#351 |
HOW long until spring??
![]() Join Date: Mar 2009
Re: Bubba's recycling project
Got a Mr Gasket Universal throttle cable , now all I need is a different gas pedal set-up.
I scrounged one from a Impala but it is not the right configuration. ![]() Next question .. Are you guys using the ported vacuum or full manifold vacuum to the HEI ??
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#352 |
I'm hooked to ported vacuum.
I've used gas pedals from old 68-78 Novas before. |
#353 |
SSN 706
I just went out and messed with mine for like an hour. I don't see a big diff. I did have it the way holley says to do it "tuned vac". I switched it and adjusted my timing. 4* with everything pluged. I just left it hooked up to full. Went for a couple test drives I don't see a difference.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 05-02-2011 at 11:53 PM. |
#354 |
Okay things are not done ,but I am done enough it is drivable again. Daughter is whining, School is almost out and She wants it to finish out the school year
I made the throttle cable plate from a scrap of 12 gauge sheet metal. I will remake it from a piece of 1/8 aluminum and polish it a little since the design is working. I had planned a old school "Barefoot" pedal but daughter turned up her nose and said NO!! I added a second attachment hole to the linkage to mount a second cable which will attach to the TH350 transmission for a detent cable in the future. Getting the detent cable long enough to mount at the carb linkage is a PIA. I set up the HEI advance on full manifold vacuum. I have timed this thing all different ways on ported and full vacuum and it seems to like full vacuum better, I may have to get a adjustable vacuum advance as I am at 40+ total timing. I think it is a little much but the motor is not pinging.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-20-2011 at 12:50 AM. Reason: added text |
#355 |
Looks good. Aluminum bracket will look good polished up. I've used 1/8 inch aluminum plate to make air cleaners with. It paints easy too.
For your kick down why not use 2 kickdown cables and build a bracket to join them together in series. Shouldn't be hard to do. And one end could be hooked to your carb. If 2 cables hooked together are too long look for a shorter one. Lots of bikes and motorcycles use shorter cables. |
#356 | |
Adjustment of cable is a problem with that idea. ![]() Thanks geezer, for the idea It sure runs better and accelerates smoother and quicker and the cable is a major improvement over the old stiff throttle linkage
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-20-2011 at 09:10 AM. Reason: added text |
#357 |
Bubba,
Man that looks great! I might have to borrow that bracket design when your get done with it. It was good to see you at the shop the other day, you took me and my dog by surprise! feel free to drop by anytime. "when your here, your family" |
#358 |
SSN 706
You going for a drive today.
#359 |
Hi Nic, I stopped by Jalopy Jungle friday and the 65 or 66 has been crushed
![]() ![]() And Ken at the radiator shop will pressure test that 4 row radiator no charge. I still need to find some upper and lower radiator saddles for that wider radiator, I wandered around the junkyard looking at the Hydro boost brake boosters found on the Astro's and diesel trucks. My brakes are still darn stiff and with the light throttle pedal it is now time to get the brakes working a little easier. Drives a whole lot better, It went to school yesterday and I just saw daughter and truck leave on their way to work tonight at the racetrack. Took the 4-wheelers up in the timber today to find snowline and we had a lost Walker bear dog follow us back to the truck. Dog was tired, thin and glad to see somebody.Spent all afternoon finding the owners and getting the dog back to them. The transmitter tracking collars quit and they lost 4 dogs last weekend and only had found the one dog so far. Hope the wolves did not find the others. Headed to the Saturday night cruise at Patty"s drive in.. Pictures to follow
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-21-2011 at 06:39 PM. Reason: added text |
#360 |
SSN 706
Glad you helped the one dog. I'll bet he was happy. That would really suck losing all your dogs, and the collars. I think it happen's often. A guy I knew lost his dogs he threw his jacket on the ground came back 3 days latter and they were there.
#361 |
Was at the local car show today. Guy had a 250 in his 54 chev truck. With offy and edelbrock 4 barrel. Here's some pics for how he controls the tv cable for his 700R4. Says he did the same set up when he had a turbo 350 in it. Another bell crank method for a kickdown.
#362 |
![]() Join Date: May 2009
Gezzer#99 that looks more like a Clifford than an Offy unless Offy heats their's with hot water now...Vernski
#363 |
Bifocals!! It must be these dang bifocals. It do indeedy say clifford on there. I guess it'll be the usual!! 20 lashes with the dreaded cat of nine tails. Go easy this time.
OUCH!!! _______! |
#364 |
IYAAYAS
![]() Join Date: Apr 2010
Looks good Bubba. Wish you could bring it over Saturday. I went to a cruise in tonight at the Westside Drive In before the rain. No other trucks like ours there.
#365 |
Hey Bubba, our kids have made classics contact at school. He's been driving the 63 there. He got hit a couple of weeks back in the parking lot. Got a text saying the front got hit. I thought for sure the nos custom cab grille I recently installed was toast, but it only got the bumper with a hitch. Whew! Bumpers at the chrome shop now.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
#366 |
Just realized that sounded like our kids hit each other rather than talked trucks. It was a dodge truck that backed into him. Whew again!
#367 |
Hey Idaho guys , I am really sorry I cannot make the BBQ. Really good friends/family having a graduation party Saturday noon . I have been assigned to help so I am committed with no options. But hey,! food and beer is involved so I am OK with that. take pictures please.
Here is the thread for the BBQ! http://67-72chevytrucks.com/vboard/s...d.php?t=452411 Only 1 knee-knocker was at Patties cruise , the band was good but the rains came early. Imperial Kustom was at the cruise,so I told him to check the Idaho meeting thread and come to BBQ if he is still in town. I met a classmate at Patties cruise from high school 30 some years ago, We had a great time catching up. He has a blown Hudson that is really nice. I cannot believe we have not seen each other in all those years.. we both have missed the re-unions for one reason or another. R-bar -I am glad nobody was hurt but the bumper, That is why I have held off so long on the body work on daughters truck, I remember the high school parking lots were always having some kinda fender bender. I had a panic attack the other day down the road in next town of Eagle. I saw a young man driving in a nice 63-66 blue and white short box and at the distance I was at, It looked like our truck!! Where is my daughter????? Steal my truck will ya !! SOB- Here I Come!!!! As it turned the corner towards me ,,,A small rear window became visible so I calmed down. So ---There is a almost identical truck around the area but with the small rear window , Same blue and white two-tone, short bed , I need to find him someday and apologize for turning the air Blue -- and check out the truck! ![]() I have been watching the terrible destruction in the southern states by the twisters. My thoughts and prayers go out to all of you affected by the storms
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-26-2011 at 05:36 PM. Reason: added text |
#368 | |
He has a catering rig as well . I cannot say enough about his cuisine. It was profiled on the Food Network TV show Diners-Drive-ins and Dives a little while ago
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 05-26-2011 at 05:45 PM. Reason: added |
#369 |
Not much to report on the truck.
Daughter is going to summer school and so is the truck. She is Student Body President and Co-Editor of the yearbook her senior year so she is taking Government and English this summer to lighten the fall load of Advanced Placement classes and open up the fall schedule . The truck is running sweet with the Holley, no mechanical problems at all, I have not built the aluminum adapter plate yet , or the transmission kick down yet either,I just put gas in it and watch it go. Getting approx 15 MPG after 300 miles I love old trucks. I accepted a new job as a Building Safety Official/ City Electrical inspector. Friday is my last day at my old job as a master electrician. It seems kinda strange to be cleaning out the service van, knowing I am hanging up my tools after 24 years in the trade......... Wondering what I have taken on and what the future holds...... Bubba
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 06-15-2011 at 10:32 PM. Reason: added text |
#370 |
Congrats man!!
You'll be a shoe in. I'm sure its a bitter sweet transition. Being a technician myself, a little less physically demanding job sounds very appealing from time to time. Especially when in some of the dirty, nasty, confined job locations I find myself in day to day. All the best!! |
#371 |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
Bubba, Which city are you going to be inspecting for?
#372 |
More Great News!!!! -------------Daverod has announced that he will be attending Northwest Motorfest in Boise in July!!!!!!!!
![]() ![]() This calls for Celebration on the part of the local Treasure Valley 60-66 bunch!! http://67-72chevytrucks.com/vboard/s...d.php?t=469913 We need a plan. Any ideas Idaho guys?? Jason -PM sent Bubba
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 06-15-2011 at 11:30 PM. |
#373 |
SSN 706
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 06-16-2011 at 10:29 AM. |
#374 |
Dave it is a good thing you are gonna have a designated driver, I promise not to tell your PO...
![]() ![]() ![]() Are you entering your truck in the show or just spectating???
#375 |
SSN 706
I'm just lookin and dreamin.
