#3826 | |
Re: What did you do to your truck today.The 3rd chapter
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#3827 |
![]() ![]() Join Date: Jan 2005
It's a 4L60 (700R4) out of a 1993 Caprice at Pick-N-Pull. I rebuilt it with the help of an instructional video I purchased from Monster Transmissions. Used a TCI kit. Replaced some of the larger hard parts that are known to be problematic with heavy-duty versions.
#3828 |
68 C10 Longbed
![]() Join Date: Sep 2006
Got the first front end alignment on the 68 today. It’s coming together. Steering wheel nice and straight.
#3829 | |
#3830 |
![]() Join Date: Jun 2022
got the shorter hoses clocked correctly, and their ends ground down to fit in the brackets. I've been 3h away from bleeding my brakes since Thanksgiving.
THIS TIME FOR SURE!!!! |
#3831 | |
![]() Join Date: Feb 2002
I have thought about a stoutly-rebuilt TH700-R4 to replace the TH350 in White Fang, my '67 K/10 Suburban, but that's a long way off. I know you're about one wrench-thru-the-garage-drywall-in-frustration from re-rigging for Manual Transmission. And you're contemplating the T-5 five-speed. I'm not a fan of that unit. A friend had one and we replaced it 3 times one year. In my opinion it's too wimpy in a Truck. For my money, I'd get a New Process A833 5-speed [or 4+OD]. They were more of a MOPAR tranny, but some mid-'80s Squarebody light duty pickups were optioned with them. The Holy Grail of transmission hunts now. ![]()
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-24-2023 at 05:16 PM. |
#3832 | |
https://67-72chevytrucks.com/vboard/...d.php?t=822382 |
#3833 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Took my truck for a wheel alignment today as everything was replaced in the front end. First drive of any distance , just a couple miles to the alignment shop, since te refurbish and what a difference in the way truck drives. Pic is the alignment specs which the tech started going over with me and I told him I'm clueless as to what he's talking about although he said everything was great as far as alignment and suspension went. I'm sure there are folks on here that can relate to the alignment specs.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#3834 |
![]() Join Date: Dec 2012
Not today - but visiting a chassis shop tomorrow morning to begin plans on joining those who have lowered their trucks. Going to see what the options are, and to probably include a disc brake upgrade up front.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#3835 |
struggled unsuccessfully to get the brake lines clamped to the xmember.
Going to punt on this, get the lines bled and leak tested, then drive the ***** up on ramps to secure those lines with some damned room to work |
#3836 |
had this little guy recreated for my truck
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#3837 |
68 C10 Longbed
Changed the rear end fluid. Checked axles seals and all dry so the 12 bolt is good to go.
#3838 |
#3839 |
if you don't have the SPID or buildsheet under the seat, then you can still create one based on what your truck's details and options are, along with the VIN. It will be probably really close, or at minimum what you want it to show. If you don't already know, you might get fully educated on what all the options were available. It'll be more of a crap shoot on a few items like tires, gearing, etc. Either way, it's easy to determine what the manufacture list prices were on every item.
#3840 |
I hate working on hoods .
#3841 |
Managed to mount the radiator overflow tank and PS reservoir, today. Waiting on a couple of 90 degree fittings so I can connect the last PS hose.
Posted via Mobile Device |
#3842 |
Inside painted
#3843 |
![]() ![]() Join Date: Jul 2002
Finally finished the install of the 84 Suburban 31 gallon gas tank
#3844 |
![]() Join Date: Aug 2018
Went in for an inspection, rolled out with an oil change, recharged air conditioning, and topped off fluids.
#3845 |
Detailing - cleaned all the window rubber gaskets and polished all the window brightwork. Good for another 51 years
#3846 | |
#3847 |
At the body shop.
Fresh layer of penetrol.
" That didnt make it any newer " " Dont antique the equipment " |
#3848 |
68 C10 Longbed
Took driver side door apart and installed new glass and track, lubed up channels and coated bottom inside of door with POR15. Also added correct spacers to window crank and door handle. Window and door operate as they should now.
#3849 | |
#3850 |
Found the cranking problem with the 72 . Couple of messed up teeth on the flex plate . New one is on the way should be here tomorrow.
