Old 04-16-2016, 03:26 AM   #3626
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
originally I thought the Turbo 350 driveshaft I got would not slip in to the tailshaft of the overdrive 833 transmission since the shaft was keyed but the tailshaft wasn't, but than I said now Greg don' be skierd try again, so I wiggled it a bit, stared at it for a minute than I stared inside it for a minute, and then I shoved her in
turns out the area that is keyed just skips a spline instead of having a wider spline, so that had no effect on the two mating
score that as a win!
Gregski is offline   Reply With Quote
Old 04-16-2016, 03:28 AM   #3627
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
dang it's passed midnight gentlemen, it's Saturday, so it's officially:
D Day!
Old 04-16-2016, 03:31 AM   #3628
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so lets get this Party started!
has anybody seen my nice black dress socks, anybody?
Old 04-16-2016, 03:33 AM   #3629
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I'm tired so I'll let the pictures do the talking
Old 04-16-2016, 03:34 AM   #3630
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I like this pic the most, it's like an assembly line
Old 04-16-2016, 03:36 AM   #3631
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
put the mosquito wheel on with some Blue (medium) loctite and torqued it down to "as hard as you can, plus a quarter turn" ha ha, jk 60ft lbs
Old 04-16-2016, 03:38 AM   #3632
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Check this guy out fellas, he is so [ahem] clutch!
Old 04-16-2016, 03:38 AM   #3633
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
that's it for me, good night everybody!
Old 04-16-2016, 09:02 AM   #3634
Rob C
Re: Restoring Rusty
So close!! Liking the 2.5 exhaust btw..Had it in my old truck too. I loved the sound. Let's everyone know your there
Rob C is offline   Reply With Quote
Old 04-16-2016, 11:35 AM   #3635
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
Originally Posted by rich weyand View Post
Huh. That's exactly what I have on mine, and it's fine with me.
That wasn't meant as a slam to anyone running that combo, FM sells a ton of those 40's every year I'm sure. But that was the loudest combo I've ever run by far, and even though I was in my 20's when I had it, it was was still embarrassing at times. Some people are obviously OK with it, to each his own. I don't think his wife and kids are going to like it. Especially with turn-downs.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-16-2016, 11:51 AM   #3636
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
An X or H pipe with 40 series and tail pipes straight out the back makes a lot less throbbing drone in the cab without the bends of side exit tails... just two 45 degree bends and straight out. The drone can get annoying on longer trips.
An H or X pipe will make a noticeable difference in the RPM range of your torque band and a pretty respectable jump in HP. http://www.superchevy.com/how-to/exh...for-your-ride/
You may end up wishing you opted for the 50 series. They are still pretty aggressive sounding when you get on it without as much throbbing running drone.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-16-2016, 12:10 PM   #3637
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
More on how and why the H and X pipes work and what they are useful for...
If I understand this correctly now... You can get rid of some of the offensive drone without killing the aggressive tone using an X or H pipe... Maybe somewhere between the 40 & 50 series running and still have the growl when you get in it. Maybe.
http://my350z.com/forum/intake-exhau...ml#post7111390
"There's a big misconception about the intended function of the X-Pipe versus the H-Pipe.
The H-Pipe does balance out the pressures and slightly helps start the scavange effect on the next exhaust pulse. But it's most effective use when properly placed and sized is for it's tuning function. Sound waves enter the tube changing to a specific frequency that was found to be a problem. Prehaps a droaning noise at highway speeds. With the correct placement in the system and correct inside diameter, sound waves entering the tub shift to the problem frequency. When like frequencies collide, they cancel.
The power comes from opening up the exhaust. A slight add comes from the scavenge effect but ultimately the H-pipe is to counter the noise from opening up the exhaust.
The X-Pipe on the other hand is more effective in sound cancellation. By forcing the exhaust streams to collide, some sound frequencies are cancelled. (In a much larger range than the H-Pipe.) You would think the two exhaust paths colliding would cause more backpressure. In reality, the exhaust flow mass follows the path down the same side. (Bending around the inside of the X.)
The sound frequencies cross paths of the exhaust. Cancellation of like frequencies occur even though the mass of the exhaust flow hits and deflects into the same side pipe.
This is all assuming WOT condition or near full mass flow rate. At lower flow rate, the X-pipe does make the low frequency idle sound a little irratic. Something desireable in a Mustang or Corvette. But a Cadillac wouldn't care for it.
This is used as a band aid in tuning high performance vehicles to meet the legal pass-by requirements. Something that is difficult to do on a car like the Viper Roadster or Corvette.
The X-pipe idea was tried on the Viper roadster but ultimately they used the H-pipe design. If you've ever seen the OE system on a Viper Roadster, the exhaust exits the headers, enters an un-Godly hot converter that I have seen damage body panels and melt basalt packing back into a crystal solid. It runs down the side of the car into the main muffler and then to the rear axle. Then it turns to the opposite side and hits the H-pipe which is over the axle and exits out before the axle on the opposite side of the car. If it were not for the Pass-By requirements, this would be an easy design.
Designs like this and the birth of the X-pipe all stem from the need to meet the requirement. Again, the X-pipe just allows the exhaust to be opened up more while tuning out undesireable frequencies. It's ability to "add" power is a debate most drawn up by aftermarket marketing managers. Everyone loves a gadget."
--- Quoted from the above linked post by User Phreakedout at the 350Z forum
Old 04-16-2016, 06:13 PM   #3638
Jeramy
Jeramy's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
so my first setback is that the rear U joints are of two different sizes, my old drive shaft spider cross thingie measures 1.063 in diameter, and the new donor drive shaft cross thingie is bigger at 1.129 so it won't could fit in the U joint or yoke what ever you call the thing in the differential
what ta do? what ta do?
can we switch caps? you know the ones that hold the roller bearings, maybe the tube inside there be of the same diameter
precision u joint part number 449
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 04-17-2016, 02:42 AM   #3639
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so the engine / transmission installation took 12 hours and started with us mating the New Process 833 overdrive transmission to the engine like so
no fluids, no motor oil in the engine, no transmission fluid in the transmission
Old 04-17-2016, 02:50 AM   #3640
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the hardest part of the physical install was the transmission crossmember, turns out I did not get the proper 833 crossmember but got a basic 4x4 one instead when I bought the transmission, so we ended up using my original Muncie SM465 crossmember, however to get it to work we had to move it forward about an inch and I think flip it front to back as the holes are a bit offset
so in other words the 833 transmission has the transmission bracket about 1 inch closer to the bellhousing than the Muncie its just off far enough so you can't just drill two new holes in the crossmember as it is only about 2 inches wide in the middle and the bolt heads would not fit
we also had to notch the floor sheet metal to make room for the shifter, more specifically the shifter bracket as it sits about 1 inch too far back to clear the natural opening cavity
Old 04-17-2016, 02:52 AM   #3641
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the engine getting installed...
Old 04-17-2016, 02:55 AM   #3642
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
the swan neck HURST shifter stick would not work as it would hit the dash when attempting to shift into 1st or 3rd gears, we even tried mounting it backwards, same problem
so we drilled some 3/8ths holes in the base of the generic stick that came with the shifter and mounted it up for the time being, but another HURST shifter is in our near future
Old 04-17-2016, 02:59 AM   #3643
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
another problem was the donor drive shaft off of the 1988 short bed 2WD truck, turns out at 56" it is about 3 inches too short, so we need another one but at least we had something to shove in the tailshaft and see for ourselves if it would work or not, that means way more to me than stretching some measuring tape and reading that
but seriously I missed it by one year? remember our generation goes up to 1987
Old 04-17-2016, 03:11 AM   #3644
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
turns out the truck wanted to spin the driveshaft even when the transmission was in neutral, so we had to pull it out and plug the tailshaft hole with a spray can cap and some masking tape and raise the rear end of the truck to keep the transmission fluid from dripping out ~ ROADKILL would be proud!
the only problem we had during our 25 minute camshaft break in was that the truck overheated after about 10 minutes, guess what, we had to pull the thermostat out to complete the break in so turns out Pontiac Mike was right when originally he told me not to install the thermostat until we break the cam in
that's why we ran for 25 minutes instead of 20 (varying the RPMs between 2000 and 2500) because we stopped to let it cool off to the point where we could yank that thermostat out and top it off with water, we ran water only intsead of coolant and I am so glad we did that, otherwise we would have sweet green coolant all over the engine and the garage floor, etc
we did not bolt up the power steering pump for the cam break in, there was no need plus the new water pump has a threaded hole for that bracket where as the original did not and allowed the long bolt to pass right through, I am going to see if there is a better way to mount the power steering pump than hanging it off that one exhaust manifold bolt, that is just silly
we ran the engine wiring quickly but just ugly enuff for the break in, I hope to nicely tuck it all away so that all you see is the spark plug wires
my '74 water temp sending unit was too big and would not fit in the Vortec head so I had to mount it in the intake manifold, I wonder if the Vortec sending unit will report properly to my '74 guage
we primed the engine with a drill to get oil to all the rockers
we primed the carb with gasoline so it didn't have to suck gas from the line while grinding on the cam
there were no other major problems during break in to report
Old 04-17-2016, 03:21 AM   #3645
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and a sneak peak at the newly painted radiator core support, yes the radiator shroud will be going back on but it was too dusty/dirty to find its way back on during the break in
and the headlight wiring harness will be hidden inside the core support
Old 04-17-2016, 03:26 AM   #3646
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and that's all the updates for tonight, again it was a long day, 12 hours with only 1 hour break for some delicious burritos, thanks to Mopar Seth and Pontiac Mike for helping out, but did I really deserve this? Clearly they are not Flowmaster fans!
Old 04-17-2016, 03:32 AM   #3647
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
wow Jeramy you da man, thank you so much, that might could work if I can find a bit longer shaft
Old 04-17-2016, 09:24 AM   #3648
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
here's my cynical take on the whole H pipe X pipe craze (for our street use people):
"How do we sell them what they already have?"
It's the cheese in the pizza crust nonsense.
They start out with single exhaust, and we gave them dual exhaust and they ate it up, now what do we sell? We need a gimick.
I give you the H pipe.
a few years later... hey man the H pipe sales are slowing down, we need a gimick
I know, lets give them the X pipe
Hmmm I woder whats the next "best" thing to simply get the dirty gases passed the passenger compartment?
oh by the way, Good Morning everybody, lol, take this with a grain of salt no need to start WWIII over it, ha ha
Old 04-17-2016, 09:38 AM   #3649
rusty76
rusty76's Avatar
Re: Restoring Rusty
Glad to see the puppy back in the cage. How I envy you. Grrrrr.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-17-2016, 09:44 AM   #3650
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thanks, lots of work bro lots of work!
