Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-22-2011, 04:02 PM   #376
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
and there goes the orange wire..lol. surprised the hole was about the size of a penny.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-22-2011, 04:20 PM   #377
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have just the basics on the drivers side. The fuse panel was relocated to above the trans tunnel and ran to the frame that way..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-22-2011, 05:13 PM   #378
67chevy1series
67chevy1series's Avatar
67s dont have many unnessacery holes.... nice work it should look alot better with a coat of primer
67chevy1series is offline   Reply With Quote
Old 05-22-2011, 07:34 PM   #379
kev2809
low n' slo
kev2809's Avatar
so what are all those little screws coming out of the driver side?
-_--_--_ _________
Old 05-22-2011, 09:57 PM   #380
texastrendz
well, i own a bunch of welders. lol. i used a hobart 230 machine for those i believe. i also own a Lincoln 220 and 110 machine. i would use a 220 machine just for the amperage you will need to penetrate. i know some people say they can get a 110 machine hot enough, i could never get it to do it. a welder is a good investment, and over time it may actually make you money by doing jobs for other people.
texastrendz is offline   Reply With Quote
Old 05-22-2011, 10:07 PM   #381
kev2809
low n' slo
kev2809's Avatar
ya your right. i been wanting to buy a 220 for a while, but its hard to invest in expensive tools because it takes away from my truck for a long time lol.
i thought about turning it into money from other jobs too, but i have a horrible consious (sp?) thats why i dont even want to weld on my own frame...i guess experience would take care of that though..
-_--_--_ _________
Old 05-22-2011, 11:49 PM   #382
67chevy1series
they are for a "jute padding" to sound deadned the cab
Old 05-23-2011, 09:42 AM   #383
kev2809
low n' slo
kev2809's Avatar
so they can just be cut right off on the firewall?
-_--_--_ _________
Old 05-23-2011, 11:10 PM   #384
kev2809
low n' slo
kev2809's Avatar
im thinking also to maybe buy these [IMG]http://*******************/files/imagecache/product/Over_Axle_Lower.jpg[/IMG]from suicide doors and weld 2 pieces of square tubing across the notch and weld a square 3/16" plate across, and mount the top bag to it. the lower bracket is only 30 bucks, and im sure i can rummage around for the tubing and top plate. those kp brackets are nice but they are over 100 bucks shipped!
-_--_--_ _________
Old 05-23-2011, 11:42 PM   #385
charx2
charx2's Avatar
I thought about those too but decided to go with the under axle ones. Im going to order some sleeve bags tomorrow I think and do Some fab work to get it all to work right.
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 05-23-2011, 11:51 PM   #386
67chevy1series
yes no need for those holes unless you want the padding
Old 05-24-2011, 06:07 AM   #387
kev2809
low n' slo
kev2809's Avatar
is there a reason your going to use sleeve bags instead of regular bags? i think you can still use the kp brackets with sleeve bags either way though..
they just might be coming off then lol
-_--_--_ _________
Old 05-24-2011, 09:02 PM   #388
kev2809
low n' slo
kev2809's Avatar
ordered the thorbecke bros axle brackets i posted above. should be here middle or end of next week, so maybe next weekend i can tear into it. im hoping this weekend i can borrow my friends cherry picker and maybe get this motor out of here finally!
-_--_--_ _________
Old 05-24-2011, 09:35 PM   #389
67chevy1series
i figured that!
Old 05-29-2011, 12:09 PM   #390
kev2809
low n' slo
kev2809's Avatar
well i still havent gotten the engine puller yet, so i decided to finish up the rear that i started on a few months ago. and heres how it turned out..
lot better than this...
still needs a little grinding and then filler but happy how it turned out. this was probably the hardest part i had to replace on this whole truck...lot of body curves and a tailgate hinge to make sure it was lined right, lot of relief cuts and splices. you can see its still a little bent in, but the bumper will cover that anyways
-_--_--_ _________
Old 05-30-2011, 01:59 AM   #391
67chevy1series
nice job a skim coat of bondo and your done
Old 05-31-2011, 11:52 PM   #392
maxxxy
maxxxy's Avatar
I've seen you around on the forum, but I've never really looked too much into your build. I just read all 16 pages of your thread, and let me just say that you do some impressive work. Keep it up man.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 06-02-2011, 07:26 PM   #393
kev2809
low n' slo
kev2809's Avatar
haha...sure hope so. i actually cant wait to start the body work...im tired of welding and crap. i get burnt out quick of doing the same thing.
thank you..appreciate you dropping in!
well guys, i got my axle brackets in a few days ago, had the day off so i went at it. cut them damn tubs out, that wasnt fun! im having a few problems trying to get everything lined up...some unusual problems. hope to get this all welded up by this weekend. heres a shot with the trailing arms up against the frame, with the bag mocked up. just a teaser til i get everything welded in, but should be what it will look like.
im really considering a spacer between the ta crossmember and ta's because im not really digging the offcentered wheel...
-_--_--_ _________
Old 06-03-2011, 01:07 AM   #394
67chevy1series
burb looks nice, i wish i had a welder that worked ok
Old 06-04-2011, 01:14 PM   #395
charx2
charx2's Avatar
Sweet! Looks like your making more progress than I am. I just have an idea and the material. No time though. But here is what I will most likely be doing. Something like this just cut to fit obviously and gussets where they need to be.
My 67 c10 Thread.
Old 06-05-2011, 09:49 PM   #396
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Very nice progress!
Hoping to start work on mine in the near future.
Congrats on a very cool project!!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-06-2011, 09:41 AM   #397
kev2809
low n' slo
kev2809's Avatar
that does look tough. could you make a square crossmember that hoops over the axle housing?
Originally Posted by C20-67_N_MO View Post
Very nice progress!
thank you!
well, got everything wrapped up yesterday. it tough trying to weld with a 115 amp welder, i think before i attempt a "Z" im going to get a bigger welder! heres some progress pics from over the weekend..
was tough trying to get a good angle, but you get the idea! i still might add some 1" spacers between the bag...it doesnt get a lot of lift with this setup..it just clears over the top of the tire at full lift.
-_--_--_ _________
Old 06-10-2011, 02:40 AM   #398
67chevy1series
burb looks good! keep it up bud!
Old 06-14-2011, 06:02 PM   #399
1sik7t2
dave
1sik7t2's Avatar
berry nice...about the centered rear wheels,,drove me crazy with mine too we moved mine back and did a triangulated 4 link looks perfect now...mine WAS on the trailing arms too....keep "down" the good work!!!
thank you!
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 06-14-2011, 07:13 PM   #400
kev2809
low n' slo
kev2809's Avatar
lol..ya its hideous!
im thinking of putting these mirrors on...i picked them up from a friend from work. he was going to put them on his 87 el camino, but he just went with no mirrors.
what you guys think?
-_--_--_ _________
