#3551 |
Post Whore
![]() Join Date: Aug 2013
Re: Post Your Craigslist Finds Part 2
https://tulsa.craigslist.org/cto/d/s...678098310.html 1969 Chevrolet C-10 Short Bed Truck
350 Chevrolet Small Block Rebuilt around 500 miles ago Turbo 350 Transmission Power Steering Disc Brakes Very cool patina! Original factory paint New Exhaust New Aluminum Radiator Front End Rebuilt New Body Mount Bushings and Pads Started out as a long bed but only frame has been shortened Bed is original Short Bed Interior very nice New Carpet and Scuff Plates Seat is like new New Dash Pad and Gauge Panel New Bumpers both Front and Rear Body and Cab Supports Excellent Only minor rust New Tires, Wheels and Poverty Caps Bed Floor original and excellent Static Lowered with Spindles and Springs All Lights work as they should Wipers and Speedo and Heater Works This Truck Runs and Drives like a Dream! I would drive this truck anywhere! Very Dependable! |
#3552 |
Post Whore
https://austin.craigslist.org/cto/d/...677673847.html -2wd
-ORIGINAL V6 305. Yes I meant V6 (Almost sounds like a v8) these motors last forever. Link for video- https://youtu.be/eIUUWcxVv-M?si=0ixFoGGG2TA3H4km The transmission has been upgraded to a NP833 4speed . Manual steering and manual brakes . The rear brakes were redone a while back. It can be driven daily. ALL original sheet metal and very straight with minimal rust. Excellent patina truck. Everything works as it should. It has had the seats , carpet, sunvisors, door panels, gas tank, and some weatherstripping replaced recently. Its also had the exhaust and the Rear End replaced awhile back from the previous owner. Clear Texas title. Located in a Austin, Tx Runs great Thank you ![]() Call or text 5 1 2 - 8 two 6 - 7 six six 3 |
#3553 |
Post Whore
Hard to find classic 1968 GMC 1500 Custom Long Bed Pickup. Incredible opportunity for a non-running restoration project! Unused and covered last 25yrs. Make this a fun daily driver or restore to it’s original beauty & glory..
V8, 327ci 4 speed manual transmission 82,287 original miles 2 wheel drive do NOT contact me with unsolicited services or offers https://kalispell.craigslist.org/cto...676172800.html |
#3554 |
Post Whore
This is a factory original 68 C10 fleet side short bed. Painted last year metallic green. Has a strong running
350 engine with an automatic transmission with the shifter on the floor. Has power steering. Has no rust or dents. Has bench gray cloth seat. The wheels and tires are 18 inch in great condition with low miles. All the glass is good. Both windows roll up and done. Very dependable daily driver that gets a lot of attention. This awesome truck is about 90% finished. I only drive this classic 68 on nice days. Gets a lot of attention and thumbs up. It is a blast to drive. Call me at show contact info and I will answer all your questions. Yes I have clean idaho title in my name. do NOT contact me with unsolicited services or offers https://boise.craigslist.org/cto/d/m...675489413.html |
#3555 |
Post Whore
https://kpr.craigslist.org/cto/d/ken...673246115.html 1968 C20 Chevy Pick up
3/4 ton, 2 wheel drive TH 400 transmission No engine Rusty floors at rockers Rusty rockers Clean Idaho title You pick up in Rathdrum ID $3,000 Text two08-7one9-672one (Delivery available within 4 hours of Rathdrum ID for a fee) Thanks for looking |
#3556 |
Post Whore
https://stcloud.craigslist.org/cto/d...678312374.html Blue 1970 K5 Blazer. Automatic transmission, 4 wheel drive, V8 engine. Runs, drives, stops and transmission brake works. Mostly stock, with cherry bombs mufflers on it. One cylinder has low compression and engine will need overhaul. Transmission shifts fine. No windshield, front quarter panels look good, 1 spot on the right needs repair, rear quarter panels need attention for sure. Will need front and rear floor pans as well as door skins and full interior. Front seat is not original seat, nor is it bolted down. I just threw it in there to drive it around. Top needs misc. fiberglass work but overall in good shape, no cracks in the glass.
Owned 1 year and purchased from Utah currently residing at my Minnesota home, with an open Utah title. First few #'s and letters on the VIN are KE180S15####. 28k miles on the odometer likely rolled over but no way to confirm. I bought 3 K5 blazers as a package deal and selling 2 of them off. The only thing that was done under my ownership is have a mechanic check the engine and transmission over and top off fluids. Email me with questions. Or call or text Jon 320828seven-three-lO 1968 1969 1970 1971 1972 Chevrolet GMC jimmy shorted c10 |
#3557 |
Post Whore
https://huntsville.craigslist.org/ct...674403282.html I built this truck to look like a 1968. It has a 1969 cab and frame, so it is registered as a 1969. It has a 68’ 327, Turbo 400, AC, PS, class IV hitch, factory tachometer and power disk brakes. New tires, new heater core and new front brake pads. The front bumper and most trim has been shaved and filled. The suspension has been modified with Bell Tech spindles, rear coils and relocated pan hard bar. The bed has been lined with Line-X. I also installed a 2001 Dodge truck seat with integrated seat belts. The engine and transmission were rebuilt during the truck build which was finished in 2005. I have driven the truck approximately 80k miles. It does have few oil leaks. But overall it’s dependable fun truck to drive. Bill of sale only due to Alabama age limit.
do NOT contact me with unsolicited services or offers |
#3558 |
Post Whore
https://dallas.craigslist.org/dal/ct...678919261.html It is a 1969 gmc c15 heavy half ton, it’s got a 350 sbc with 4 bold main, th400 trans, 12 bolt rear end with I believe it’s got 3.55 gear ratio. It is a project truck that is mostly numbers matching. I have a few spare parts and a few new parts I don’t really want to sell her but due to recent life events I could use the money to help with that so I have decided to test the water a little bit, the glove box door still has the build sheet and I have the owners manual for it a long with the title. I am the second owner and am looking to get $6500 cash for it but am open to offers
#3559 |
Post Whore
https://albuquerque.craigslist.org/c...678623183.html A timeless 1969 Chevy Truck with a powerful 350 engine that breathes through a custom dual exhaust. Classic Mint Green original paint makes it authentic and unique, and also has a new wiring harness on the instrument panel, a lockable Weather Guard tool box in the long bed of the truck. Simply need the space and need to sell. Feel free to contact me with any additional questions.
#3560 |
Post Whore
https://minneapolis.craigslist.org/d...676767474.html Old skool Truck fresh 5.7 4 bolt, 400 turbo.org from Colorado w/96.000 mi disk brake conversion. ready to work or play. Scammers ____ off cash only thanks!
#3561 |
Post Whore
https://pueblo.craigslist.org/cto/d/...676336393.html 1969 c10 , Great Patina , 350, turbo 350 Trans , new Aluminum Radiator , edlebrock intake Edlebrock carb , New Tires , Truck runs great and looks great , asking 9,999 OBO Has Clean NM title in my Name , might trade with Cash on Top ,
505-803-290ZER0 |
#3562 |
Post Whore
RUST FREE. 1969 CMC CUSTOM CAMPER. FACTORY 396. FACTORY A/C. THIS IS A VERY SOLID TRUCK. ROCKERS, CAB CORNERS AND ALL SHEET METAL ORIGINAL AND RUST FREE. VERY MINIMAL BODY WORK NEEDED. RUNS AND DRIVES GOOD. 3 GAS TANKS. ALL GLASS IS GOOD. HEADERS WITH NICE SOUNDING GLASS PACKS GREAT FOR RESTORATION PROJECT. $13,000 OBO
I HAVE A FULL VIDEO SHOWING THE UNDERSIDE !! iT IS TOO LARGE FORMAT FOR HERE. ICAN EMAIL IT !! LOCATED IN DYER NEVADA !!! CLEAN TITLE IN MY NAME !!!! FEEL FREE TO CONTACT ME FOR MORE INFO !! https://lasvegas.craigslist.org/cto/...675973955.html |
#3563 |
Post Whore
https://lasvegas.craigslist.org/cto/...674606235.html Are you ready to own a piece of automotive history that's been taken to the next level? Look no further! We're excited to offer this stunning 1969 Chevrolet C-10 Restomod for sale - a true masterpiece of craftsmanship and power.
Key Features: Powerhouse Engine: Under the hood lies a beastly LS1 5.7L, with Kenny Bell supercharger that roars to life with exhilarating power. You'll feel the adrenaline rush every time you hit the gas pedal. Smooth Shifting: The 4L60 automatic transmission ensures seamless gear changes, allowing you to enjoy every moment behind the wheel. Modern Comfort: Stay cool and comfortable with the integrated Air Conditioning, making cruising in any weather a breeze. Suspension Excellence: The Accuair Air ride guarantees a smooth and controlled ride, while the custom billet wheels add a touch of elegance and class. Reliable Handling: Power steering ensures effortless maneuvering, and now with power brakes, you can confidently bring this beauty to a stop with ease. Sound Sensation: The custom sound system will take your driving experience to the next level. Crank up your favorite tunes and enjoy crystal-clear audio quality. Enhanced Performance: This C-10 comes equipped with electric cut outs for the exhaust, giving you the option to unleash the full power and growl of that Supercharged engine whenever you desire. Reliable Handling: Power steering and power brakes ensure that you maintain full control of this beautiful machine. Cooling Efficiency: The Be Cool radiator keeps the engine running at optimal temperatures, ensuring longevity and performance. Added Boost: The Kenny Bell Supercharger takes the already impressive LS1 to new heights, providing exhilarating acceleration and power on demand. Fuel Efficiency: A new aluminum fuel cell with all new lines and AN fittings ensures efficient and reliable fuel delivery. This 1969 Chevrolet C-10 Restomod is a showstopper and a true head-turner. Whether you're taking it to car shows, enjoying weekend drives, or simply admiring it in your garage, this truck is a must-see for anyone who appreciates automotive excellence. Important Note: We want to ensure that you're fully satisfied with your purchase. The responsibility for inspecting the vehicle, either personally or through a third party, to assess its condition and value prior to purchase rests with the buyer. Please note that mileage is undocumented. Don't miss out on the opportunity to own this meticulously crafted 1969 Chevrolet C-10 Restomod. Contact us today to arrange a viewing and experience the thrill of owning this automotive masterpiece. Act fast - this gem won't stay on the market for long! |
#3564 |
Post Whore
https://knoxville.craigslist.org/cto...674496319.html 1969 gmc original short bed,350 engine 350 automatic,it does have some rust but make a good start to a build or leave it,needs tires
#3565 |
Post Whore
https://milwaukee.craigslist.org/cto...673525840.html 1969 Chevy c10 2wd short bed step side. 54000 miles. 6cyl 250. Manual 4 speed. Southern truck. Now titled in Wi. Heater delete. All lights and gauges work. Runs and drives perfectly. Manual steering and breaks. 414 three zero five 1221
#3566 |
Post Whore
https://orangecounty.craigslist.org/...681089671.html Built in Los Angeles. Mist Green with white strips. 350 Strong engine, 12 bolt rear end with 373 gears, electronic ignition, factory front disk, and rear drum breaks. Fresh new paint, new vintage air conditioner, spray in bed liner, new windshield and many new original equipment parts. Included and 15 inch rally wheels with Chevy dog dish hub caps. I don’t need help selling and if the add is still up it’s still for sale. All original sheet metal and you won’t be disappointed.
#3567 |
Post Whore
https://spokane.craigslist.org/cto/d...680455827.html 1970, Chevy Pickup Truck / Classic Christmas Tree Hauler!
Road Ready, with Tow Package. Runs Great! C20 934 / V8 / 3/4 Ton / Dual Pipes / Manual, 4 speed Transmission /rebuilt 350 cuin / 2555hp / 4 bbl / 34,767 mi / Original Instructions Manual Clean Title. Current Tabs and Insured. Come check it out! $18995. Cash, In Person. Get Me close, got $22000 into it, Call with Questions and/or test Drive! Great Christmas Present! |
#3568 |
Post Whore
https://phoenix.craigslist.org/cph/c...674311134.html Hard to find (big hub)1970 Chevy C20 4x4 3500 for sale. This truck is a original 3500 8 lug 4x4 4 speed manual transmission truck. The truck starts right up and runs great. The truck has a 350 Engine, new rims and tires, new power booster and master cylinder, new fuel pump, new fuel sending unit and overhauled carburetor. The truck does run good and drives nicely down the road. This truck is a long bed and very hard to find original 3500 4x4. If you have any questions Call me @ show contact info thank you….. Note this truck is located in Albuquerque New Mexico and I do have a clean NM tittle on hand.
#3569 |
Post Whore
https://racine.craigslist.org/cto/d/...671248062.html I have a 1970 GMC C10. It has a fresh built 355 engine and transmission with over drive. New wheels, tires, rebuilt engine, rebuilt transmission, motor mounts, axle, new heater core, new heater, new dual exhaust, and new heater cluster. I also have a new brown leather seat cover in box I paid $400.00 for. I have a new rear bumper delete roll pan, I have original rear bumper, tail gate, new steering wheel, and inner door panels in boxes, too many parts to list, everything under the hood is new. Runs and drives great. Will consider trades. Looking for a ski boat. I need a car for my daughter. Honda, Lexus, Camry, Acura
#3570 |
Post Whore
https://kpr.craigslist.org/cto/d/mil...681422639.html Truck needs very little attention to be fully operational. This was a Camper Special. Originally a big block. Power steering, power brakes, air condition, cruise control. Catalac 500 engine runs well. Transmission is weak and needs to be replaced. NEW aluminum radiator. This can be a beauty once painted and operational. Body work complete on the bed. Entire truck body is straight and has NO RUST; only some surface rust (see photos). Dent free! I am the second owner and have had this since 1984.
SPID- VIN CEZ34-2116050 |
#3571 |
Post Whore
Barn Find! Parked since 2012 due to low engine compression and oil burning. 1971 Chevrolet Custom C-30 1 Ton Dually all original and complete. 350 V8 4 barrel 4 speed manual with hydraulic dump bed and factory front disc brakes. Replace or rebuild the engine and have a classic work truck or the basis for an awesome Rat Rod!
do NOT contact me with unsolicited services or offers https://albuquerque.craigslist.org/c...681673283.html |
#3572 |
Post Whore
https://springfieldil.craigslist.org...681241587.html 90 % original truck. Factory A/C (compressor starting to seize). 101,000 miles. Original 350/400 engine and transmission. I replaced the bed with T11 because I wanted to use the truck daily. It had a wood bed originally, but was in bad shape. Please send a text first to weed out spam. This number is backwards 0155-528-712
#3573 |
Post Whore
https://yakima.craigslist.org/cto/d/...679702073.html I have a 1971 3/4 Ton Green Chevy Pickup, Stick Shift-Not an Automatic, Duel Exaust, Three fuel tanks. Milage is 44,620. 2003 White Lance Lite Camper. Truck Runs Good, No Issues. Camper is exstremly clean and well maintained and in good condition. Has remote lifts. No Leaks! Bought brand new batteries. Tires have good tread on them.
Excellent Truck and Camper for the hunter, camper or outdoors person. $19,500 or best offer may be considered. Cash prefered! Serious inquiries only! Respond to this listing and I will setup a time to check out the truck & camper and give you my number to discuss it. |
#3574 |
Post Whore
https://denver.craigslist.org/cto/d/...678723456.html
Purchased my 1971 Chevrolet c30 form my Bosss three years ago after he had it sitting for 7 years. I finally convinced him into selling it to me. When I purchased it, I had to tow it to my home. The work I have done - I cleaned out the gas tank - put in a brand new carburetor - replaced the fuel pump This truck is a longhorn and it’s 6” longer than a long bed. The truck in the pictures has two set of rims on it. I have the full set of the tiers in the back, I may have the full set of the ones in the front but I would have to look for them. My boss put in a out of the crate Motor, and it sounds great. It was a project that I wanted to do but time has passed, and I haven’t been able to do it. If you are interested in the truck please call me to set up a time for you to come and take a look. My phone number is threezerothree-ninezeroone -4497 I am asking $6000.00 OBO. |
#3575 |
Post Whore
https://phoenix.craigslist.org/nph/c...678303332.html K5 Blazer, runs and drive good, 350, Automatic, 4x4, no top
Five zero five 486 35four6 $23,500 ---Located in Farmington NM--- |
