03-30-2012, 02:11 PM | #3676 |
67cheby
Re: 67 cheby's Dropmember build thread
do you mean something like this without the extra trans lines holes ? GEEZ LEEVON all of this is your fault and you arent even paying attention!! LOL
03-30-2012, 02:14 PM | #3677 |
67cheby
http://www.summitracing.com/parts/DER-13256/ This is what i am looking at
03-30-2012, 02:25 PM | #3678 |
Laid Back
I run the 30'' cooler on my frame rail Nd the tranny never gets hot!!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
03-30-2012, 02:48 PM | #3679 |
Look at this it is an 85 c/10 radiator.
http://www.summitracing.com/parts/PLI-433716/?rtype=10 This was the note in the description: Notes Heater return line with plug on passenger side tank. Maximum cooling radiator.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
03-30-2012, 03:14 PM | #3680 | |
03-30-2012, 04:29 PM | #3681 |
67cheby
hmmmmmmmmmm.....what to do , what to do
03-30-2012, 04:43 PM | #3682 |
03-30-2012, 05:00 PM | #3683 |
67cheby
LOL...this one wont leave me until i am dead...then i might just have them bury me in it !! LOL
03-30-2012, 05:04 PM | #3684 |
I figured you'd say something like that because that would be what I'd say after seeing all the effort you put into it. It definately won't be a catalog assembled or fancy shop built ride! Till death do you part! Or maybe you'll have a kiddo to past it down to.
03-30-2012, 10:53 PM | #3685 |
That's what I said about a couple wifes I've had.
03-30-2012, 11:18 PM | #3686 |
67cheby
Yep got a boy that can't wait to cruise in it !!
Posted via Mobile Device |
03-31-2012, 12:04 AM | #3687 | |
I like the finned cooler on the frame idea. Posted via Mobile Device
69 C10 "Torchered" RC Crawler Nut http://www.dorkstarproductions.com/orcrc.com/forum/ |
03-31-2012, 11:14 AM | #3688 |
GEARHEAD
I'll start by saying I'm not a pro mechanic, but I've been doing this stuff for about 30 years. I have run auto trannies with and without using the cooler in the radiator. No problems. But living up north where the temps can regularly be below zero, it's makes a difference on the tranny warm up. A cold tranny shifts slow and feels like its not quite locking up in the torque converter properly. So using the radiator cooler is probably a good idea if you are planning to drive it when it is very cold.
Frankly, I don't see that happening with your truck. Tranny lifetimes are usually prolonged by running cooler over the life of it. I've never heard or read about tranny failure due to running it below a certain temp for a few minutes until it warms up. The pump, the flow through the tranny and torque converter, etc. will warm the tranny fluid on its own. As for the holes on the cover for the tranny cooler lines, maybe weld a piece on that looks like an old rivet head. They had both rounded (like the head of a carriage bolt) and pointed ones. If it needs clearancing on the lower one you could drill or grind out the back side. Might even be able to find those bolt head covers to use, which are just stamped out sheetmetal, like what some of the bumper bolts had. Instead of a chrome bolt some had a cover over the head. BTW, if everything worked perfect the first time you made it, well where's the fun in that?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
03-31-2012, 11:30 AM | #3689 |
67cheby
thanks guys, and the cover that is on there now has just turned into a glorified pattern, both sides are getting completely redone...LOL, but now i know they will fit perfect because my patterns are coming out NICE !! 3 times a charm ...right !
03-31-2012, 11:54 AM | #3690 |
When I ordered my transmission from Bowtie Overdrives, they would not warranty the trans unless I ran it through the radiator then my auxiliary cooler. I set it up like that and with my trans temp gauge, I found that I never got up to 160° like it was supposed to, so I ended up taking the aux cooler out. Now, it gets up to 160° quick and stays there no matter how hot it gets outside, which in southern Louisiana is pretty damn hot!
I have read that for every 10° above 160° that your trans runs, you will cut your trans life in half. How accurate that is I have no idea. I'm curious though, all of these people that run just an auxiliary cooler instead of using the radiator, how many guys actually have a trans temp gauge and what does it read when you are sitting in traffic with the A/C blowing cold on a 95° day? I know mine will read 160°!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-31-2012, 12:08 PM | #3691 |
67cheby
geez....i think i am more confused then EVER !!
03-31-2012, 01:56 PM | #3692 |
plug the radiator trans lines so you have no lines going to it and you will have a cleaner look , put a small external cooler and call it a day , you will be fine , that's the way i have mine set up , here at 100 degrees and humidity in south florida
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
03-31-2012, 06:42 PM | #3693 |
I hear you might be in stillwater tomorrow?
03-31-2012, 06:47 PM | #3694 |
67cheby
Yes I will be there, look for the guys wearing slosh Tubz shirts my phone 1 479 599 9664
03-31-2012, 07:36 PM | #3695 |
glad to see progress still being made
04-03-2012, 06:08 PM | #3696 |
you looking for a place to store those "patterns" when your done? i know a 67 that could "store" them nicely...
04-03-2012, 06:10 PM | #3697 |
67cheby
lol, i will keep you in mind !
04-03-2012, 07:22 PM | #3698 | |
Village Idiot....
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold Last edited by n2billet; 04-04-2012 at 05:40 AM. |
04-03-2012, 11:18 PM | #3699 |
67cheby
Awwwwww ok, shows what I know thanks for not letting me screw up !
04-04-2012, 02:22 PM | #3700 |
67cheby
got my new SS7 bags in from Porterbuilt today , anxiously awaiting the arrival of my Bolt on Bodydrop !! Made my underhood panels for the third and hopefullly last time last night , plan on beadrolling , bending and dimple dying tomorrow night ! picking up SLOSH TUBZ SQUARED from the body shop and taking them to the fiberglass shop early in the morning ! lots going on ! this baby is getting done !
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
