06-13-2022, 07:06 PM | #351 |
Re: 1969 C20, CST. 396, 21,000 mile documented Survivor
I believe it was a legal requirement that they had to have at least a driver rear view mirror, but I cannot recall when they started "safety" inspections, but it was in the 60's I think. I am showing my age, but I can remember when it became law that pickups had to have two taillights as my dad had a 59, and originally it only had one on the driver side (no turn signals, the driver used arm signals out the window. When it became law and inspections came along in MO dad mounted a piece of angle iron and mounted a second passenger brake light.
06-13-2022, 08:22 PM | #352 |
Who Changed This?
Minimum of two mirrors started in about '64, IIRC. Prior to that, only an inside rear view mirror was required. I think it was about '60 when heaters were mandatory. I worked at a shop in '76 and was driving the shop car ('58 Fjord wagon) to pick up the owner after we delivered a customer's car. It had no heater or defroster. It was raining cats and dogs, so I had the driver's door window open to air the car out, and someone drove by and splashed water into the car. There I was with a dirty shop rag, "drying" the windshield on the inside.
06-13-2022, 09:46 PM | #353 |
Ok so here's what I don't understand. This truck is a Z84, CST. It states right here CST trucks came with a cargo light. This one like I said is just the outside bezel, no lamp fixture and no hole in the cab.
The other mystery is being a CST truck there should be a headliner, there is not. |
06-13-2022, 09:47 PM | #354 | |
06-13-2022, 09:50 PM | #355 |
06-13-2022, 10:24 PM | #356 | |
06-13-2022, 10:59 PM | #357 |
Who Changed This?
I've seen where options have showed up mid-year, in production. Maybe that's what happened with this truck?
06-13-2022, 11:00 PM | #358 |
How would I get the SPD or scheduled build date?
06-14-2022, 12:22 AM | #359 | |||
My post #130 of the thread you are reading should help answer most of your questions. http://67-72chevytrucks.com/vboard/s....php?p=9074777
Jim Last edited by FirstOwner69; 06-14-2022 at 12:53 AM. |
06-14-2022, 12:46 AM | #360 |
Dave...
At this point, I'd bet the deluxe side marker lights are not original on this truck either. Do yours light when the headlights are on? The original markers on my early December '69 were not lighted and not the deluxe style. The deluxe versions like yours were only made with lights. Here is a picture of the front and back of the original markers from my CST/20. I also replaced mine with the deluxe version and got the appropriate wiring from a 1970 junkyard truck.
Jim Last edited by FirstOwner69; 06-14-2022 at 01:31 AM. |
06-14-2022, 08:20 AM | #361 |
Jim as I stated in an earlier thread the top lens is lit, the bottom portion is just a reflector. On all four.
06-14-2022, 08:27 AM | #362 |
Roadtrip!
I used to own an early 69 cst 1/2 ton that did not have a cargo light or headliner. The early headliners were perforated. I am not sure on the dates these happened.
I also have a set of cst side marker lights with no light provisions in them.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-14-2022, 05:30 PM | #363 |
Where would I find the build month/day???
06-14-2022, 05:41 PM | #364 |
If the truck doesn't have a paper build sheet tucked under the seat springs, then you can get a pretty good estimate of the build date by comparing its VIN to the VINs listed in this thread:
https://67-72chevytrucks.com/vboard/...5&postcount=64 |
06-14-2022, 06:55 PM | #365 |
Which digit am I looking at?
06-14-2022, 06:57 PM | #366 |
The previous owner replaced the fuel tank no sheet was found. Nothing under either bucket seat nothing under front carpet pulled back as far as I could reaching in with my hand. Glove box liner removed nothing behind the dash.
06-14-2022, 07:01 PM | #367 |
Looks like Flint (F) doesn't have a good representation of 69 Chevys on the Build Date Project. Bummer. You might be able to get a rough idea from the window date codes.
https://67-72chevytrucks.com/vboard/....php?p=9081761 |
06-14-2022, 07:18 PM | #368 |
I'll snap a good photo of the glass codes here in a second and post it. Thanks for the idea!
06-14-2022, 07:18 PM | #369 |
AFAIK all deluxe side markers only light up on the top half
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
06-14-2022, 08:25 PM | #370 |
All Glass in this truck is original LOF. Here are two picks from the drivers vent window and drivers window. Driver side vent window.
06-14-2022, 08:28 PM | #371 |
Driver side glass.
06-14-2022, 08:28 PM | #372 |
Based on that thread I linked above, YX = October, 1968.
06-14-2022, 08:29 PM | #373 |
Stamping on the windshield is directly below edge of passenger wiper arm corner of glass.
06-14-2022, 08:30 PM | #374 |
Rear glass stamping is directly behind driver bottom corner.
06-14-2022, 08:31 PM | #375 |
So this truck was built within the first 3 months of production 68?
