#3501 |
Re: PO has me PO'd
![]() Still needs a bit of polish, but roughly done The saga goes like this! My attempt went like this FAILED @ rebuilding the vent windows Wrong ds gasket installed on ps gasket Had window surround chrome done Bought SS U channel but original has a swage at top to fit in door frame
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-09-2023 at 08:55 AM. |
#3502 |
Re: PO has me PO'd
![]() Install complete, going to open for first-time, NOPE should have lubed, before installing Got the oil can pump and doses it liberally, Today squeakie crusty crunchy sound, continued on watching hinge, aliitte more pressure And it. Snapped free
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#3503 |
![]() Join Date: Mar 2011
Re: PO has me PO'd
[quote=jaros44sr;9195196]
![]() Install complete, going to open for first-time, NOPE should have lubed, before installing Got the oil can pump and doses it liberally, Today squeakie crusty crunchy sound, continued on watching hinge, aliitte more pressure And it. Snapped free[/quote] jeez Jim I was going to take a shot a rebuilding mine but im chicken ![]()
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3504 |
Re: PO has me PO'd
Snapped free as in functions correctly now? Or snapped free from some where it was supposed to be attched to?
#3505 |
Re: PO has me PO'd
If there is such a good thing as a SNAP, I think it was the cam and spring on the post freeing up
But I was concerned that the hinge was going to twist off, so my focus was on the hinge Jesse, the whole process of rebuilding them isn't difficult, I just lost one of the parts. It was called FOCUS I picked this one for 15.00, on our boards, and now I have a sample to go by I'll revisit this at a later date, for now I have lots of other stuff to do Thanks for stopping by guys, encouraging to see someone actually reads this ![]()
#3506 |
![]() Join Date: Aug 2007
Re: PO has me PO'd
Hey Jim, I plan to rebuild my vent windows also, thanks for letting me know how you have done yours. I will check the bottom spring assembly.
Just for the fun of it |
#3507 | |
Re: PO has me PO'd
Your truck looks amazing, thanks for posting up. I always enjoy your posts
#3508 |
Re: PO has me PO'd
Today I was looking at the vent window and noticed a haze on it,
Windex didn't touch it nor carb cleaner So I went extreme, OOOO x steel wool, took it right off ![]()
#3509 |
Re: PO has me PO'd
![]() Finished up with the vent window, of course I dropped one of special screws LOST
#3510 |
Re: PO has me PO'd
Never would have thought....rust in the vent windows
#3511 |
Re: PO has me PO'd
#3512 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: PO has me PO'd
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#3513 |
Re: PO has me PO'd
Thanks for the pics
![]() 10/32 starting tap OEM hole size I hate rivets
#3514 |
Re: PO has me PO'd
Cleco worked well foe the top bracket
#3515 |
Re: PO has me PO'd
![]() ![]() Drive head leaves a little to be desired, prefer hex drive and a little less counter sunk My trusty old ignition screw holder came thru again, probably one of the oldest in the box
#3516 |
Re: PO has me PO'd
Seems to be pretty solid so far, one more screw to install
#3517 |
Re: PO has me PO'd
Convinced I can bolt these back together used wire wheel on the Dremel to polish hinge bracket
DISCLAIMER Made in China Wear I protect ![]() Run at low RPMs
#3518 |
Re: PO has me PO'd
#3519 |
Re: PO has me PO'd
I may have found the key to installing vent window gasket
![]() ![]() Pushing down on the gasket at the top bracket seems to keep the gasket running in the channel, while pulling down on the gasket towards the bottom of the vent frame
#3520 |
Re: PO has me PO'd
This tool will save your fingers from cramping up
#3521 |
Re: PO has me PO'd
This area gets tricky as the bracket wants to pull the gasket out of the C channel
![]() Windex makes it slid better, but the trade off is that it also comes out of the channel easily
#3522 |
BlahBlahBlah
Re: PO has me PO'd
Taking notes on your vent window build ... good info.
#3523 |
Re: PO has me PO'd
Thanks CG will keep that in mind as I progress, nice to know and thanks for stopping by
Found this on a shelf, light 100 grit sand and go buy some semi gloss paint ![]() Now I can fill the hole in around my Lokar shifter
#3524 |
Re: PO has me PO'd
Highlight of my day...watching paint dry
![]() Part number 3991945 shifter boot Bought this off the parts board many years ago
#3525 |
Re: PO has me PO'd
![]() ![]() Trying to figure out a way to wrap my ancillary tube
