#376 |
Re: Junkyard Jimmy Super Low Buck Build Thread
this is a nice build glad to see progress now get that jimmy in to the garage
#377 |
2wd FTW!!!!
This build is one of my favorites. Just one question though, are you using anything from the original jimmy that started this thread???? J/K keep up the good work.
#378 | |||
GEARHEAD
Looks like selling one of the tops is out of the question until spring. No way to get to them now with all of the snow we've had already. It's snowing now again. ![]()
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#379 |
well i know how it feels to have yor project out in the elements and tarps that dont seem to work
#380 |
nice work, keep pictures of progress coming
#381 | |
GEARHEAD
Thanks, here's "sort of" progress... ![]() Parked by my C-10. I believe this is the only time I've had 2 trucks of this body style together in the garage. Just for a few days though. ![]()
#382 |
well glad you got it in the garage
#383 |
It is starting to shape up! I think you are turning that corner that is in every project where tasks seem to take forever to where they start going really fast.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
#384 | |
GEARHEAD
Me too.
Like today, Heads are installed, valve train is installed, intake installed. Unfortunately, I had to remove the headers, and the driver side one couldn't really come out because of the oil dipstick. I tried to hold it out of the way, but just as I was finishing the torque sequence, it dropped and busted the dipstick tube. I'm hoping I can get the stub out with out having to take the oil pan off, but I'm not holding my breath. ![]() ![]() Checklist (at least what I can think of now): prime oil pump Distributor carb valve covers headers/exhaust spark plugs/wires power steering pump water pump alternator fan/pulleys fuel line radiator hoses temp sensor throttle gas tank filler hose tranny cooler lines plug un-used holes vacuum lines ground straps I'm probably forgetting something. If anyone spots something I missed, go ahead and give me a reminder.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-28-2010 at 11:44 AM. |
#385 |
It's looking good!
But just a watch out item for you. In the past several months, I've seen a few engines with these heads, Having water leaks in these weak areas front and back. Of coarse, All of them where on stock motors. Original gaskets. Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#386 | |
GEARHEAD
And for anyone wondering... I did clean the overspray off the gasket seating surfaces before the intake went on. I remembered something else for the check list too, prime oil pump. I added it to that post.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-28-2010 at 11:45 AM. |
#387 |
GEARHEAD
Sometimes, very rarely, I even amaze myself.
Remember I said the oil dipstick was busted off in the block? I fixed it without having to pull the oil pan. The mess (I did try to punch the side of the tube in to loosen it, it didn't work: ![]() First, you need the right tools. In this case, a set of ear plugs (foam with the attached lanyard), a 27/64" drill bit, a drill (either small enough to fit between the block and steering column/shifter linkage or an angle adapter to get you in there). ![]() Squeeze the ear plug down so it fits into the dipstick hole. ![]() Push the plug down using the dipstick or whatever, without pushing it all the way into the pan. Cut the string off a few inches from the top of the hole. Push the string down the hole at least past the stub that needs to be removed. Then get your drill set up so you can drill out the stuck tube. I chose to use a 27/64" bit because it will not jam as bad in the hole or bore it out at all and it's big enough not to really leave much of the tube inside. ![]() The drill worked great and the tube was cleared out. Then I used a fairly strong magnet to get as much crud out as possible. I put a smaller diameter bolt on the magnet, which is then magnetized, and put it down the hole a few times to clean as many shavings out as possible. When the bolt is removed from the magnet, most of the filings will drop right off. ![]() Then I used a small hook or probe to fish out the string. ![]() Then slowly pulled out the ear plug and all the rest of the grit with it (there wasn't much) ![]() That's it, job done. I think I am done using that style of dipstick. This is not the first time I had one bust off. They make tubeless style dipsticks that fit directly into the block that I think I will use from now on, depending on how they fit around the headers. Like this one from summit: http://www.summitracing.com/parts/SUM-G290/
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-28-2010 at 05:56 PM. |
#388 |
wow you are pretty good with jerry rigin!
#389 |
VA72C10
![]() Join Date: Mar 2008
nice work!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#390 |
GEARHEAD
Thanks, I think...
Thanks Look! All done! Not really, the only other thing I really got done yesterday was mounting the headers. The carb and valve covers sure makes it look more complete though. ![]()
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-29-2010 at 08:23 AM. |
#391 |
Did you make a decision on the distributor? I would go with an HEI. The performance upgrade over points will be well worth it. You won't have to worry about setting dwell, float or wear for points; you will have a hotter spark giving you better burn and the cost increase is marginal.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
#392 | |
GEARHEAD
Like this one: http://www.summitracing.com/parts/ACC-2010/ Or a dizzy like this: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT They have a matching coil for $20.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-29-2010 at 10:52 AM. |
#393 |
I miss this truck.
Boy, wouldn't some billet valve covers look nice on there with that aluminum intake and that Edelbrock carb?
Edit:...or are those? They look chrome from here. Admittedly, I'm not very good at know the difference in photographs.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. Last edited by Tynee; 12-29-2010 at 11:39 AM. |
#394 |
GEARHEAD
Just cheap chrome ones, $20 from amazon.com.
#395 |
GEARHEAD
The story of a water pump.
Once upon a time, there was a nice shiny new 1972 GMC Jimmy K-5. It had a 350 V-8 engine, which was a good engine, but over the course of many years of wear, tear, use and abuse, it bit the big one and died. The owner, who dearly loved his Jimmy, replaced the engine with a nice big, somewhat used, 400 cubic inch sbc. Eventually, this engine also died. And because the years had been long and hard (hee hee, head in the gutter there), the Jimmy had seen better days. So the owner sent the Jimmy to an appropriate resting place, where maybe it's bits and pieces could be used to help other old Jimmys make their way through more years of use. Some years later, a fool came along that was looking for parts for a Jimmy. A LOT of parts. He talked the nice (stoner) automotive rest home manager into selling hime the entire she-bang. The fool was thrilled, because he knew not what a mess he was getting into. He did manage to complete (sorta) his goal of having a running driving Jimmy for a meager amount of money. And he had a good time overall working on his Jimmy. Another engine was installed, which had just enough life left in it to frustrate the fool. He came to learn his lesson and so built another fine engine, which he installed. He worked diligently to make the Jimmy into something better than it had been for many years. The engine was treated with nice new shiny stuff and upgrades using the newest head technology GM had for the first gen sbc. By now, you are probably wondering what this story has to do with a water pump. Well finding a water pump is not that hard, and really isn't that expensive either. A nice shiny new water pump for a 1972 GMC Jimmy K-5 with a nice shiny new 350 cubic inch V-8 can be had for a paltry $15 at O'reilly's. Unfortunately, that pump will not work with the unknown style or vintage of alternator brackets. As it turns out, alternator brackets can be the limiting factor in many engine accessory set ups. The automotive resting homes routinely pull the engines and subsequently, the alternators and brackets as soon as a new resident is brought in. When they can be found, they can be quite expensive. So the best alternative is to have a set of brackets that work and have a water pump that allows them to be used. Unfortunately, that pump had to be ordered and will have to wait until tomorrow. I guess the story could have been titled, "About an alternator Bracket, Who did Not Play Well With a New Pump". Next I can tell a story about an intake manifold vacuum hose adapter...but that's for another day. To make a long story short, the water pump was bad, replacement not immediately available, which means waiting for the accessories to be mounted, which means no significant progress. Thanks for reading.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff Last edited by hgs_notes; 12-29-2010 at 11:47 PM. |
#396 |
VA72C10
sorry for the setback...but that was an entertaining read at least
#397 |
Good job on fixing the oil dipstick dillema.
#398 |
you thought correct! it was a compliment ,nice work on the engine! valve covers.....ooooohhhhhhh shiny!
#399 |
I miss this truck.
So, what did you wind up having to go with, instead of the $15 O'reilly's special?
BTW, I have a 1YO, and a 3YO. I just printed this to read at bed time. I'm calling it, "Ode to a Water Pump and an Alternator Bracket."
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#400 | |
GEARHEAD
They ordered a $20 special for me, cross referenced from the old pump I returned for a core. The O'reilly store is brand new and I had never been in it before. The manager was a young guy (early 20's), but very helpful and knew more than I had hoped.
