Old 05-03-2016, 01:27 AM   #3776
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well it's been like Amateur Hour over here on Team Shake 'n Bake I tell you, check out these spark plug gaps, this is rediculous
5 at .040" like they should ought to be was
2 too big, bigger than .045"
and 1 too small, way too small, about .030"
this team needs to shape up I tell you what Stu
OBSERVATION: 1-6 look the same blackish/border line rich, 7-8 look lighter, a bit leaner
Gregski is offline   Reply With Quote
Old 05-03-2016, 01:32 AM   #3777
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
and to add in salt to injury, check out how high my feeler gauge goes up to, ha ha, .035 man GM Gods sure have a sense of humor - had to resort to the goofy wire style one I swore I would never find a need for, lol
Old 05-03-2016, 01:49 AM   #3778
Woodyboat
Woodyboat's Avatar
Re: Restoring Rusty
Originally Posted by Gregski View Post
... I wipe it with my finger, and it looks like trans fluid, feels like trans fluid, smells like trans fluid, and tastes like trans fluid.
WOW! I'm sure glad you didn't step in it!!
If you haven't figured this out yet, I'm reading the entire thread from start to finish. I love it.
Woodyboat is offline   Reply With Quote
Old 05-03-2016, 07:17 AM   #3779
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
I would run through the valve adjustment again, it is acting like they are a tad too tight.
Jake Wade is offline   Reply With Quote
Old 05-03-2016, 08:35 AM   #3780
enaberif
Re: Restoring Rusty
Spark plug gap on a HEI Chevy should be .045 as .030 was for a points system. Yes using the wrong gap will make a vehicle run like absolute crap. When I put plugs in my truck they were gapped for .030 and I could not get it to run properly no matter what.
Also doing vac gauge measurements I am pretty sure it should be on manifold vacuum not ported vacuum as should your distributors vacuum advance to get optimal performance.
enaberif is offline   Reply With Quote
Old 05-03-2016, 09:53 AM   #3781
blazer2007
Re: Restoring Rusty
I was just curious why the engine would overheat with the heater lines plugged,my big block is capped and it runs fine.Is your style engine have a different water gallery set up that would cause that?
blazer2007 is offline   Reply With Quote
Old 05-03-2016, 09:59 AM   #3782
Oberon67
Re: Restoring Rusty
I been looking at your photos... y'all gonna have to change that truck's name.
Oberon67 is offline   Reply With Quote
Old 05-03-2016, 10:24 AM   #3783
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ha ha, I said that, hmmm, thank you so much and enjoy the read
Old 05-03-2016, 10:26 AM   #3784
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Hi Jake, I agree about the valves needing an adjustment, not sure if they is too tight, as I am not that good at diagnosing them, but I will definitely check them today and report back
I do hear a tick and to me it sounds like one may be loose sounds like it is a comin' from the passenger side, here's the absolutely crazy thing though, it sounded exactly precisely the same before I did the top end swap/job, in other words the old heads aka the old valve train was generating the exact same tick (lets just keep that in mind as if it may turn out to be something else, something silly, like a bolt sticking out and tapping a firewall or something crazy like that)
Old 05-03-2016, 10:35 AM   #3785
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
interesting, we are going to try all on .040 as per the GM Performance Spec sheet, but may bump it up to .045 as you recommend if needed
it is
Old 05-03-2016, 10:37 AM   #3786
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
my best guess is that something is wrong, we have not truly found the source of the problem yet, I agree that it should run without the heater core, and without the bypass hose from the intake to the water pump
let me get passed this vacuum issue and then I may try a different water pump, and maybe a more than single core radiator after that, maybe go aluminium
Old 05-03-2016, 10:50 AM   #3787
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ha ha, not just yet, we still have to tackle the kick panels inside the cab and pull the dash completely out to see what lurks behind it (Winter Project?)
Old 05-03-2016, 11:44 AM   #3788
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I used to run .060 gap with a Jacobs Mileage Master multi spark setup on my 1985 5.0L C10. She ran nice and smooth. That or an MSD6AL is about the only aftermarket coil system I would use because it doesn't bork the stock ignition module. The mileage gains were not enough to make the price worthwhile.
Run the gaps as wide as you can get away with it lights the fuel better. .045 is a good number for stock HEI with a new Delco coil and Ignition module.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-03-2016, 11:48 AM   #3789
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
well, gapped the plugs this morning to .040 (for starters) and warmed him up for 10 minutes, and then tested with the vacuum gauge again, and no change needle is still jumpy, dang
valve adjustment coming up next after my dentist appointment
Old 05-03-2016, 11:52 AM   #3790
68post
Re: Restoring Rusty
Dentist appt. !! Don't take it out on poor Rusty, he has to be worried now.
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 05-03-2016, 11:52 AM   #3791
jwilson645
Re: Restoring Rusty
Can't you combine the .035 and .010 to get to your .045? That's the way I was shown by my dad when I was learning engine stuff.
jwilson645 is offline   Reply With Quote
Old 05-03-2016, 11:56 AM   #3792
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thought about it, but they have some heavy lube on them so that probably will add thickness to it, so I just used that wire wheel one, I may pick up a proper feeler gauge set today, I like decent measuring implements when I can afford them
Old 05-03-2016, 12:14 PM   #3793
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ha, ha, Rusty is about to meet the 3 lbs sledge if he don't shape up real quick!!!
Old 05-03-2016, 01:16 PM   #3794
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
What vacuum can are you running? That can make the engine throb like that, although that is usually on the low end of vacuum, not the high end where you are.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-03-2016, 01:26 PM   #3795
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
hi Rich, what can are you talking about? if the one on the dizzy than I am not using that during the test, its like setting initial timing, no vacuum advance
Old 05-03-2016, 01:58 PM   #3796
rich weyand
Re: Restoring Rusty
No, it's not like initial timing. You need to tune the carb with the vacuum advance hooked up. There's your problem. You are running a way-too-late spark.
Rich Weyand
1978 K10 RCSB DD.
Old 05-03-2016, 02:45 PM   #3797
enaberif
Re: Restoring Rusty
1) Initial timing = vacuum advanced unplugged
2) Mechanical Advance = How much your distributor pulls with weights and springs
3) Total Timing = Initial + Mechanical @ 2500-3000 rpm
4) Carb tuning is 1-3 setup PLUS vacuum advance
Vacuum advance is there to help with idle and cruise and can help with MPG
Old 05-03-2016, 04:49 PM   #3798
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Koogle Mooglie, lemme re test than, and get back atcha all
Old 05-03-2016, 04:53 PM   #3799
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
decided to do a compression test before doing a valve adjustment, it's always good to have a baseline
man I was so bummed to find out that my trusty ol' compression gauge was not working, it read 0 for the first 4 cylinders
so rented one from AutoZone for $40 bucks (which they refund you if and when you return the tool) before Pontiac Mike told me to check the Shrader valve on my old hose, and sure as sheet the cheapo tiny valve is bad, so that tells me my gauge may be good after all
Old 05-03-2016, 04:55 PM   #3800
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
man my cylinder pressure looks great, #1 and #2 were initially low but retested great
I always like to test twice once 1 through 8 and later on after re warming up the vehicle 8 through 1
