Old 02-15-2024, 10:20 PM   #3526
Wikid61
Wikid61's Avatar
Re: Facebook classifieds finds
https://www.facebook.com/marketplace...2111112l%22%7D 15X8 CHEVY TRUCK 6 LUG RALLY WHEELS
$750
Listed 4 days ago in Summerdale, AL
Door pickup
Wikid61 is offline   Reply With Quote
Old 02-15-2024, 10:42 PM   #3527
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-6f618a20d3aa 1964 Chevrolet panel C30
$2,000
Listed 3 days ago in Klamath Falls, OR
Old 02-16-2024, 11:15 AM   #3528
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks
Old 02-16-2024, 11:17 AM   #3529
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1966 rat rod C10 tiny house
$15,000
Listed a day ago in Modesto, CA
Old 02-16-2024, 11:30 AM   #3530
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 1966 Chevrolet m30
$5,000
Listed 3 weeks ago in Grass Valley, CA
Old 02-16-2024, 11:37 AM   #3531
Wikid61
Wikid61's Avatar
c10 shortbed
$1,000
Listed 11 hours ago in Lodi, CA https://www.facebook.com/marketplace...2111112l%22%7D
Old 02-16-2024, 11:40 AM   #3532
Wikid61
Wikid61's Avatar
61-64 c10 trucks
$10,000
Listed 3 weeks ago in Twin Falls, ID
Public meetup
Door pickup or dropoff
Details
Condition
Used - Good
64is bbc th400 about done runs and drives 63 inline 6 4 speed runs and dives 62 has the Original V6 And standard transmission Not running And 65 with a 350 and Turbo 400. Not running atm the 61 engine but I have one
Old 02-16-2024, 11:45 AM   #3533
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 1960 Chevy C10 Wheels and Tires
$800
Listed 5 days ago in Sacramento, CA
Details
Condition
Used - like new
Great condition Chevy C10 wheels with Wild Peak tires which have only 2000 miles on them. One tire has a nail repair. There is a fifth wheels and tire. Came off of my 1960 C10. Includes beauty rings and center caps.
Old 02-16-2024, 11:51 AM   #3534
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 1966 Chevy Suburban
$38,000$42,000 · In stock
Listed in Madera, CA
Details
Condition
Used - Good
1966 Suburban –
California Title Current Non-Op
Matching Vin Numbers ~ Frame & Body
Torque Thrust 2 Wheels
VN515-8873 American Racing 18x8
VN515-2173 American Racing 20x10
Nitto NT 555 G2 Tires
245/45-18 Nitto Tires NT555G2
295/45-20 Nitto Tires NT555G2
4 WHEEL DISC BRAKES
140-11290F Wilwood (2) Front 2-Piston
140-11290R Wilwood (2) Rear 2-Piston
150-8939K Wilwood (4) BP-10 Ceramic
D52-RDB Captain Fab Rear Axle DB Kit
ECE-RDS-5 ECE Brakes 1.25 Rotors DR/SL
6.2 LS376/480 - 495 HP
GM Performance ECM / Engine Harness
GM Performance LS Muscle Car Oil Pan Kit
GM Performance Corvette Accessory Drive Kit
Corvette Fuel Rail Covers
GM Performance T-56 Super Magnum 6-Speed
GM Performance T-56 Trans Installation Kit
GM12B 12-Bolt Posi 373Gears
304GM Kentrol 304GM-12TR Stainless Cover
LLR-G012 Lube Locker GM 12-Bolt Diff Kit
D52-RDB Captain Fab Wilwood D52 R-Disc Brake Kit
BK-05 Caps Coating Chassis Black by Caps
Built & Assembled by Fearless Gears in Fresno, Ca, Narrowed
3”, Moser 5-lug Axles, Mini Pinion Kit, Seals & Bearings,
Powder Coated by Caps Powder coating BK-05
1966 Suburban Chassis
BellTech 3” Drop Spindles HD 1.25 Rotors
ECE 2” Drop Front Coils V-8
ECE Disc Brake Conversion Kit
Wilwood Front 2-Piston Brake Calipers
Hotchkis Steel Tie Rod Sleeves
ECE Front 1.25” Sway Bar Kit
M64-66KT Moog Front Suspension Rebuild Kit
ECE Front Steering Assembly Kit
ECE Power Steering Mounting Bracket
ECE Power Steering Gearbox (Quick Ratio)
ECE 63-72 Heavy Duty Trailing Arm Kit
ECE 63-72 Trailing Arm Air Bag Kit
Hotchkis 63-72 Rear Sway Bar C10 Blade Type
ECE Super Rear Track Bar Kit
ECE Rear Shock Mount Re-Locator Kit
Belltech Street Performance Nitro Shocks
Classic Perf. 3” Rear HD C-Notch Kit Classic Perf. Front Shock Support Brackets FSRB
ECE TAX Extreem Drop Center Crossmember
ECE TXPC Tremec 6-Speed Crossmember
ECE Rear Frame Crossmember
ECE LS Motor Mount/Frame Mount Kit
Powder Coated Chassis, Upper/Lower Arms/ Sway Bars, Etc.
Miscellaneous Parts
Prothane Body Mounting Kit
Direct Sheet Metal Transmission Tunnel
64-66 C10-SS Rick’s Tanks Stainless EFI 26G Tank
IDIDIT 35” FS Fl-Shift Steering Column
OER 64-66 C10 Chrome Truck Grill
Tanks Inc. High Flo EFI Fuel Pump
60-66 PBBHC Captain Fab Power Brake Booster Brk.
60-66 PBBHC Captain Fab Wilwood HY. Clutch Kit
Powder Coated Core Support & Inner Fenders, Chassis Black
Factory Front Seat Frames & Springs
Factory 3erd. Row Seat Frames & Springs
Front Stock White Bumper
All Window Frames With Sliding First Row
Mandrel Bent 2.5” Exhaust
11226 Magnaflow Performance Mufflers
2.50FL AZ CNC Manuf 2.50” Flange Set
V-Band Marman Clamps Stainless Turbo Clamps VB
GM Perf. Camaro Exhaust Manifolds
Complete exhaust is HPC Cerma Coated by Caps Powder
Coating.
$30k+ in receipts
NOT RUNNING!
Located in Central California
I’m sure I’m missing something.
Old 02-16-2024, 12:05 PM   #3535
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...5-bc16e7ee8d7d
1966 Chevrolet classic
$1,234
Listed 2 days ago in Brownsville, CA
Old 02-16-2024, 12:08 PM   #3536
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...9-00445b5b23a3 1965 Chevrolet 2500 regular cab & chassis Same
$15,000
Listed 15 weeks ago in Oroville, CA
Old 02-16-2024, 12:10 PM   #3537
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...9-00445b5b23a3 1962 GMC 2500 regular cab & chassis 132" WB
$1,600
Listed 5 weeks ago in Grants Pass, OR
Old 02-16-2024, 12:12 PM   #3538
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...9-00445b5b23a3 1962 Chevrolet silverado (classic) 1500 regular cab
$8,000
Listed 20 weeks ago in Elk Grove, CA
Old 02-16-2024, 12:59 PM   #3539
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...9-00445b5b23a3 1961 Chevrolet 2500 regular cab
$6,000
Listed 19 weeks ago in Janesville, CA
Old 02-16-2024, 01:16 PM   #3540
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D Aluminum slot mags
$225 · In stock
Listed in South Beloit, IL
Details
Condition
Used - Good
Two 14x7 and two 15x10 aluminum slot wheels, 6x5.5 bolt pattern. In good condition, just need to be cleaned. $225 obo
Old 02-16-2024, 01:17 PM   #3541
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 15" steelies with white walls 6x5.5 Chevy c10
$1,200
Listed 23 hours ago in Watertown, MN
Old 02-16-2024, 01:24 PM   #3542
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 16×7 Vintage chevy truck rims- chrome. call my number. Russell. [hidden information]
$300
Listed 4 days ago in Panora, IA
Public meetup
Details
Condition
Used - Good
Chevy truck rims chrome come off a 1979 GMC pickup they've been in storage for the last 35 years
Panora, IA
Location is approximate
Seller information
Gardner Russell
Joined Facebook in 2023
Sponsored
Old 02-16-2024, 01:29 PM   #3543
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2111112l%22%7D 6x5.5 wheels
$950
Listed 2 days ago in Reedsville, WI
Details
Condition
Used - Good
15x10 American racing wheels with Firestone tires, 33x12.50-15 with good tread remaining also comes with new center caps and lug nuts
Old 02-16-2024, 01:34 PM   #3544
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...9-63dadb51eb3a 1966 Chevrolet 2500 regular cab
$6,200
Listed 2 days ago in Ponca, NE
Old 02-16-2024, 01:36 PM   #3545
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb 1962 Chevrolet short box Deluxe
$1,500
Listed a week ago in St Cloud, MN
Old 02-16-2024, 01:41 PM   #3546
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb https://www.facebook.com/marketplace...a15aa233bb1966 GMC 2500 regular cab Long Bed
$3,200
Listed 6 days ago in Gilby, ND
Old 02-16-2024, 01:45 PM   #3547
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb 1961 Chevrolet chevy van g10
$1
Listed a week ago in Gering, NE
Old 02-16-2024, 01:48 PM   #3548
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb 1964 Chevrolet silverado 1500 Pickup 2D 8 ft
$7,500
Listed 6 days ago in Hampton, IL
Old 02-16-2024, 01:49 PM   #3549
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb https://www.facebook.com/marketplace...d-7ca15aa233bb 1962 GMC suburban 1500
$12,500
Listed 2 weeks ago in Osakis, MN
Old 02-16-2024, 02:01 PM   #3550
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-7ca15aa233bb 1963 Chevrolet 1500 regular cab Custom deluxe
$10,000
Listed 6 weeks ago in Oak Grove, MO
