#3476 |
Re: Restoring Rusty
#3477 |
Re: Restoring Rusty
3-5" of snow here tonight. I would much rather have the rain.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#3478 |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
Saturday = RAIN !
#3479 |
Post Whore
Re: Restoring Rusty
Sunday = RAIN !!!
#3480 |
Post Whore
Re: Restoring Rusty
alright guys, it's raining this weekend, we get it, but that don't mean we get to sit idle, so as you may recall when we set out on this last excursion we called it March Madness, oh yeah, I remember, but didn't all you do was swap some heads on your engine, what's the big deal amigo?
Um no, there's much more to MARCH MADNESS than that, so let's list all the things we are doing before this all goes back together on D Day, Saturday April 16th, 2016 1. Vortec Cylinder Head - Top End Upgrade 2. Paint Frame \ Crossmember 3. Midmount Alternator & Re Route \ Clean Up Engine Wire Harness 4. Replace \ Paint Core Support 5. Black Out Grille Molding and Headlight Bezzels 6. Overdrive Transmission Upgrade anything jump out at you guys there? ha ha anything we haven't touched on yet... |
#3481 |
Post Whore
Re: Restoring Rusty
ladies and gentelmen, I may have pointed this out before, but it's worth saying again, I have picked out my truck for as much as it didn't have as for what it had
I did not want a 4x4, I did not want an Automatic, I did not want Air Conditioning, I did not want 3/4 ton or a 1 ton truck, nor did I want a long bed. I wanted a 2WD, 350 V8, manual, short bed, plain Jane, dime a doze (or so I thought, but these plain trucks are harder to find than you know), simple and easy to work on. And I pretty much got all that, but one thing. Ok, two things I wish the truck had. 1. OVERDRIVE TRANSMISSION, I had no idea going beyond 1:1 ratio wouldn't become the norm till the 80's lol when I bought my beloved '74and so The Greg went Big Game a hunting for a very rare albino samoan polar bear unit called the New Process 833 trans-a-mission and on one faithful day back in December '15 he found one AND WHAT AN ABSOLUTE BEAUTY SHE WAS ~ TAKE A LOOK ~ Craigslist Condition: "Mint" |
#3482 |
Post Whore
Re: Restoring Rusty
now there may be some overlap coming up with my other thread called What can be said about the 4-speed New Process NV833 overdrive manual transmission? which you may or may not have seen, I apologize for the redundancy and will try to keep this more on point of the upgrade and installation process and not bore you to death with regurgitated "facts" and "specs" of that unit that I just happened to gleen off the InterWebs pretending to be a self proclaimed expert on the topic, ha ha
so how much did The Greg drop on this thing? $300 bucks, $500 dollars, surely no more than $750 bones? WHAT? he paid NINE HUNDRED AND FIFTY DOLLARS for it, what a dope!!! Wait, and he drove over 350 miles one way to pick it up! ah jeez, I gotta hear him explain his way out of this one, lemme pull up a chair |
#3483 |
Post Whore
Re: Restoring Rusty
wow, tough crowd, tough crowd
well guys let me share some insight with you, things I learned along the way while researching this trans, as it may help you I went the Saginaw 4 speed route and the Muncie 4 speed route first and learned those transmissions were not overdrive transmissions, I was surprised, I did not realize there was no overdrive in the 60's (you know what I mean, I mean not every car had it, I'm sure some did) not even in the 70's cars ran around with 2 speed automatics for crying out loud with names like Powerglide, and then the 3 speed automatics called Turbo this and that, (non of it being Turbo in any way mind you) then there were 3 on the Tree manuals, wow THREE GEARS really, sounds cool Three on The Tree, but honestly wheres the other gear, LOL OK, so I punted on the 60s/70s technology and fast forwarded to the 90s ok I will get an NV3500, wait what? they are weak, they come on six banger trucks, ok what about their big brother the NV4500, ok better, but wait the case is longer the stick is going to be between my girlfriends legs, and then theres the whole Getrag mix up confusion (say what? GetWho?) yeah there's the German overbuilt overcomplicated unit that looks like the NV4500 to the uninitiated [pronounced] ME and if you pull the wrong one at the junkyard no one in the States will touch it - go ahead Google it [we'll wait]... ... and then there's the speedo electronic connection instead of the cable, and this and thats, and nope, we'll punt on the 90's tech OK, back to the 80s, hmmm wonder if these trucks ever came with Overdrive transmissions from the factory? Say what? They did? Thank you Wikipedia. and that's how we got ourselves one of them 1980-85ish ... (87ish) New Process 833 units |
#3484 |
Re: Restoring Rusty
Its funny how we want so many options out of a truck but always have to settle simply because what we want isn't available. Where I live short box trucks are almost impossible to find in the 73-87 and 88-98 era so you usually end up with a long box unfortunately.
As you also have found the NV3500/4500 are not that great of transmissions as the stated reasons about but one thing about the 4500 that is even worse is it requires a special type of fluid that is STUPID expensive from the dealership. NV3500s have an issue with the 5th/Reverse nut coming off randomly and losing those gears. For the 73-87 era and 2wd trucks the A833 is a perfect choice IF you can find them and for the 88-98 era the T56 is a good choice as well. |
#3485 |
Post Whore
Re: Restoring Rusty
so after looking for one for over a year, sure missing a good deal here and there, you know how that goes, you hesitate to pull the trigger than you wish you had - I finally found one, the guy wanted $950 for it and would not budge on the price (I know I tried to negotiate, honest I did, I'm not made of money)
but to sweeten the deal and justify the cost he inclduded / threw in the following 1. The HURST shifter and linkage (later we found out one rod was missing, and the threads on the stick were broken) |
#3486 | |
Re: Restoring Rusty
#3487 |
Post Whore
Re: Restoring Rusty
Honestly, cause I'm not that smart, but I'm learning, and wouldn't that effect my gitty up, in other words if I put in highway gears in the diff to cruise at 75 MPH at about 2500 RPM wouldn't my truck be slower off the line, yet with an overdrive trans I get the best of both worlds a "quick" and I use that term loosely, LOL truck off the line and a happy truck on the freeway
#3488 |
Post Whore
Re: Restoring Rusty
so The Greg began cleaning the parts for the new transmission, starting with the new cross member, I have not pulled out my old cross member yet for a stare and compare but I think they is different
the new one I think is multi talented in that it (I'm taking a guess here) can support the TH350 Trubo 350 automatic as well as the 833 manual, correct me if I am wrong, I think it is also rubber mounted, oh yeah this is where I tell you the donor truck was a 1984 supposedly (I never saw it) |
#3489 |
Post Whore
Re: Restoring Rusty
and into the paint booth it went, actually used POR15 on this baby for durability, I like painting things with a brush, need to do that more, spraying wastes a lot more prodcut
#3490 | |
Re: Restoring Rusty
http://sfbay.craigslist.org/eby/pts/5513697175.html At one time I really wanted to convert mine over to a 4 spd. But not a truck 4 spd. being a big block only one 4 spd. would do me. The rare and disgustingly expensive M22 rock-crusher. I finally decided that a built TH400 would do me.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
#3491 | |
Re: Restoring Rusty
#3492 |
Post Whore
Re: Restoring Rusty
the transmission bracket that goes between the transmission and the crossmember looks different than the one for the SM465 granny gear Muncie, slightly different, they both attach to the trans with two bolts and that top part matches, but the bottom is different the Muncie attaches with two bolts, the 833 uses just one
top Muncie bracket bottom 833 bracket keep in mind I have not done this swap yet, I am in the process so if I state or make any mistakes, please correct me |
#3493 | |
Post Whore
Re: Restoring Rusty
and I was just in the Bay yesterday dang it |
#3494 | |
Re: Restoring Rusty
#3495 | |
Re: Restoring Rusty
#3496 |
Post Whore
Re: Restoring Rusty
alright lets see these beauties side by side
833 on top Muncie on bottom |
#3497 |
Post Whore
Re: Restoring Rusty
are you saying it may work with my old Muncie crossmember? this one with that big drop in the middle?
#3498 |
Post Whore
Re: Restoring Rusty
I think I am going to use the new bell housing just because I don't like the pointy Bermuda triangle in my old one, it just gets in the way, no idea what it's for
plus since both the bell and the trans have the dual bolt patterns I may put in a few extra bolts just for good measure, to control that torque monster, ha ha |
#3499 |
Re: Restoring Rusty
Looking at your photos...... Yes it appears you could. the 833 member bolts to the bottom of the frame rails and the Muncie obviously bolts to the top. if you look closely you will see your frame has extra cross member holes in it for the many different trans options. Also the 833 member bolts to the underside of the rail flange
#3500 |
Post Whore
Re: Restoring Rusty
OK, that makes sense. But wait a minute. The seller said his boys were going to convert an automatic 4x4 truck to the 833 manual, and I pulled this crossmember off of the 4x4 automatic truck not quite understanding what the dad was telling me I was just grabbing what ever parts he was willing to part with. So maybe this crossmember will work with my trans, or maybe I didn't even need it.
One thing I just learned looking at my old pics of my crossmember, is that mine is mounted high to the top frame rail ie C channel where as the new crossmember I believe was mounted down low to the bottom of the frame rail C channel. |
