Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-29-2023, 09:12 AM   #3576
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I like to tape every couple inches, making sure the back of channel stays engaged, thats where the tape helps
Catching the channel pry down and push up on the tool, you'll see when you actually do it
Headlamp really helps to see
Don't let it out of your sight
16985850637243555851802622212635 by [url=https://www.flickr.com/photos/97391199@N06
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-01-2023, 09:39 AM   #3577
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ok stop at this point, and get the gasket over the L bracket
Helps to tape lower channel to avoid pulling gasket out of channel
16988456040303382952337659992035 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-01-2023, 07:42 PM   #3578
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
I see this is a tedious process need patience of a saint
zicc1835 is offline   Reply With Quote
Old 11-02-2023, 08:23 PM   #3579
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
ah yeah, I work on it awhile then put it aside
SAFETY FIRST
AS usual, off topic
Jim
Old 11-03-2023, 10:28 AM   #3580
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Had to blow my fender apart to get at the lower hinge bolts
Glad I did found alot of unfinished welds, and spider webs
16990213731915127837025528396484 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-05-2023, 10:11 AM   #3581
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thing is, this is just a trial run, see if I can do it.Not happy with the paint adhesion, chips easily
Wanted to ask you a couple questions about powder coat
SAFETY FIRST
AS usual, off topic
Jim
Old 11-05-2023, 09:12 PM   #3582
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
pm sent
Old 11-06-2023, 09:03 AM   #3583
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
pm sent
Sorry my mailbox was full, empty now
SAFETY FIRST
AS usual, off topic
Jim
Old 11-15-2023, 12:46 PM   #3584
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Any body remember this stuff in their trunk
17000666290934071350952786655852 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-16-2023, 12:22 AM   #3585
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Splatter paint. I remember it well.
low'n slow is offline   Reply With Quote
Old 11-16-2023, 09:36 AM   #3586
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I thought that is what it used to be called, had little specals of turquoise in it
Now krypton calls it stone course texture, obsidian
Have to check how strong it bonds to the metal, seems pretty good after drying for 2 days, have use the putty knife test
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2023, 09:15 AM   #3587
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Tough stuff, used to have this stuff in the trunk of my 62 Chevy, only it had turquoise speckled
17002261376286937009066607236262 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2023, 09:17 AM   #3588
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
17002269702037740125196384264484 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2023, 10:47 AM   #3589
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got the last 8 inches of the gasket installed, seems like Widex and pry tool best suited for the job
Seemed like method would replicate installing spline on screen door, but it didn't prove out to be any guicker then the pry bar, but but the finish on the frame failed, might have to go with plating
17002318377631316869095308798981 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2023, 11:27 AM   #3590
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
17002347099994462784109505353831 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-17-2023, 11:34 AM   #3591
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Some place in a desert climate should be a wind wing with this plating
1700235047741738472027850013897 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2023, 12:30 PM   #3592
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Today's debacle
17004974665266040844977846667718 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2023, 12:34 PM   #3593
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Vent window update
17004976415195996873084173219018 by [url=https://www.flickr.com/photos/97391199@N06
Adjust tension stud
SAFETY FIRST
AS usual, off topic
Jim
Old 11-21-2023, 11:24 AM   #3594
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Threads galled
Wonder what size it is?,303 OD have to check TPI, looks like 24
,278 at the threads
17005798249731050062899400830680 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 11-28-2023, 09:41 PM   #3595
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
17012154716626842701964752200098 by [url=https://www.flickr.com/photos/97391199@N06
The post on the right is a 5/16×24
Still trying to figure out the left post
They are symmetrical, meaning driver side to passenger side, if you remove latch handle and insert from other side of the glass
SAFETY FIRST
AS usual, off topic
Jim
Old 12-03-2023, 06:04 AM   #3596
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Total frustration over the last 3 days
Can't get the vent window to mount up to the. Frame and gasket
17015308650872776201514556474862 by [url=https://www.flickr.com/photos/97391199@N06
Only thing I can come up with is the angle of the mounting post
The second window seems to fit better but not perfect
SAFETY FIRST
AS usual, off topic
Jim
Old 12-04-2023, 08:34 PM   #3597
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Tears on my tablet
Today and tonight, my special son lays in the ICU, machines keeping him alive
Please pray for my son Jeremy
SAFETY FIRST
AS usual, off topic
Jim
Old 12-05-2023, 04:10 PM   #3598
JJH Jimmy
JJH Jimmy's Avatar
Re: PO has me PO'd
Sending prayers for your son.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 12-05-2023, 07:42 PM   #3599
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Tears on my tablet
our prayers are with Jeremy
Jess
Old 12-05-2023, 09:34 PM   #3600
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks guys, means alot
Outta my hands and into God's
Next 2 days will tell
SAFETY FIRST
AS usual, off topic
Jim
