Old 02-26-2016, 04:10 PM   #351
El Dorado Jim
Re: 8 lug wheels - what's on YOUR truck?
Originally Posted by extd56 View Post
And my crew cab the first picture are of the wheels that were on it and the ones that are on it now.
love your crewcab, would love to see it sometime....
El Dorado Jim is offline   Reply With Quote
Old 02-26-2016, 05:28 PM   #352
Big O
Rolling on 16.5 x 9.50 FirestonesName:  right side.jpg
Big O is offline   Reply With Quote
Old 05-20-2016, 11:17 AM   #353
683/4farm
Do you have the floater hub coming through the rear wheels?if so how well did the rear caps fit over?
683/4farm is offline   Reply With Quote
Old 05-20-2016, 02:01 PM   #354
northerngmc
northerngmc's Avatar
Before I lowered my 68 C20 it had white wheels with hubcaps and trim rings.
I removed the hubcaps and painted the wheels green. Left the trim rings on.
northerngmc is offline   Reply With Quote
Old 05-20-2016, 10:44 PM   #355
CG
BlahBlahBlah
Mine ....
Old 05-21-2016, 07:21 AM   #356
-Greg72
-Greg72's Avatar
17 X 9" custom built to hold the Chevy hubcap....
Almost done with all the welding, then off to powdercoat!
-G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 05-21-2016, 09:35 AM   #357
Ram-Man
Ram-Man's Avatar
Moto Metal 20 x 9
Ram-Man is offline   Reply With Quote
Old 05-21-2016, 11:44 AM   #358
Jonlopes
Originally Posted by CG View Post
Mine ....
Those are the best looking wheels for these trucks. I wish they were not so hard to find in 16"!
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 05-21-2016, 12:15 PM   #359
chevy2tom
chevy2tom's Avatar
Just ask lol, I have a set that I'll sell
chevy2tom is offline   Reply With Quote
Old 05-21-2016, 06:57 PM   #360
dads longhorn
dads longhorn's Avatar
Just like Big O's, 9.5x16.5 firestone 8 lug originals
dads longhorn is offline   Reply With Quote
Old 05-22-2016, 12:50 AM   #361
rusty knuckles 5
Here is a tip to the people with alot of money to make a lot of money , make a adapter from a 16.5 rim adapted to a 17 inch tire, i think you will clean up. there is a lot of nice rims going to waste, wishing you all the best
rusty knuckles 5 is offline   Reply With Quote
Old 05-22-2016, 04:19 AM   #362
RINC
RINC's Avatar
16 x 7 MB Razers
235-85-16 tyre's
Chris
'69 C-20
'04 Jeep TJ
RINC is offline   Reply With Quote
Old 05-22-2016, 07:39 AM   #363
-Greg72
-Greg72's Avatar
Are you talking about some kind of 1/4" tire spacer that mounts to old wheels?
I really like the look of factory white steel wheels with hubcaps, but there are very few good choices in 16.5" sizes these days. I cut out the centers from some 16.5" factory wheels and figured out how to mount them to a 17" hoop...
Now I've got a lot of modern tire choices, but with the "look" of a stock wheel.
-G
Old 05-23-2016, 05:34 PM   #364
RPBurris
RPBurris's Avatar
Mine ....
CG...What do you use to polish those wheels? Looks like the same as mine but I just cannot get them to polish.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 05-23-2016, 07:18 PM   #365
CG
BlahBlahBlah
I got the mags from board member cleszkie, they were nice and shiny when I got them. You might shoot him a PM.
Old 06-01-2016, 06:27 PM   #366
Harley03joe
Originally Posted by 70LongbedC20 View Post
Same as some other people. I think they are a little inboard too.
I Just Put The Same Wheels On My Truck, Can You PLEASE Tell Me What Size Lug Nuts You Used , The 14x1.5 are to tight
Please Help Me Out Here Thank You.
I Need The Right Lugs To Be Able To Put On The Center Caps ?
Harley03joe is offline   Reply With Quote
Old 06-01-2016, 06:52 PM   #367
chevy2tom
chevy2tom's Avatar
16x8 polished centerlines, picked them up from a forum member years ago & haven't seen another set.
Old 06-01-2016, 07:09 PM   #368
FirstOwner69
FirstOwner69's Avatar
Your lug nuts are either 1/2" (drum brakes before 1971) or 9/16" (disc brakes 1971 and later). The correct nuts are commonly called dual thread lug nuts and are available on eBay as well as other sources.
9/16"
http://www.ebay.com/itm/32-LUG-NUTS-...9WD1vm&vxp=mtr
1/2"
http://www.ebay.com/itm/32-LUG-NUTS-...VWD11e&vxp=mtr
FirstOwner69 is offline   Reply With Quote
Old 06-02-2016, 01:45 AM   #369
Harley03joe
9/16"
1/2"
Thank You Bro For That Info, I'LL Head Over To The Tire Store In The Morning And Try The 9/16 Ones I Know 1/2 Is Way To Small, I Do Have Front Disc Brakes And Drum In Rear With The Floating Axle, My Truck Is 71 C20 3/4 Ton Camper Special
Thank You
Harley03joe
Front
REAR
Old 06-02-2016, 01:50 AM   #370
Harley03joe
9/16"
1/2"
Here Is A List I Found On Line
So First Owner 9/16 Your So Right
Thanks Again Bro
Joe
CHEVROLET/GMC TRUCK/VAN/SUV -
1/2 TON BLAZER, JIMMY, SUB FULL 71-91 5X127.0 1/2-RH NUT 78.1
1/2 TON BLAZER, JIMMY, SUB FULL 71-91 6X139.7 7/16-RH NUT 108
1/2 TON BLAZER, JIMMY, SUBURBAN 92-on 6X139.7 14mmX1.5 NUT 78.3
TAHOE, YUKON 2X4 92-99 5X127.0 14mmX1.5 NUT
1/2 TON BLAZER, JIMMY, SUBURBAN 00-on 6X139.7 14mmX1.5 NUT 78.3
1/2 TON TRUCK ALL MODELS 2X4 67-87 5X127.0 1/2-RH NUT 78.3
1/2 TON TRUCK ALL MODELS 2X4 88-98 5X127.0 14mmX1.5 NUT 78.3
1/2 TON TRUCK ALL MODELS 4X4 67-87 6X139.7 7/16-RH NUT 108
1/2 TON TRUCK ALL MODELS 4X4 88-98 6X139.7 14mmX1.5 NUT 78.3
1/2 TON TRUCKS 2X4 & 4X4 99-on 6X139.7 14mmX1.5 NUT 78.3
3/4 TON TRUCK 2X4 & 4X4 67-on 6X139.7 1/2 or 14mm NUT 100.7
3/4 & 1 TON C20, C30, K20, K30 65-87 8X165 9/16" NUT
C2500-K3500 1 TON & HD 2X4 & 4X4 88-04 8X165 14X1.5 NUT
ASTRO/SAFARI 5-Mar 6X139.7 14mmX1.5 NUT 78.3
AVALANCHE 1500, 2WD, 4WD 6-Feb 6X139.7 14mmX1.5 NUT 78.3
AVALANCHE 2500, 4WD 02-on 8X165 14mmX1.5 NUT 125
COLORADO, CANYON 04-on 6X139.7 12mmX1.5 NUT 100.7
COLORADO 15-on 6X120 14mmX1.5 NUT 66.9
CYCLONE, TYPHOON ALL 5X120.7 12mmX1.5 NUT 70.3
EL CAMINO, CABALLERO 64-81 5X120.7 7/16-RH NUT 70.3
EL CAMINO, CABALLERO 82-87 5X120.7 12mmX1.5 NUT 70.3
ENVOY 02-on 6X127 12mmX1.5 NUT 78.3
EQUINOX 2005-2009 5X115 12mmX1.5 NUT 70.3
EQUINOX 10-on 5X120 14mmX1.5 NUT 66.6
LUMINA APV 90-96 5X115 12mmX1.5 NUT 70.3
S-10, S-15 BLAZER, JIMMY, SONOMA 82-on 5X120.7 12mmX1.5 NUT -
S-10, S-15 BLAZER, JIMMY, SONOMA 83-on 5X120.7 12mmX1.5 NUT -
SAVANA 1500 01-on 5X127.0 14mmX1.5 NUT -
SSR 04-on 6X127 12mmX1.5 NUT 78.3
TRACKER 98-on 5X139.7 12mmX1.25 NUT -
TRAILBLAZER 02-on 6X127 12mmX1.5 NUT 78.3
TRAVERSE 09-on 6X132 14mmX1.5 NUT 74
UPLANDER 2005 5X115 12mmX1.5 NUT 70.3
UPLANDER 06-on 6x115 12mmX1.5 NUT 70.3
VAN G-SERIES 1/2 TON 71-96 5X127.0 1/2-RH NUT -
VAN G-SERIES, 3/4 TON 96-97 6X139.7 14mmX1.5 NUT -
VAN EXPRESS 1500 97-02 5X127 14mmX1.5 NUT 78.3
VAN EXPRESS 1500, SAVANA 03-on 6X139.7 14mmX1.5 NUT 78.3
VAN EXPRESS, SAVANA 2500, 3500, 97-on 8X165 14mm1.5 NUT 117
VENTURE 97- 5X115 12mmX1.5 NUT 70.3
SUBURBAN 2X4 & 4X4 65-87 8X165 9/16" NUT
Old 06-02-2016, 01:56 AM   #371
Harley03joe
9/16"
1/2"
HERE Is Another List I Found
Joe
Chevrolet / GMC Trucks & SUV
Asrto Van 1985-2002 1/2"
Asrto Van 2003-On 14mm x 1.50
Avalanche 2002-On 14mm x 1.50
Blazer 4X4 (6 Lug) 1971-1991 7/16"
Blazer 2 W/D (5 Lug) 1971-1991 1/2"
Blazer 1992-On 14mm x 1.50
C-10 1971-1988 1/2"
C-1500 (5 Lug) 1971-1987 1/2"
Canyon 2004-On 12mm x 1.50
Caballero & El Camino 1964-1981 7/16"
Caballero & El Camino 1982-1987 12mm x 1.50
Chevy 3/4 Ton Van (5 Lug) 1960-1981 1/2"
Colorado 2004-On 12mm x 1.50
Denali, Express Van, Savana Van 1996-On 14mm x 1.50
Envoy 1999-On 12mm x 1.50
Equinox 2005-On 12mm x 1.50
Jimmy (5 Lug) 1969-1970 7/16"
Jimmy (5 Lug) 1971-1991 1/2"
Jimmy (6 Lug) 1971-1991 7/16"
Lumina Van 1989-On 12mm x 1.50
Luv 1972-1984 12mm x 1.50
Pickup (5 Lug) 1971-1987 1/2"
Pickup (6 Lug) 1950-1987 7/16"
Pickup (8 Lug) 1965-1987 1/2" or 9/16"
Pickups (All) 1988-On 14mm x 1.50
S-10 Blazer 1983-On 12mm x 1.50
S-15, Sonoma & Jimmy 1983-On 12mm x 1.50
Safari 1985-2002 1/2"
Safari 2003-On 14mm x 1.50
Savana, Suburban & Yukon (5 & 6 Lug) 1992-On 14mm x 1.50
SSR 2004-On 12mm x 1.50
Suburban (5 Lug) 1969-1970 1/2"
Suburban (5 Lug) 1971-1991 7/16"
Suburban (6 Lug) 1970-1991 7/16"
Suburban (8 Lug) 1970-1991 9/16"
Tahoe 1995-On 14mm x 1.50
Tracker 1989-On 12mm x 1.25
Trail Blazer 2002-On 12mm x 1.50
Uplander 2005-On 12mm x 1.50
Van 5 (Except Express) 1971-1996 1/2"
Van 6 (Except Express) 1971-1996 7/16"
Van 8 (Except Express) 1965-1996 1/2" or 9/16"
Ventura MiniVan 1997-On 12mm x 1.50
3 of 9
Old 06-02-2016, 10:07 AM   #372
Project_Big_Red
Not sure what brand but their 16.5 inch rims.
1966 Chevelle True SS "father and son project"
1969 C60 "Toy Hauler"
1970 k20 "Big Red"
1970 C10 lwb "survivor"(Sold)
1971 k20 "Duramax build"
Project_Big_Red is offline   Reply With Quote
Old 06-02-2016, 03:07 PM   #373
midniteblues
midniteblues's Avatar
[QUOTE=Project_Big_Red;7612722]Not sure what brand but their 16.5
That looks like the beginnings of a sweet truck.
I gotta ask, did you recently buy it?
Seem to recall one similar on cl a while ago.
Anyway these accuride wheels are going on my
71 with some 245 70 16 bfg at's when I find some scew in valve stems.
Thanks too some local board members I also have a full set of oe 16x6" rims also. I wouldn't mind finding a set of firestone transforce tires for them (tall and skinnys)
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-02-2016, 04:45 PM   #374
The Swed
The Swed's Avatar
16" in stead of 16.5"
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 06-02-2016, 07:35 PM   #375
larryboy_3t5
larryboy_3t5's Avatar
Stock 16.5x8.25
"A man's got to know his limitations"
1969 Chevy C20 Camper Special
1968 Chevy C-10 short/fleet
1970 GMC Jimmy 4x4 (SOLD)
larryboy_3t5 is offline   Reply With Quote
