Closed Thread
Old 07-06-2014, 01:16 AM   #3576
OrrieG
OrrieG's Avatar
Re: What Did You Do With Your Truck Today ?
More work on the bed sides, just minor stuff. Fleetside spears are really cool, but a PITA to get the ridge straight... Also hung the doors and got them close. Going to do the fenders before doing anymore adjusting. Did find the driver step sill installed high from the factory at the front so door gap at the bottom is off a little. BFH an sturdy oak block moved it a little. Not enough for me to worry about, it did fine for 25 years, next guy can get neurotic about it! Body lines are lining up fine which is what stands out the most.
OrrieG is offline
Old 07-06-2014, 02:32 PM   #3577
wayne4252004
wayne4252004's Avatar
Took the Newlyweds for a carriage ride.
wayne4252004 is offline
Old 07-06-2014, 11:10 PM   #3578
OrrieG
OrrieG's Avatar
I hung the front fender and looks like it is not the factory. The step is definately higher. I looked at old photos and it is not that high. I replaced that whole lower hinge pocket and from what I can tell from the photos when I welded it up it must have pulled the step up to fill the gap. I am going to cut the joint loose and infill to get it where I want. Will need to repaint that area (arghh) but no biggie. Lesson learned is to look REALLY CLOSE at how the door hangs while tacked, and during the final welding and brace to keep from moving. Passenger side is ok, I only had to replace a part of the hinge opening, not the piece below.
OrrieG is offline
Old 07-06-2014, 11:31 PM   #3579
Get Down
Get Down's Avatar
Got my seat in after having it redone! Not for everybody but I like it! photobucket.com/user/crime_inc/media/imagejpg2.jpg.html][/URL]
Get Down is offline
Old 07-08-2014, 12:10 AM   #3580
mechanixman
mechanixman's Avatar
Got the steering box mounted!!!!
-Nick
Projects:
1952 Chevy 1 ton = The Build page
mechanixman is offline
Old 07-08-2014, 12:58 AM   #3581
topdown99
topdown99's Avatar
i dig the seat! is that a rebuild original or out of something else?
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels
topdown99 is offline
Old 07-08-2014, 02:48 AM   #3582
BADAZ chevy guy
BADAZ chevy guy's Avatar
Am I missing something? With the steering box mounted on top of the frame rail, the arm will move up&down instead of side to side. What other linkage are you going to ad?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 07-08-2014, 07:01 AM   #3583
Get Down
Get Down's Avatar
Thanks. Yes it's a rebuild of the original seat that was in my truck!
Get Down is offline
Old 07-08-2014, 08:20 AM   #3584
maxdog51
maxdog51's Avatar
Knocking down 5 layers of paint from previous owners.
I made this silly looking rolling cab cart to make it easy moving the cab in and out of the garage.
maxdog51 is offline
Old 07-08-2014, 01:06 PM   #3585
Half Baked
Half Baked's Avatar
Seat looks killer man!
Cheers,
Chris
1951 Chevrolet 3100 Pick up
Half Baked is offline
Old 07-08-2014, 01:12 PM   #3586
Get Down
Get Down's Avatar
Thanks Half Baked appreciate that! I know this style isn't for everybody but it is getting a warm reception.
Get Down is offline
Old 07-08-2014, 04:46 PM   #3587
49tomchevy
Put wheels on to check fit. Finished door.
49tomchevy is offline
Old 07-08-2014, 09:49 PM   #3588
Dan in Pasadena
Dan in Pasadena's Avatar
I like the hell out of it. Ive been saving the below picture for a couple years now because I do. I'm not sure I WILL do it, but I'm sorely tempted...
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline
Old 07-08-2014, 11:16 PM   #3589
Get Down
Get Down's Avatar
Dan I seen the picture you posted in the past and I felt the same way, that's what inspired me to come up with my own design. I appreciate the kind words.
Get Down is offline
Old 07-09-2014, 11:59 AM   #3590
topdown99
topdown99's Avatar
I am headed to Mexico in November, I'll have to keep my eyes out for a new cover for my seat!
Old 07-09-2014, 04:17 PM   #3591
Russell Ashley
Russell Ashley's Avatar
I finished up my new front brake lines and bled them today. Got good pedal and was hoping to neighborhood-drive it today but didn't happen. Maybe tomorrow. I did find the best and least messiest way to add fluid to my CPP under floor master and maybe it will help someone. I impulse bought a five pack of these bottles at Harbour Frt a few years back. I put brake fluid in one, screwed the nozzle off, and stuck on the hose and it worked great. It's easy to top the mc off because the bottle doesn't deliver too much volume per squeeze of the trigger and the flow stops when you release it. I found it more controllable than a squeeze bottle with a hose on it.
BTW, the saddle blanket seats in the previous posts look good. I like them both.
Russell Ashley is offline
Old 07-09-2014, 05:59 PM   #3592
topdown99
topdown99's Avatar
Another great idea!
Old 07-09-2014, 07:23 PM   #3593
Daze57
Daze57's Avatar
good idea russell thanks for sharing
both seats look good !!!
Daze57 is offline
Old 07-09-2014, 11:32 PM   #3594
mechanixman
I just wanted to add in, i think that seat is REALLY sharp. Not only does it add a little color, but the fact that it looks like it's a part of the seat, and not some sloppy seat cover really adds to the fact. (although I like those covers too. Everything has their place)
Ha ha yeah that was the original pitman arm that I never quite took off all the way. I'm going to have the pitman arm vertical, with a drag link between the steering and pitman arms. It'll be real similar to the original system, except the box will be in front of the axle as opposed to behind.
-Nick
Projects:
Old 07-13-2014, 02:02 PM   #3595
OrrieG
OrrieG's Avatar
Cut the step loose and pushed it down, sill stayed level and parallel with the door bottom. Still needs welded and hammer and dolly work and door gap set but much closer.
OrrieG is offline
Old 07-13-2014, 06:26 PM   #3596
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Gave my 57 a facelift!!
ChuckDriver is offline
Old 07-13-2014, 07:04 PM   #3597
Softpatch
Softpatch's Avatar
My dad waited 38yrs to give me this wrench.!
I'm guessing he thought i was old enough not to distroy it...?
at least thats what i 'm thinking
I calling this....
" How many thing are just wrong with this scene"......
It is not lost on me
All 6 wheels are off and the truck is on jack stand/ assort, wood blox
in a dirt drive way on a hill
working on widow makers and surrounded by very dry grass no fire extingisher
about 2 feet away from a propane tank on one side Oxy/Acetylene set on the other
Busting my hump on a 50 yr old wrench with a 4ft cheeter
when will the fun stop.?
the rims got alittle hot
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 07-13-2014, 07:16 PM   #3598
Softpatch
Softpatch's Avatar
but in the end i had a vision and it all worked out for the day
No lives were lost
two wheel cylinders per wheel ..Means two adjusters
Old 07-13-2014, 07:22 PM   #3599
Russell Ashley
I like old tools and that lug wrench looks interesting to me. It's actually called a Shock wrench. Here's a link to a tool vendor that gives a little info about it. I first assumed that you hit the ends with a hammer to loosen the lugs but you just spin the arm and the weight of the ends acts like an impact wrench.
http://inlandvalleytoolsupply.com/ken-tool.pdf
Old 07-13-2014, 08:05 PM   #3600
Softpatch
Softpatch's Avatar
.thanks for the Tech info R.A..very interesting.
I did use a large hammer on it.
The wheels Nut's/studs have been soaking for days
but could not penetrate the wheel studs.
I even had to use heat to first take the lug nuts off then after no luck with a hammer and the "Kem Tool'
more heat and a large pipe wrench with a cheater bar & lots of heat
and my fat arse it finally broke loose
I'm beat up ..
Tomorow I'll take the shoe to be relined
......Sp
Closed Thread
