03-03-2021, 12:26 AM | #351 |
Re: '72 Cheyenne K10
I need it for photos like this.
03-09-2021, 04:34 PM | #352 |
I dropped the extra transmission and transfer case (that came with the truck) off to get rebuilt. Once I get them back I will swap both into the truck.
03-23-2021, 09:54 PM | #353 |
I mounted some KC Hilites spread beams on the lumber rack. Wired to the relay, but I need to finish wiring the switch.
04-08-2021, 03:15 PM | #354 |
Transmission and transfer case are back from the shop
04-09-2021, 10:00 AM | #355 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
04-09-2021, 07:53 PM | #356 |
The fun has begun! Old transfer case is out of the truck.
04-09-2021, 10:46 PM | #357 |
Got the crossmember out too.
04-10-2021, 03:47 PM | #358 |
The fun continues...
The super greasy crossmember and torque mount are all cleaned up, and the old transmission is out. The people at Locktite should know that their product works for decades. |
04-10-2021, 06:09 PM | #359 |
I believe many thread lock compounds transform into rust-tite after a number of years.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-10-2021, 07:28 PM | #360 |
At least it wasn't gonna fall out. LOL
04-12-2021, 09:46 PM | #361 |
I think I have everything ready for install. New bolts for everything, 3 gallons of ATF, and all the old parts are cleaned up. Tracking says new cooler lines, kickdown cable, poly transmission/torque mounts, and gear oil will be here tomorrow.
04-15-2021, 01:19 AM | #362 |
I got the transmission and transfer case installed today. Column shifter, speedo cable, rear driveline are all hooked up. Fill tube and kickdown cable are installed. I need to hook up the transmission cooler lines (I have some found conflicting info on which line goes to which fitting on the radiator). And I still have to fill up the fluids.
But my main obstacle is that the twin stick shifters do not line up with the factory hole in the floor. They need to be forward and right of where they are. The website said GM NP205, but it wasn't specific about compatibility with a '72. I'm guessing it is designed for '73 up. I hope I can find a fabricator to help me modify these stainless shifters to make it work. I have it stuck in RWD HIGH without any shifter for now. At least I will be able to drive it. |
04-15-2021, 02:08 PM | #363 |
The manufacturer of the twin stick has offered to modify the handles at no charge. That's what I call customer service!
I assembled it the best I could to take more pictures and measurements for him. |
04-16-2021, 06:51 PM | #364 |
Bad news. I filled up the transmission and went for a drive around the block, and it leaks really bad from the servo. The person that rebuilt it says he will fix it next week, but it's a real bummer. It leaked a tiny bit after filling, but it was squirting out profusely while driving. Left an obvious nasty trail of fluid behind on the road too.
04-16-2021, 08:11 PM | #365 | |
04-23-2021, 07:07 PM | #366 |
Darn. The modified shifter handles showed up today, but they are not going to work. They still hit the opening in the floor and can't be shifted. He's on vacation for 2 weeks, so I have to wait.
04-23-2021, 07:40 PM | #367 |
Darn 2 weeks. Isn't that the way it always goes. I think I'd have to modify them myself. Truck is looking awesome man! I love seeing an old survivor out there still working away!
04-24-2021, 05:03 AM | #368 |
Sorry it’s taking so long- bummer
71 C10 72 K20 72 K10 Super Kirk |
04-27-2021, 01:05 AM | #369 |
Transmission leak is fixed. Just a broken o-ring. I went to the parts store for ATF and he had it fixed when I got back. We spent more time talking and drinking a beer.
Got a couple new stickers today. |
04-27-2021, 07:57 PM | #370 |
No mystery why this o-ring was leaking
04-28-2021, 06:43 AM | #371 |
I thought an o ring didn't have ends!!
05-05-2021, 05:01 PM | #372 |
Two wheel drive got me out to where I needed to work on the disc golf course today.
05-13-2021, 11:45 AM | #373 |
Third time's the charm. The modified handles work great. Now I have RWD, FWD, and 4WD in high or low range. Pretty darn cool.
05-14-2021, 07:10 AM | #374 |
They look good, my little brain would screw it up if I had them.
05-28-2021, 12:20 PM | #375 |
Jim it was great meeting you yesterday. Thanks again for the adapter!
Tags |
ochre |
