Old 03-19-2018, 07:27 PM   #351
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
My Daughter is happy with it plus it matches the interior pretty good!
Build
67 Green Gobblin
http://67-72chevytrucks.com/vboard/s...d.php?t=688755
6t9camaro is offline   Reply With Quote
Old 03-20-2018, 12:09 PM   #352
shoveldug
Great work! Very talented!
shoveldug is offline   Reply With Quote
Old 06-27-2018, 09:26 AM   #353
ilikethewoods
ilikethewoods's Avatar
One of the greatest builds on this forum!! I have this biscuit booked marked!
ilikethewoods is offline   Reply With Quote
Old 10-13-2018, 08:06 PM   #354
waynep
waynep's Avatar
this build is amazing. wow!!! This really makes me want to get out in the garage!!
waynep is offline   Reply With Quote
Old 10-15-2018, 05:47 PM   #355
6t9camaro
6t9camaro's Avatar
I took a break from the truck and posting for quite awhile! I just wasn't happy with the build and the direction it was going. I completely tore the truck down and pretty much started over. Here are the last few pics from before I took a break a few months back. Kind of a shame since it was running and almost ready to drive other than the box/back half needing to be finished.
Build
67 Green Gobblin
Old 10-15-2018, 05:53 PM   #356
6t9camaro
6t9camaro's Avatar
More teardown! My kids took over the bench and used the truck as a hangout for a while until I figured id better get back on track with it! Stripped it and took out the frame to maybe use on another project?
Build
67 Green Gobblin
Old 10-15-2018, 06:16 PM   #357
6t9camaro
6t9camaro's Avatar
Here's where the direction changed for me! I picked myself up a set of powder coated transits with new rubber for another project and decided I wanted a big wheel for the C10. In order to put a 22" wheel and slam it the way I really wanted to do in the first place required more suspension work than I had done. So after doing quite abit of research I decided on Choppin blocks complete front crossmember kit and rear back-half kit.
Build
67 Green Gobblin
Old 10-15-2018, 06:20 PM   #358
6t9camaro
6t9camaro's Avatar
Picking up the Choppin block stuff!
Build
67 Green Gobblin
Old 10-15-2018, 08:50 PM   #359
6t9camaro
6t9camaro's Avatar
Now to the good stuff! Unpacking and checking it out! Choppin blocks quality is pretty awesome and I'm very impressed. I ordered pretty much everything they offered (at the time) heres a few pics.
Build
67 Green Gobblin
Old 10-15-2018, 08:53 PM   #360
6t9camaro
6t9camaro's Avatar
Front/Rear
Build
67 Green Gobblin
Old 10-15-2018, 08:55 PM   #361
6t9camaro
6t9camaro's Avatar
Battery boxes, Trans crossmember, E-level sensor clamps.
Build
67 Green Gobblin
Old 10-16-2018, 09:15 AM   #362
Bennett68C10
Bennett68C10's Avatar
Nice direction your taking with it. Can’t wait to see the outcome!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-16-2018, 03:56 PM   #363
Mykids69
Do you have any interest in re-homing the upper and lower modified stock control arms?
68' C20 Custom Camper 350ci/turbo 400 Mine
69' C10 long bed 380 hp 350ci/turbo 400 Son's
70' C10 long bed Orchard Barn Find Project Sold
Mykids69 is offline   Reply With Quote
Old 10-16-2018, 08:55 PM   #364
slowcpe
slowcpe's Avatar
Nice collection of parts
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 10-18-2018, 04:12 PM   #365
6t9camaro
6t9camaro's Avatar
Message sent!
Thanks!
Build
67 Green Gobblin
Old 10-20-2018, 07:32 PM   #366
6t9camaro
6t9camaro's Avatar
So I picked up a parts truck (72 3/4 ton 292 4 spd) awhile back and figured since I needed a set of frame rails it would be a good donor. Front rails were really nice and straight but the rear section under the box were shot from years of hauling some type of fertilizer/chemical tank? Kind of a shame to dismantle a running driving truck but it gave up some good parts and was worth the teardown.
Build
67 Green Gobblin
Old 10-20-2018, 07:41 PM   #367
6t9camaro
6t9camaro's Avatar
Got the frame rails back to the garage and started fitting up and trimming the rear section to fit. Drilled quite a few holes and got it all bolted in and mocked up.
Build
67 Green Gobblin
Old 10-20-2018, 07:47 PM   #368
6t9camaro
6t9camaro's Avatar
Once the rear was in place I started on fitting the front crossmember. Bolt holes lined up well and squared up the frame.
Build
67 Green Gobblin
Old 10-20-2018, 07:54 PM   #369
6t9camaro
6t9camaro's Avatar
Fit the rear air tank and cleaned everything up so i could get a good look!
Build
67 Green Gobblin
Old 10-21-2018, 02:40 PM   #370
ryans69chevy
You have some awesome skills! Where are you in ND? If you are close, it would be cool to come check your build out in person.
ryans69chevy is offline   Reply With Quote
Old 10-22-2018, 08:33 PM   #371
6t9camaro
6t9camaro's Avatar
Thanks! Builds actually going on up in Manitoba Canada.
Build
67 Green Gobblin
Old 10-24-2018, 02:17 PM   #372
Janz99
Who's doing the work on it?
Janz99 is offline   Reply With Quote
Old 10-24-2018, 03:25 PM   #373
redneckgames
Love this thread. Just now was able to read it all. You do good work!
redneckgames is offline   Reply With Quote
Old 10-24-2018, 04:38 PM   #374
6t9camaro
6t9camaro's Avatar
[quote=Janz99;8370874]Who's doing the work on it?
No shops just me.
Thanks!
Build
67 Green Gobblin
Old 10-24-2018, 05:45 PM   #375
6t9camaro
6t9camaro's Avatar
I decided to Mock up the engine and trans to see where everything would sit now that its together with the new cross members. I was really happy with how everything lined up and had decent clearance. The headers even fit perfect on the drivers side but did need a little tweaking on the pass side.
Build
67 Green Gobblin
