Old 04-17-2016, 09:59 AM   #3651
enaberif
Re: Restoring Rusty
H and X pipes aren't a gimmick. By the same though process dual pipes is a gimmick.
H and X pipes help with sound and balancing out the pulses from the engine and can actually make things better. But too many people LOVE droning noise in the cabs or to be obnoxious with their exhaust.. *ahem*Flow 40s*ahem*
enaberif is offline   Reply With Quote
Old 04-17-2016, 11:32 AM   #3652
foamypirate
foamypirate's Avatar
Re: Restoring Rusty
x2. My friend's 6.0L swap picked up quite a bit of low end torque swapping to an X-pipe (dyno verified). They aren't just a gimmick.
foamypirate is offline   Reply With Quote
Old 04-17-2016, 11:44 AM   #3653
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
just wanted to show you how the 833 transmission sits in the tunnel and how far back the shifter sits, see how we had to notch it about 1.5" around the shifter mechanism
I am wondering if the 80s trucks had a longer transmission tunnel than our 70s counterparts, maybe one of youz with an 80s squarebody could share a pic with us or some measurements of your manual transmission tunnel please
note the stock generic GM stick, I need to take it in to a place to have them thread the tip for me, I think CarQuest still has one machine shop around here
Gregski is offline   Reply With Quote
Old 04-17-2016, 01:55 PM   #3654
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
As the guy I quoted said. They allow you to use slightly larger pipes without the performance and noise penalty usually associated with going too big.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-21-2016, 11:25 PM   #3655
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so where are we on this project, let me give you some updates
First I returned the 1988 drive shaft as it was 3 inches too short, and as I learned, the drive line shops do not lengthen tubes, they replace them, so all I could use out of the drive line was maybe the transmission yoke, the U joint at the rear was the wrong size to mate with the differential
so I took today off and hit four junkyards
I picked up this 70" long, long bed driveshaft from a 1976 GMC (here we go again a GMC to GMC transplant) this shaft measures about 3.5" thick in the middle and tapers down to about 2.75 at each end, note that, it is important
Pros: both the spline end in the front and the U joint in the rear are correct (well not exactly, yes the rear is the right diameter 1.063 but at only 3.246" it is too narrow for the diff yoke)
Cons: the shaft is too long and it is damaged [revised: and the rear U joint is too narrow]
Lesson Learned: The drive line place/shop only installs straight pipes and not tappered ones, so I can't use the ends from this shaft to get a new tube installed, I would need new ends, spline yoke and U joint, more on that later, and since I basically exchanged my 88 one for this one, this lesson cost me nothin'
Old 04-21-2016, 11:30 PM   #3656
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
then I spied with my little eye this other long bed 70" shaft off of a 1976, but I punted on it cause it's ends were also tapered and if I was to shorten it to 59" I would need new yokes and U joint ends anyway
plus this truck lived a hard life, it looked like Death on Wheels
Old 04-21-2016, 11:38 PM   #3657
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so then I happen to walk by a 1983 El Camino and thought ah what the heck lemme check if it's a boy or a girl
and very interesting it has a shaft that is 61 inches long (only 2 inches too long) measures 3 1/4" in the middle section and tapers down to 2 3/4" just like the long bed one
Pros: although it is also tapered on both ends it has the same taper 2 3/4" like the long bed one, and there is plenty of room to shorten it 2 inches, and it was plugged in to a Turbo 350 so we are good on the front end / yoke spline thingie
Cons: it is only a 3 1/4 thick drive in the middle, and the back U joint is the wrong size, at 1.125" the diameter of the roundy rounds is a bit too big for the yoke in the differential
Plan: have this one shortened and use one of them combination U joints with 2 caps of one size and the other 2 of a different size, or just have the proper new U joint thingie installed by the drive line shop
Old 04-21-2016, 11:46 PM   #3658
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so here is where I find myself, I am a proud owner of three drive shafts right now
1. my original two piece Muncie SM465 one (backwards in the picture I think, LOL)
2. the 1976 long bed damaged, too long, with the wrong U joint one
3. the 1983 El Camino just barely too long one with the wrong U joint
I know some of you may be rolling your eyes but I enjoy learning about this stuff this works much better for me than reading a book or a manual, I have physically touched these drive lines and I know what they are and what they do now, I think that is pretty cool
Old 04-21-2016, 11:48 PM   #3659
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
here is how close we are with the El Caminio 61" drive shaft installed, just 2 inches away from a test drive, ha ha
Old 04-22-2016, 09:13 AM   #3660
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
Here's a thought for you Rusty...get the yoke off of the El Camino rear end and put it on yours. They are both 10 bolts right?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-22-2016, 09:46 AM   #3661
jwilson645
Re: Restoring Rusty
OR......if the tapered end of the Elco shaft is the same diameter of yours, use the yoke of your drive shaft on the Elco shaft after you have it shortened.
jwilson645 is offline   Reply With Quote
Old 04-22-2016, 10:53 AM   #3662
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thanks, but mine is a 12 bolt, I got the beefier rear end (wait... that didn't sound right, you git what I mean, ha ha)
Old 04-22-2016, 10:56 AM   #3663
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
all good suggestions, but mine is a 2 piece so its thicker I think 3" and the Elco taperes down to 2 3/4, LOL
I am having fun, love figuring out this sort of stuff
again thanks for all the suggestions guys n gals, that's why I share
Old 04-23-2016, 11:24 AM   #3664
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Remember these guys?
Old 04-23-2016, 11:32 AM   #3665
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
They must have come after Ren & Stimpy
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-23-2016, 01:13 PM   #3666
Titomars
Titomars's Avatar
Re: Restoring Rusty
Pinky and the Brain. hah never really watched them but I remember from my kids watching them. For me it was the Bugs Bunny and Road Runner show
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-23-2016, 11:07 PM   #3667
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
Hey I realize you're on to other things. However, can you coach me on the order in which the parts go back on as far as the grill and core support? My core support is already in place with the finders and headlight harness. Now I'm stuck.
LOL, you give me too much credit, mine is only held on by the two big bottom bolts with the rubber bushings and maybe one bolt on each side on top to each fender, just enuff to mount the radiator to run the engine
Old 04-23-2016, 11:13 PM   #3668
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
sharing is caring so here we go, so a little secret for you all, sometimes I like to take a Thursday off work and work on my truck in piece or go to the junkyard, you see the wife is at work, the kids are at school, and it's just me, Rusty, and Bud in the garage
ok, having said that, last time I went to Pick n Pull not only did I get a couple driveshafts, I also bronged home two more transmission crossmembers
now what in the world did you done that for Greg?
well I wasn't too a happy with the way I was mounting the trans with my old crossmember so I thought I could do better
so here is my collection
1. my old original Muncie SM465 4 speed cross member aka da Double Humper for 2WD
2. Turbo 400 TH400 automatic transmission for 2WD cross member
3. Turbo 350 TH350 automatic transmission for 2WD cross member
4. automatic transmission cross member for a 4x4 aka 4WD
Old 04-23-2016, 11:23 PM   #3669
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ok Greg, I am confused here, what is it that you are trying to accomplish here?
well our trucks came with the New Process 833 overdrive transmission in the early to mid 80s so I am looking for the crossmember that will allow us a simple bolt up with no modifications no holes to be drilled
lets review, the the one in the forefront in the picture, the nice and black one, that is one for a 4x4 truck and it won't work because it does not have the two holes to mount up the transmission bracket to, and the single hole bracket don't align with any of its holes, plus it sits too high, so we punt on that one
the second one from the front is the TH350 trans and when we compare it to my old one (the double humper) we see that though they look different they sit the same height above the bottom rail, about 2 inches above it, this one looks promising lets give it a go
Old 04-23-2016, 11:29 PM   #3670
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and here is the New Process 833 overdrive transmission held in place with the Turbo Hydramatic 350 TH350, it works, it fits, BUT...
lets go over a few lessons we learned whilst (yes I do use the word whilst from time to time, it's a lost art really) installing this automatic cross member
first I did not like my old crossmember because it did not align the two transmission bracket holes with it nicely, the transmission sat about 1/2 inch to the passenger side, well, same goes for this TH350 crossmember, so maybe there is nothing wrong with my old crossmember, maybe the transmission is crooked, yep, sure enuff
LESSON LEARNED: don't tighten mounts / brackets / anything super tight until you got everything fitted
we loosened the engine brackets and the transmission shifted into place nicely, about 14 inches is the center between my frame rails
Old 04-23-2016, 11:33 PM   #3671
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so the TH350 transmission cross member fits but...
but it don't play nice with long tube headers / dual exhaust (2.5 inch to be specific) hard to tell in the pictures but we need at least 1 inch more of clearance
hewk I could have had my collector extension pipes modified, or had some new ones bent, but why if I could just [wait for it] go back to my awesome Double Humper original cross member
Old 04-23-2016, 11:37 PM   #3672
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and that's what I did, I mounted my old transmission crossmember back into place, but this time I did not flip it front to back like last time to get the bracket holes to align, this time the transmission was properly shifted / aligned on center so the bolt holes matched up
I did loosen the cab mounting bolts and lifted the cab just enough to remove those four top cross member bolts in the top frame rail, and I only dropped in the one on each side that fit the new hole position
on the bottom I was able to elongate one hole in the bottom brackets and use two bolts on the bottom
so in total my crossmember is held on with 3 bolts on each side
so this was a classic example of one step forward three steps back, I had to remove the exhaust, I had to undo the engine brackets, I had to loosen the cab bolts, etc....
was it worth it, hewz yes
Old 04-23-2016, 11:41 PM   #3673
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
man I just about had enuff of crawlin' under the truck today and had to do something different, something above ground, and so I did
I decided to give it a go and cut out a hole for the shifter in the ol' transmission tunnel
it ain't perfect, needs a bit of biggering but it's a nice start
Old 04-23-2016, 11:44 PM   #3674
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
not a big fan of how the shifter protrudes on that curved edge, wish the tunnel was about 3 inches longer
Old 04-24-2016, 09:22 AM   #3675
flashed
Re: Restoring Rusty
Looking good Greg.
flashed is offline   Reply With Quote
