02-26-2014, 11:32 AM | #351 | ||
Re: Project "Captain Insano"
I'm not trying to say the Teflon tape doesn't work. I've seen the tape get cut up because of the threads. With something that flows as easy as air, those tears may allow air to pass faster than the liquid. I'm also not saying the liquid will fix all problems, as I still have a problem with one bag. Just a suggestion to possibly help. As for temperature, it might have a slight effect on the overall height, but we've had 30 and 40 degree highs for a couple of weeks and back to 60 and 70 degree highs for a few days, then cold again. I haven't had to touch the 3 bags that sealed well since mid January. I have filled the one leaky bag twice in that time. The slow leak may not be in the bag fittings either. I don't know how your air management plumbing is set up so I can't speak to the other parts of your system. I have heard that if your air line isn't cut perfectly straight, it could cause leaks in a push-to-connect style fitting. It's really hard to chase a slow leak like that so if you're okay with it, I'd leave it alone. Looking forward to seeing the body come together! It sounds like you're moving right along nicely. Keep it up!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
02-27-2014, 02:13 PM | #352 |
The first measurements were my error. They've been aired up now, I put a small mark so I can measure from the exact spot and I kneeled down to see for sure. The front has stayed up. The rear, 1 side dropped 1/16" and the other side 1/8". I made clean cuts with an exacto-knife, however, I put a small chamfer on the insides incase of any burrs. I'll recut the rears without chamfering to see if that helps.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
02-27-2014, 02:36 PM | #353 |
I just looked at my first post on this thread, I almost forgot what this truck looked like when I first got it. Crazy, doesn't even look like the same truck anymore. Ha!
03-02-2014, 08:40 AM | #354 |
What are you doing about lock up on the trans? Are unusing a togel switch for the converter?
03-02-2014, 09:14 AM | #355 |
I'm in the same boat as you right now. I haven't wired it up yet. I plan on doing that today. I won't be using a switch though, just wired. I'll post up how I do it once I get it done. I hear it's simple.
03-02-2014, 12:05 PM | #356 |
What is the difference of a switch and just wired?
03-02-2014, 12:34 PM | #357 |
I'm learning this as I go. I think if it's just wired, it's just a power & ground hook up and it locks up just in 4th. I think some people hook a switch up for 3rd gear lockup or for towing? I believe you can do a manual switch or vacuum switch.
I'm in the middle of finishing up my exhaust, I'll be getting online tonight to read up more on this.
03-15-2014, 10:24 AM | #358 |
I have been working on getting my exhaust to exit out the rear behind the tires. I think I need to bring the piping up higher and come back down with the tips. I have some more bends on order, will be here Monday, so I moved back to working on the bedsides. I'm getting the inside lower parts sprayed with bedliner. Got one done last night, about to start on the other one. I'll have pics of them later tonight or tomorrow.
03-15-2014, 10:47 AM | #359 |
67cheby
looking good ! nice work bringing the exhaust out !
03-15-2014, 11:00 AM | #360 |
Thanks. It's almost too much work than its worth. I'm determined to get those dang tips out the back.
03-15-2014, 11:16 AM | #361 | |
Progress is excellent regardless.
03-15-2014, 02:12 PM | #362 |
Laid Back
Looking good Daniel!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
03-15-2014, 02:19 PM | #363 |
67cheby
we did it on Square Peg so I can vouch for the amount of work that it takes to accomplish this task !
03-15-2014, 07:27 PM | #364 |
Still Learning
Very nice work on the exhaust Daniel. I still want to the same on my
Exhaust. |
03-15-2014, 07:44 PM | #365 |
I really like the stance of your truck... I really like the way you have done the exhaust...
03-15-2014, 09:51 PM | #366 |
Nice job on the exhaust so far, will look really nice when your done with it. Looks good with the bed on too.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
03-15-2014, 10:51 PM | #367 |
I haven't thought of that, thanks.
03-15-2014, 10:52 PM | #368 |
03-15-2014, 10:56 PM | #369 | |
I better get back out there and get to work. Your laying down some paint, so I've got some catching up to do!
03-15-2014, 11:02 PM | #370 |
Thanks. Since I was 17, I've had an 86 Camaro, 87 mustang, 98 sierra, 93 mustang, and 01 Silverado and all I had dumped before the axle. So, this build I wanted to do something different. I think it's going to turn out cool.
03-15-2014, 11:04 PM | #371 |
Thanks. I'm pretty much ready to lay down some paint on the inner bed, doors, etc but this weather isn't consistence at all!
03-15-2014, 11:07 PM | #372 |
03-15-2014, 11:17 PM | #373 |
Still Learning
The bedsides look great. Looks like you will be shooting paint soon too.
03-19-2014, 12:59 PM | #374 |
Subscribed.
I've always liked truck with the old "Chevelle" Style exhaust. (Kinda aimed down) That'd look killer
69 c10, mild 350, TH400, LWB......Starting build 3/14 |
03-31-2014, 10:35 PM | #375 |
I got one side of the exhaust finished. I brought it up out of sight, then back down. I have more bends coming in tomorrow for the other side.
I had this wild idea that I would be ready to paint the insides of the bed, fenders, and doors, but I didn't realize the passenger fender was so beat up.
