10-30-2011, 12:10 AM | #351 |
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
At least you had fun right. Not sure what that would be in 1/4 mile times but seems fast. The second time sheet you must have raced a turtle. So are you giving up on your trans?
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
10-30-2011, 11:45 AM | #352 |
Truck and auto performance nut
Times equate to low 13's or high 12's in the 1/4.
I'll never be happy or comfortable with this trans. Got home last night and it sat in the driveway for a while then moved to garage....left 3 nice drops on the pavement. I just can't get this thing to seal up, or shift how and when I want it too.....so as soon as I get a spare $2k its out and becoming my personal rebuild project for a backup tranny for those times I get to go to an LSx, Goodguys, or some other event far from home.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
10-30-2011, 12:54 PM | #353 |
Still Learning
Sounds to me like you hooked up great. If you get in the 12's that's gonna be one FAST truck.
10-30-2011, 04:15 PM | #354 | |
10-30-2011, 05:46 PM | #355 |
Holley's LSFest is in Bowling Green KY. The LSX Shootout that was in Memphis is in like 4 other cities now
As far as shifting, I plan to race this truck and I need it to be consistent...or I might as well stay home.
10-31-2011, 07:56 PM | #356 |
6>8 Plugless........
Nice times man. At least you still can go to the track. We're all out of track time up here.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-31-2011, 08:58 PM | #357 |
thanks. we have a few more weeks left...but yes its about all done down here for the year too!
11-30-2011, 11:54 PM | #358 |
purchased a 2nd carb...for use in the off season. Wanted something on the other end of the scale from my 750cfm Street HP that would start up easy in winter and return a reasonable mpg for just cruising, so I got a vacuum 650cfm 4150 series Holley. Dual inlet, elec. choke, vac. secondaries
Made 2 changes before bolting it on in the hopes I wouldn't have to take it back off. Based on my old carb I upped the primary jets 3 sizes and the primary squirter 7 sizes. Left the secondary jets and vacuum springs alone for now. I think this smaller carb might be a bit crisper jumping off idle then the 750cfm Street HP! Might have to take it to the track again and see how the "economy" carb does up against my "race" carb.
12-01-2011, 12:42 AM | #359 |
That is tiny carb. If you get it tuned right should have great response.
12-30-2011, 07:23 PM | #360 |
should make it a bit easier to get along with in winter as opposed to the 750 Street HP.
but on the other hand.................I may have a deal working where someone wants what I've got (that I'm not really using) and might trade some to most of an LY6/L92/LS3 efi setup and a tune for it. If I do...I'll take it another direction to solve my weak trans issue. Just put a 4L80e in it. Then all I'll need for lots of abuse at the track and easy cruising home is a built dana60 or 14bolt SF 9.5"...or my last choice...a 9" turd
12-30-2011, 08:20 PM | #361 |
A 9" turd! LMAO! Spend the money once and put a 9" in it.
12-30-2011, 09:01 PM | #362 |
Sweet build and great numbers on the track. I have a question. I am not motor savy, so I had a friend build me a motor..basically a zz4 block, edelbrock e-tec heads, rpm air gap intake, roller cam and lifters, and edelbrock 750. Said it should put out 420HP. Runs like a scalded dog! The problem I have is I have not done anything to the rear end...I am wanting POSI! How hard is it to install a Richmond or posi lock?
Thanks, James |
12-31-2011, 01:25 AM | #363 |
A 4l80e and a dana 60 would be sweet. When my 700 dies it will get a 4l80e.
12-31-2011, 02:14 PM | #364 |
its not that hard to do, especially if you're not swapping the gears too. Mine's an Eaton limited slip...or "posi".
if you had someone build your motor...you might want to do the same with the rear.
12-31-2011, 02:15 PM | #365 |
then you going to pcm control?
12-31-2011, 11:44 PM | #366 |
Yes i will be getting the ez tcu that tci and fast built together. It has an option to wire push button shifts. Like a paddle shifter but with buttons.
http://www.tciauto.com/tc/tcir-ez-tcutm.html
01-31-2012, 10:42 PM | #367 |
well......my build may be taking a different direction. If some horsetrading that I'm involved in works out like it looks like it will...I'll be getting all the stuff needed to take my LY6 from carb back to running computerized efi. I guess I should go ahead and install it all vs letting it just gather dust.
custom harness, ecm, complete intake, etc. I'm thinking now I can go 4L80e easily....or I could even go 6L80e I think. Now that would be cool.
01-31-2012, 11:01 PM | #368 |
A guy with a truck
Yes! Now you're talkin'
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-01-2012, 12:16 AM | #369 |
69' Chevy Stepside
Sounds like a good plan to swap back to efi! Which intake is it, the truck LY6 or a car style LS3?
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
02-01-2012, 02:40 PM | #370 |
only know its for genIV and loaded w/cable TB. but think it's a truck intake.................I think.
it's not like I really need to go efi....was just the best way to come together on a trade. funny....was just getting the a/f dialed in with the smaller carb...though it would never be as efficient as it would with a computer managing the fuel.
02-09-2012, 11:01 PM | #371 | |
'69 Chevy SWB
Any updates? I'm looking in to an LS swap in my truck and your build has a lot of info in it.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
02-09-2012, 11:13 PM | #372 |
what do you need to know? The truck runs and drives fine...just not as efficiently as the efi would be
on the efi... waiting for the guy to get thru with the harness and the tune and ship it all to me. I keep thinking if my intake was a single plane I'd just get the boss's drilled and tapped and toss a big throttle body on top. May wind up there someday tho...who knows.
02-10-2012, 12:41 AM | #373 |
Just think 4150 style throttle body on single plain efi manifold.........There is a guy on here with that set up and it looks great.
02-10-2012, 01:03 AM | #374 |
except mines a dual plane....
02-10-2012, 03:42 PM | #375 |
I know it is. I was just going with the idea of using the edelbrock manifold. So it will look similar still. Could prob find one used on ls1tech cheap
