01-22-2023, 07:09 PM | #3551 |
At the body shop.
Re: What did you do to your truck today.The 3rd chapter
Set plug gap and timing in my brother's 56
After new HEI install.
" That didnt make it any newer " " Dont antique the equipment " |
01-24-2023, 06:12 PM | #3552 |
Picked up my seat back from the upholstery shop . Did not like the way it was made at all . Didn’t fit right cut wrong and had the sail pieces to cover the side bracket’s like 69 and up . The owner of the shop I had met at a couple of shows and this is the first time I used his services. Very fast turn around dropped of Thursday was done Monday morning very reasonable too . Had him add some of the original seat skin to the bottom of the seat so it wrapped around like the original . He also cut the sail piece and restitched the piping to give it a finished look around the hinge . As you can see in the second picture the whole bottom of the seatback was open . Third picture it wraps around like original
01-24-2023, 06:20 PM | #3553 |
Stumbled upon an original 67 right front fender today too . And the price was right .
01-24-2023, 10:02 PM | #3554 |
Seat is not good . The pleats running from left to right on the seat back are short . There are 10 pleats per panel each pleat is 2.125 inches on the seat bottom it is exact on both sides .
The seat back however has 8 pleats per panel at 2.125 the other two outer ones are 1.862 Also the center panel in the seat back is 8 3/8 inches while the seat bottom is 8 1/2 inches. So the run lost just about an inch when you get to the drivers side . I’m just going to have to live with it since even my upholstery guy said he can’t match the color . PUI doesn’t even offer it anymore
01-25-2023, 11:59 AM | #3555 |
Upgrading hardware on the C10
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-25-2023, 01:18 PM | #3556 |
Shiny
01-28-2023, 09:15 PM | #3557 |
I like the bling where can I get some?
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-28-2023, 09:20 PM | #3558 |
Went to my pops’ house to help him with some things he couldn’t do. We needed to go to the hardware store so decided to take Maynard for a hardware store run.
01-28-2023, 09:29 PM | #3559 |
fix my baffle for the a/c vents and dash/floor vent. And clean 50 years of crud inside.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
01-29-2023, 12:44 AM | #3560 |
70+ ( Old Skool Club )
The fellow working on my truck got lots done on the front end today.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-29-2023, 08:57 AM | #3561 |
Location: Herculaneum MO (20 minutes south of St. Louis
Finished installing the rebuilt transmission in the wife's 72 last night. All good now, works better now than it has since she has owned it. Transmission shop turned it out in 3 days for me. That's a lot better than the end of February which is what they had told me it would be if I waited for them to do the r&r for me.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
01-29-2023, 01:20 PM | #3562 |
At the body shop.
Does using 68-72 parts in your 73 count?
Local upholstery shop made a notch for the visor clips. Floppy squarebody visors no more.
01-30-2023, 02:58 PM | #3563 |
Put together some new wiper arms for the 70. Used the "J-hook" portion of some 2002 Silverado wiper arms, then drilled out the rivets on a spare set of original arms. Adjusted the arm length in the older base sections. drill and added stainless screws to hold them in place. Painted them up, then put on a new set of 15" blades. I had done something like this on my older 66 since it was so hard to find blade refills for the old style that would stay on the arms.
01-30-2023, 04:25 PM | #3564 |
Who Changed This?
Looking good! I had to order a pair of wiper blades from my local NAPA, and they had to match pictures, as nothing was listed for a '70. Weird.
01-30-2023, 04:32 PM | #3565 |
Yep that was the issue I was having. And if I happened to find one, it was the cheaper plastic ones that broke or popped off the first usage.
01-30-2023, 06:23 PM | #3566 |
I bought what I needed right here: https://www.lgbilletusa.com/
They all took a ride on the buffing wheel before installation..
01-30-2023, 10:56 PM | #3567 | ||
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
01-30-2023, 11:32 PM | #3568 |
No reason to buy new on a 71k mile truck - clean/restore all the pedals. 50 years of gunk nearly as hard as cement on the accelerator. I used dental tool equivalent to get all out. Polished the brightwork and reinstalled. In all, about a 2-3 hour project with a lot of elbow grease.
01-31-2023, 12:35 AM | #3569 | |
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
01-31-2023, 11:47 AM | #3570 |
Started upgrading some hose clamps
01-31-2023, 06:10 PM | #3571 |
Those look like aircraft hose clamps. Do they have tiny holes thru the nut for safety wire?
01-31-2023, 08:57 PM | #3572 |
Like those . Most t clamps arent as detailed I use them on my dodge turbo hoses but they look industrial . What brand are they ?
02-02-2023, 02:00 PM | #3573 |
Installed my revised mini tach in over the weekend.
02-02-2023, 03:10 PM | #3574 |
HPS performance is the go-to for most on these T Bolt Clamps. I found these on Amazon, but not sure of the manufacturer. They we a bit nicer looking. They are unbelievably tight - should be a good upgrade from hose clamps.
02-02-2023, 03:12 PM | #3575 |
They do not - but following a friend's advice, I covered the protruding threads and nuts with rubber vacuum port caps for a little better appearance.
