#3876 |
Re: What did you do to your truck today.The 3rd chapter
The saddle fawn poly that’s on my stepper is a little lighter and has more metallic than the anniversary gold .
#3877 |
Attended the C10 Truck Show in Enumclaw, WA. 200+ C/K-10's from all around the PNW. Found my "taller twin". The red/white '72 took best 67-72. I'm pretty certain this truck has every conceivable option and all items are original, though not factory on this truck.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#3878 |
Who Changed This?
![]() Join Date: Jan 2013
Took some turpentine and paper towels to the engine to get a bit of the oily guck off of it. I'll get it a bit at a time. Not big on pressure washing, and the caustic cleaners have only the storm drains to go to, so that's out.
#3879 | |
![]() Join Date: Feb 2002
#3880 |
![]() Join Date: Mar 2011
radio in........ Thank God the PO didn't cut any deeper
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#3881 |
![]() ![]() Join Date: Jan 2005
Cleaned and painted a set of under-seat brackets for the jack handle and lug wrench. These are for buddy bucket seats. The passenger seat doesn't slide forward, which makes it difficult to access the cab corner stowage locaton.
#3882 | |
I just hide a Farm Jack under the in-bed tool box.
#3883 |
#3884 |
There is a swap meet and car show about 1.5 hours west of me and plan on taking my truck up this year. Not to be in the show, of course, but will be its first trip over an hour in one direction. SO, I had a short list on the white board in my shop (yes, I have a white board where I keep lists of things to do) to run down before the trip. Since I will be out of pocket this weekend and in Iowa the entire week following I knocked the list out over the weekend.
Checked front wheel bearings. Checked tire air pressure. Greased front end and drive shaft. Checked gear oil in transmission and rear differential. Checked lug nut torque. Checked brake fluid. Checked coolant level. Changed oil and filter.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#3885 |
Sorry, double post
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra Last edited by 67C10Step; 06-05-2023 at 04:31 PM. Reason: Double post |
#3886 |
Painted the cowl and fender . My make shift spray both worked great
#3887 |
#3888 | |
I took off the under/bed spare carrier off a few years ago to mount a Class III hitch. I will need longer threaded rods to mount the 235/85/R16s I'm running now. If the carrier clamps too tight, it will spill the air at the bead seal, and you find you've been carrying a flat spare since forever.
#3889 |
Picked up an LQ4 for my 67 build this weekend.
#3890 |
#3891 |
I got the drivers side bearings and brake shoes done . I put the races in the chest freezer overnight a couple of light taps and they were seated it’s the only way to go. Specially with the big inner bearing race everything went together nicely no profanity involved . The passenger side is tomorrow I checked the fluid and there are no metal shavings so the bearing that was on its way out didn’t contaminate anything . Verified it’s a 4.10 and it was made 8-28-71 so it’s most likely original .
#3892 |
Installed a set of under-seat jack handle/lug wrench mounting brackets.
#3893 |
Looks nice, Pat.
Personally, I prefer the cruciform type for better leverage and a two-handed grip, and you can spin the nut once it's loose, and spin it on. But I see where you're going with your Stepside -- back in time.
#3894 |
pj, nice and thanks for the photo. I still have all mine from my 67, just have not re-installed and I didn't take a good photo when I pulled it all out. This should help a bunch.
#3895 |
So that’s what those brackets are for . I’ve been scratching my head as to what they did
#3896 |
#3897 |
Got the 72 back together and was doing a check on the drivetrain and found a bad ujoint at the pinion. I had checked the ujoints for slop but I got no movement but visually you could see they were shot , I had changed them all 4 years ago when I did the carrier bearing with inexpensive ones from autozone won’t be doing that again , when I the shaft off the ujoint just fell apart . Guess I found the vibration . Going to do all four
#3898 | |
#3899 | |
#3900 | |
Well at least I averted a problem with the bad wheel bearing . I’ll feel better now when the wife is driving the truck .
