11-25-2011, 09:05 PM | #3651 |
SSN 706
Re: Project Vitamin C-10
We should make it a game. Guess how much dough Alan has in his truck? Who ever guess the closest gets the truck. I'll start off with one million dollars.
11-25-2011, 11:57 PM | #3652 | |||||
1 thing at a time is progress.
The vette wasn't there, but the Charlie Angles convertable white w/orange stripes 69 Camaro was. Quote:
Cleaned up the rest of the wires that was behind the tank that I couldn't get to before. I just used some split loom and brought the fuel sender wire out of it. Made a QD for the sender as well to facilitate future removal if needed. Then just tucked into the loom.
Alan
Philippians 2:14-16 |
11-26-2011, 12:00 AM | #3653 |
A couple more
Alan
11-26-2011, 03:18 PM | #3654 |
For those that don't know, when you run power steering the left front bumper bracket has to be modified. I have to repaint now.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 11-26-2011 at 09:03 PM. Reason: spellin' |
11-26-2011, 05:09 PM | #3655 |
WHAT ?!?!?!?
You mean I am going to have to cut and modify stuff to make it fit or work?? Nobody told me this! Well that seals it, I quit.... Just kidding. I really love all the pics you take, they help immensely when I am try to figure out how I am going to tackle a part or mod. I have to stop and remind myself to take a photo of something when I get started on it, remembering to take the "after" shots is easy
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
11-26-2011, 06:14 PM | #3656 |
Hope I remember that when I get to that point. Something tells me I won't.
Keep up the good work and thanks for the pics.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
11-26-2011, 08:46 PM | #3657 |
hey alan, just a quick question about sanding clearcoat. can you block the clear or do you just need to use your hand, i was told if you used a block it would leave drag marks.
11-26-2011, 09:46 PM | #3658 | |||
I wish I was this detailed about taking pics when i first started. If you look back the tear down didn't have many pics. The camera is like my cell phone, I don't leave home without it. I know my pnone has a camera, but no flash. Quote:
Here's another problem I think I mentioned before that needs to be fixed. The right rail on the front of my truck looked like it was OK when I removed the original bumper. Well my test bumper will not bolt up. I can get the bottom bolt in, but not the top. There is a bump in the bottom of the rail that is bringing the bumper down. I will bring my porto- power home and see if I can make it better. I'm not using this bumper since I'm going chrome. Once done I can weld the crack that I missed and paint the front section of the rail again.
Alan
11-26-2011, 10:15 PM | #3659 |
Hey Alan, I had that same crack in mine on the right side bottom I welded but it up, I just hope that I don't have those problems when I got back together with mine Thanks for pointing this one out.
11-27-2011, 12:59 AM | #3660 |
Hey alan guess what I found this weekend.. 86 chevy 1/2 ton 48000 yes that is correct four eight thousand miles... been garaged since day one. looks like brand new.. Price well that is a different story.. some where around Get ready.. $2000.
going to sell the 57 and start a new project..hope you guys won't band me from the site.. since my truck will be newer then a 79v8 auto power sterring deluxe cab.. |
11-27-2011, 12:18 PM | #3661 |
Daring to be Different
No way, you need to keep the 57 also. 2K is a great find for that low milage 86.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
11-27-2011, 02:42 PM | #3662 |
Resistance is Futile
Alan, is the bumper fit close enough that you can slot the holes?? My first thought as they will be covered with the bumper installed.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-27-2011, 05:59 PM | #3663 | ||||
Got a few things marked off the list. The main thing is I got all the grounds made a installed. The cab, engine, and bed are grounded to the frame. I didn't scrape the paint around the holes. I used lock washers to bite into the metal. It might be an issue later with corrosion. If so I'll use plan B. I used a ohm meter and all points had .5 ohms. i say it is good for now.
Alan
11-27-2011, 06:27 PM | #3664 |
I like your grounds thanks for the posting it. Were did you get the ground strap cable.
11-27-2011, 07:05 PM | #3665 |
My guess is 35 grand.........Mine is over 40 grand now and I know he is smarter than me
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
11-27-2011, 08:32 PM | #3666 |
SSN 706
As long as his wife thinks it's 10.
11-27-2011, 09:52 PM | #3667 | ||
Add another $300 for parts ordered tonight. Something else I started today. I didn't like the way the wires were coming thru the floor. It needed a grommet for protection. I found this rubber piece on a used door at work and thought it would come in handy. I cut one end off and split it. I should have installed it prior to running wires. It's not finished yet since I 've got more wires to run. Once the wiring is finished I'll use plastic split loom to cover the rest of the wires.
Alan
11-27-2011, 11:15 PM | #3668 |
You just gave me some ideas Ala. I have several of those type door wire looms!
11-29-2011, 01:04 AM | #3669 | |
Still chipping away at the small stuff. Mounted the relays for the AC and also hooked up the main feed to the circuit breaker for the AC. Baby steps, but they all have to be done. My ends almost look professional. Some of the wires with the Vintage Air already come assymbled. They are tinny wires and didn't really want cut into them. I only had about 12" extra I looped and tied off. Still not done wiring the AC, but making progress.
Alan
11-30-2011, 12:34 AM | #3670 |
We got a new toy at work. I wish we had it when I was doing the metal work on my cab. I can almost duplicate a factory spot weld. Don't rush out and buy one. They are pricey and this one requires 3 phase power. ;(
Hey Ronnie, you need one of these.
Alan
11-30-2011, 09:04 AM | #3671 |
One day...
Those are sweet!!!
11-30-2011, 09:51 AM | #3672 |
That is a cool tool.
11-30-2011, 11:13 AM | #3673 |
That would be nice to have.
11-30-2011, 11:21 PM | #3674 |
It can do a lot of stuff. I'll learn as I go.
Had a pretty bad set back today as far as the truck goes. Remeber my hood? Well, it's not in as good of condition as before. This company blasted my last hood and did a great job. So I trusted that it would repeat. I had all the paint sanded off the top except around the turn signals. I removed the hood bows and reinstalled the bows by a few threads. I told the guy that I did so and for him to remove them prior to sand blasting. After seeing what happens to a 67 hood when sand blasted incorrectly, I didn't want mine that way. The guy commented on how clean it was and it wouldn't take much to do the job. He also said he had never seen one without any rust. I told him it was from California. To make a long story short, he didn't remove the bows and now I have 2 nice ridges running down my hood where the bows were. I called the lady that owns the place to give her a heads up. She didn't get defensive, but the guy that blasted it wasn't there. I told her I would prime it and see how it really looks. Then I would call her back. I also told her that these are not reproduced and this one was from California. It just pisses me off that I did everything in my power to inform the guy, and this happens. In hind sight I should have kept the bows and blasted them in my cabinet like I did today. I sprayed some DP90 epoxy primer on it hopeing to get a good reflection. It was hard to get the right light for the camera. The wife suggested that they reblast it without the bows and maybe the metal will go back into shape. It sounds plausable. In the last pic you can see the ridges about 12' from the center rib. I don't know what to tell these people that blasted it. I hate to complain, but due to the circumstances of what I went thru to get a nice hood..........I speeceless. What do y'all suggest I do?
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 11-30-2011 at 11:30 PM. |
11-30-2011, 11:37 PM | #3675 |
Shloooooong bed member #2
That really sucks Alan, sorry to hear this. I agree with the wife. With your rep in the area they should make it right. As much work and sweat as you got into this don't settle.
David
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
