Old 09-08-2010, 08:46 AM   #351
Jonboy
Slots go on anything!
Re: LS1 into a 73 cheyenne
That is exactly how I shaved the seam on my '73. I was planning on tack welding the corners when I do the roof on my CC, just to be on the safe side. I have also used the 8115 to fill trim holes on a '94 Roadmaster I used to have. I used pennies as a backer, because I am lazy.
Those tires are killer. This truck is going to be insane when it is all together.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-10-2010, 02:06 PM   #352
6erWebb
maaannnnnnnn what a build, the quality pictures only made it even more enjoyable. good luck with the progress
6erWebb is offline   Reply With Quote
Old 09-10-2010, 04:27 PM   #353
79gmcclassic
79gmcclassic's Avatar
Gosh i cant wait til this truck is done!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 09-12-2010, 11:53 PM   #354
smokedat
smokedat's Avatar
I got the wheels mounted on the tires < the wheel shop was not able to balance them because they didnt fit on the machine.
I installed the bed for a moch up for the measurement of the new rear end , back side of the wheel to back side of wheel, minus a 1/2" for the brake rotors roughly at 1/4" each. I will have 2" clearance in the front from the lip of the fender and 3" on the back side from the frame. I will order a custom rear axle with Ford 9” big-bearing “Torino” (BBT) or “new style” housing ends, moser 31 spline axles.
here are the following specs
For the center section i will run a track lock posi with 4.11or + gears.
As for the rear suspension i will use Ridetechs 4 link with their new adjustable coilovers.
For the rear brakes i plan on running big breaks from a C6 z06 style 340x26mm 13.4" with 4 piston calipers
Here are a few pics of the moch up
smokedat is offline   Reply With Quote
Old 09-12-2010, 11:55 PM   #355
smokedat
smokedat's Avatar
heres a close up
Old 09-13-2010, 12:00 AM   #356
smokedat
smokedat's Avatar
By the way i will not run the Ebrake for 2 reasons if I dont i save like $600 and personally i think the cabin looks cleaner with less pedals hangin
Old 09-13-2010, 12:22 AM   #357
3r!c84
Badass
3r!c84's Avatar
bet they had a fun time mounting them tires lol i work at goodyear the wider and thinner the tire the more its suckss lol
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-13-2010, 07:25 AM   #358
menace121978
menace121978's Avatar
holy crap! that is sick man! i love the look of those tires mounted nice progress
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-13-2010, 07:42 AM   #359
nlped
nlped's Avatar
WOW...SEXY!!!
Question though. Won't a 3.70 gear with that 31" tall tire and the 4L60e trans have a very low highway speed RPM? Just doing the math it seems like it would be better with a 3.90 or possibly a 4.10 final drive. That's the luxury of a Ford 9", lots of gear choices.
Anyhow, Man... It is looking awesome!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-13-2010, 08:22 AM   #360
RandyP
Getting Old; Going Broke
RandyP's Avatar
That is one sexy looking view from the back. Always have liked those views the best on the ladies though.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-13-2010, 12:30 PM   #361
kvn1011
Kvn1011
kvn1011's Avatar
nice!!
kvn1011 is offline   Reply With Quote
Old 09-13-2010, 05:39 PM   #362
smokedat
smokedat's Avatar
I agree I previously had 4.10 and i really like how it cruised on the highways might just stick to 4.10's
Originally Posted by nlped View Post
WOW...SEXY!!!
Old 09-13-2010, 05:48 PM   #363
smokedat
smokedat's Avatar
thanks for the compliments fellas.
Waiting on the rear axle I ended up pickin that up from Quick Performance Inc. I got a better price than the local shops around this area heres a link http://www.quickperformance.com/index.htm
Im also waiting on the 4 link i got that one from Ridetech part # TRI1000 with the stainless option with the Billet Shockwave Lower Rear Mount part # SKW0901 as for the coilovers i will order last after evrything is hangd.
Old 09-13-2010, 06:01 PM   #364
68 TT
Still plays with trucks
68 TT's Avatar
You have quite a bit of rubber out back and at 31" tall you might want to look into going with a 4.57 gear instead. 60 mph is only 2080 rpm so it is still going to be pretty low rpm on the freeway. If you drive in the car pool lane in LA you will only be running 3120 rpm at 90 mph. You will be aerodynamically limited before you run out of gear.
Look for the 4.57 gears vs. the 4.56's as the 4.57 has fewer teeth on both the ring gear and pinion so they are a little tougher.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-13-2010, 11:05 PM   #365
v502
v502's Avatar
Man all i can say is WOW
The wheels are awesome i was thinking about getting the MT wheels but HR2. Ride-tech 4 link looks nice i got that on my list but not the stainless but i might change my mind i just have to wait for you.
v502 is offline   Reply With Quote
Old 09-14-2010, 12:00 AM   #366
smokedat
smokedat's Avatar
Il make sure i post pictures
Old 09-14-2010, 12:40 AM   #367
smokedat
smokedat's Avatar
Im also waiting on the rear brakes I only bought the rear set up due to incuficent funds will convert the front eventually.
Their from a C6 z06 style. On the rear 340x26mm 13.4" with 4 piston calipers No Ebrake.
I am sertain I will need a spacer between the wheel and hub to clear the caliper, so i got some Arp 1/2x 3" wheel studs hopefully that will be enough
Old 09-14-2010, 02:32 AM   #368
draggin86
draggin86's Avatar
sweet baby jesus those are some big ass tires! looks great man!
draggin86 is offline   Reply With Quote
Old 09-14-2010, 06:18 AM   #369
logan91k
logan91k's Avatar
wow, nice setup! Could u give me some more info about the wheels? Where did ya get them, for how much? (size of the tires and rims?)
(sorry if you already posted the info and i just overread it...)
'01 GMC Sierra ~ daily
'64 Chevrolet El Camino ~ project
'80 C-10: 5.7L/custom ~ My Baby! - sold -
European Union -> Germany -> Bavaria -> Franconia -> Nuermberg
logan91k is offline   Reply With Quote
Old 09-18-2010, 06:00 PM   #370
smokedat
smokedat's Avatar
Thanks, the wheels and tires are Mickey Thompsons and i got them online thru Summit the tires were $400 each plus $30 each for oversize shipping. The wheels HR1 were i think $1,250 each. on the rear i got 20x16 with a 5" back space bolt pattern is 5x4.75 they dont make these on 5x5. Tires are Sporsman SR 31x18x20.
Old 09-18-2010, 06:06 PM   #371
smokedat
smokedat's Avatar
The 4 link arrived today I opened up the box and everything was wraped in foam. The quality of this kit is superb it arrived with no scrathes on the shiny stainless and the tig welds are very well done. I didnt get a chance to measure the lenghts will post that info later.
Old 09-18-2010, 06:43 PM   #372
menace121978
wow! this is turning into one heck of a build my friend! awesome stuff!
"Dennis the Menace"
Old 09-18-2010, 07:07 PM   #373
Leedogg
Love this thread- sweet ride in progress!
Leedogg is offline   Reply With Quote
Old 09-22-2010, 12:05 PM   #374
smokedat
smokedat's Avatar
The rear components showed up my first impression was "damm this thing is narrow" it is a metal beef cake its very well built
Old 09-22-2010, 12:07 PM   #375
smokedat
smokedat's Avatar
I slided the axles into the housing for test fittin the bolt pattern of the hubs with my wheels and it was a match so far so good
73c10, c10, cheyenne, ls1, swap
