Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-16-2018, 10:38 PM   #376
60apache
60apache's Avatar
Re: Power Brake Booster Adapter Bracket
Originally Posted by Caudillo64 View Post
I just insalled mine easy bolt up no problems also looks good. Thanks.
what booster did you use?
60apache is offline   Reply With Quote
Old 04-16-2018, 11:29 PM   #377
Captainfab
60-66 Nut
You might have to send him a PM to get an answer to that question.
Old 04-22-2018, 05:21 AM   #378
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I need a vacuum boost bracket for a 64 and a hydroboost for a 63.
Old 04-22-2018, 11:12 PM   #379
Captainfab
60-66 Nut
I will send you a PM.
Old 04-23-2018, 02:33 AM   #380
pdxhall
pdxhall's Avatar
Hi John, I'd like to get one of your powder coated booster brackets for my '66, please.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-23-2018, 03:38 PM   #381
402GMC
I would like one of the booster brackets for my 66
402GMC is offline   Reply With Quote
Old 04-23-2018, 11:33 PM   #382
Captainfab
60-66 Nut
I will send you both PM's with ordering info.
Old 04-29-2018, 07:32 PM   #383
JasontheBeaver
Hey Captainfab, I'm looking to change my factory '66 brake master cylinder to a vacuum boosted unit. (still have drum/drum)
Will I need one of your brackets if I purchase one of these LMC kits?
Thanks for any guidance!
JasontheBeaver is offline   Reply With Quote
Old 04-29-2018, 07:34 PM   #384
JasontheBeaver
Old 04-29-2018, 07:49 PM   #385
JasontheBeaver
Ok, here's a pic, finally figured it out.
Old 04-29-2018, 11:36 PM   #386
Captainfab
60-66 Nut
If you want the booster and master assembly to be installed correctly as the GM engineers designed, then yes you will need one of my booster brackets. With a drum/drum braking system all you need is a '67-'70 booster and master cylinder assembly and one of my booster brackets to correctly and securely mount it to your firewall.
Old 04-30-2018, 11:30 AM   #387
JasontheBeaver
So I would need a master cylinder and booster from this page correct?
If I buy that setup then I would also need to find a proportioning/combination valve to route the two lines coming out of the new cylinder, correct?
The previous kit I linked included a combination valve, this one does not.
I've tried researching this prior to asking potentially dumb and/or repeated questions but there are myriad paths.
I just want as close to bolt-on as possible. I understand there will be rerouting of the lines, but I do not have the ability to do any welding or fabrication.
I appreciate your help man!
Old 04-30-2018, 11:27 PM   #388
Captainfab
60-66 Nut
The booster and master cylinder can be purchased at your local auto parts store. However if you do not have the means (or know someone that does) to lengthen the booster pushrod, you will have to purchase one of the aftermarket universal boosters. With a drum/drum brake system, you do not want nor need a combination valve. All of the power brake conversion kits I have seen from the big name parts suppliers are for either disc/drum or disc/disc braking systems. And what they are selling is a universal booster with universal booster brackets that require you to drill holes to bolt it up. And then it is not really securely attached to the pedal bracket.
Old 05-01-2018, 08:55 AM   #389
JasontheBeaver
Ok so in summary...
I go to the Napa store across the street and order a master cylinder and booster for a '67 c10 pickup, and I also order one of your brackets.
I'll also need to order a universal push rod because my existing rod is too short (lol).
Does the new cylinder have one outlet port like mine? If so then it's just a matter of running a new line from the port to my tee.
If the cylinder has 2 outlet ports then I'm assuming I remove the tee and run 2 new lines to connect to my existing ones.
Am I on the right track here?
Old 05-02-2018, 12:14 AM   #390
Captainfab
60-66 Nut
Yes you can simply buy the booster and master locally. You can buy a universal brake booster pushrod, but you do not have to. If you know someone that can weld or thread, the booster pushrod and your original pushrod can be cut to length and joined together by either welding or threading and using a coupling nut.
http://www.67-72chevytrucks.com/vboa...d.php?t=564518
It really is a good idea to split your brake lines and convert to a dual reservoir master cylinder. That is a much safer design. There are a thread or two here all about how to do that.
Ok so in summary...
Old 05-02-2018, 09:07 PM   #391
JasontheBeaver
So you know my next question... is the new '67 master cylinder that I'm going to buy a dual reservoir model? If not, then it sounds like I need to do further research to find one that will fit this setup.
Old 05-02-2018, 11:01 PM   #392
Captainfab
60-66 Nut
The '67-'70 master cylinders are of a dual reservoir design.
Old 05-14-2018, 08:57 PM   #393
Kustom64
I’d like to order one of these brackets! Could you PM ordering info to me? Thanks!
Kustom64 is offline   Reply With Quote
Old 05-14-2018, 11:32 PM   #394
Captainfab
60-66 Nut
Old 07-27-2018, 10:52 PM   #395
Budman56
Budman56's Avatar
Smile Re: Power Brake Booster Adapter Bracket
Payment sent for brake booster black powder coat.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 07-27-2018, 10:54 PM   #396
Captainfab
60-66 Nut
Payment received. I will have to check tomorrow and see if I have one in stock. I think I do. If I don't have one I will let you know. Thanks for the repeat business
Old 07-28-2018, 09:06 PM   #397
pdxhall
pdxhall's Avatar
Hey Capt. I will be back home in about 2 weeks and I'm going to be ordering a powder coated bracket. Just some advanced notice.
Sanity'66
Old 07-28-2018, 11:29 PM   #398
Captainfab
60-66 Nut
I'll get a couple powder coated and set one aside for you.
Old 07-30-2018, 12:25 PM   #399
First c10
First c10's Avatar
Hey John,
I have a few questions.
First, What is the reason GM used the longer bracket with the pivot or linkage?
Second, To use your bracket I will need to remove the bolts that go through the brake pedal assembly that go through the fire wall?
Third, How does the direct push rod to the brake pedal affect the braking or the feel when braking?
Thanks Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-30-2018, 04:11 PM   #400
pdxhall
pdxhall's Avatar
thanks, I'll be in touch
Brett
Sanity'66
