestly, those who altered some things did a sloppy job, so I'm rebutting a few lines so they route correctly, even though its all going to be pulled and replaced. I'll have plenty good questions about what's correct Vs what's wrong................Will save that until after I ID what goes to what and where.
On a side note, the more "exposure" the more I realize there's really not much to the wiring. At least not on these trucks. That said, I haven't dove into the LH dash panel yet. ![]()
#3490 | |
But I say its simple before I get to that point myself... Im sure there will be even less hair on my head when it all done...
#3491 |
![]() Join Date: Feb 2016
#3492 |
![]() Join Date: Dec 2012
More progress completed on the wood for the bed today. Routing and final sanding done - ready to apply the stain. Going for a reddish brown final color.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3493 |
![]() Join Date: Jul 2015
Took it catching today, released a 18lb spring chinook native and released.
46 years and still working the pasture over. |
#3494 |
I like it. I haven't had any problems besides forgetting to glues the seal in. My wind wings were rusted out and the one piece window kit cost me less then buying a new set of wings so I saved money in the long run. And I can always switch back if needed. Thanks
#3495 |
![]() Join Date: Jul 2014
Attempted to start my new engine, leaked gass all over the garage floor, will try again tomorrow!
#3496 |
#3497 |
replaced the rubber grommet around my gas tank filler tube. Not near as bad as I thought it was going to be
71 swb 350/4sp manual 5/7 static drop |
#3498 | |
![]() Quote:
Have a good one, Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#3499 |
Minor upgrade last night. Lost the rusty chrome cover and installed this stock restore. New gear oil and found out I have 3:08 gearing
#3500 |
doors fitted waiting for the good fenders and hood
