Old 01-21-2011, 09:46 PM   #376
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Originally Posted by (joey) View Post
looks really good.are you going to use the newer rad support or the old one?are your front to back cab supports sitting on top of the newer frame in these pictures?
I am using the old radiator support.
My front cab mounts would be the same as yours and they are sitting on cut down 2001 rubber biscuits - about 2 inches tall, directly on the frame. My burb rear mount are totally different from a regular truck cab.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 01-23-2011, 09:43 PM   #377
drewskiren
drewskiren's Avatar
I got a little bit of work done last night.
First pic is the sharpie mark to drill the frame for the front cab mount. Talk about lining up perfect side to side!
I now have a third frame rail?!?!
The gas tank comes just under the frame rail tops, so I can't do cross bracing like the engineer had done a cad drawing of. Instead I am taking that thought of bed support in the frame plane in a different direction (literally). I have cut off all of the bed supports that are welded to the bed and instead positioning this support in the frame. This one in the center and 5 outriggers coming off both frame sides to catch the inner box walls for their support. If you are lost, give me a week and you will see what I am talking about.
I also welded the spare winch back on 4 inches to the rear, my middle rail holds it up.
This welding is getting better and better.
Drew
Old 01-25-2011, 01:18 AM   #378
drewskiren
drewskiren's Avatar
Today's update.
All the old body mount brackets are cut off.
Welding struts to frame to replace bed cross members. Still have the front to do and the angled support brackets on the longer ones. They are at different heights depending on which factory brace they support. Notice I left the old mounting tab on the frame. It is a good reference point for where the old box mounted/ its level with the rear of the frame. I have been laying my level across these 2 points and clamping the correct scrap bed cross-member to the bottom to find the correct height of each strut.
Started cleaning the frame to paint. Don't think I've ever seen such a shiny frame.
Drew
Old 01-25-2011, 01:19 AM   #379
67chevy1series
67chevy1series's Avatar
wow looks good
67chevy1series is offline   Reply With Quote
Old 01-25-2011, 01:26 AM   #380
mcbassin
Still Learning
mcbassin's Avatar
That frame looks great. I hope your keeping notes on these mods. You know there will be some guys asking for them. Keep it up!
mcbassin is offline   Reply With Quote
Old 01-25-2011, 01:26 AM   #381
VA72C10
VA72C10
VA72C10's Avatar
Nice progress!
Although not as good as when you started the build thread and caught up to where you're at now
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-25-2011, 01:37 AM   #382
sparkydog
sparkydog's Avatar
Great job!!!
Go!...... Go!........Go!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 01-25-2011, 01:42 AM   #383
sparkydog
sparkydog's Avatar
Originally Posted by drewskiren View Post
Thanks, I probably stared at it over an hour last night.
Weirdo
Somewhere right about now (as you settle on your ride height and fore/aft position) you need to sit in the cab and make vroom vroom noises. Maybe talk to yourself a little bit too.
Balls and a Sawzall
Project Halfbreed
Old 01-25-2011, 05:18 AM   #384
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the bed mounting points!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-25-2011, 10:25 AM   #385
67cheby
67cheby
67cheby's Avatar
what ...you dont like GM's wax dip on the frame ??cleaning it all off !!
67cheby is offline   Reply With Quote
Old 01-25-2011, 11:00 AM   #386
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
You do some awesome work! I'll be watching to the end.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 01-25-2011, 11:37 AM   #387
drewskiren
drewskiren's Avatar
Originally Posted by VA72C10 View Post
Nice progress!
Originally Posted by sparkydog View Post
Great job!!!
My goal is to have all the bed and body mounts done, clean the frame for paint where needed, weld on the rear trailing arm suspension, and paint the whole thing by Sunday.
Drew
Old 01-25-2011, 11:40 AM   #388
67cheby
67cheby
67cheby's Avatar
i never understood why Gm didnt paint those frames the wax dip made no sense to me
Old 01-25-2011, 11:59 AM   #389
drewskiren
drewskiren's Avatar
I'll have to say it works quite well here in the south, this thing looks perfect. However I have a few salvage Denalis and the ones from up north are really rusty.
Drew
Old 01-25-2011, 01:18 PM   #390
Dieselwrencher
I was going to say, most of the later GM's around here have super rusty looking frames. Ford is the next rusty, and the dodges seem to have less. The frame must be the only thing dodge coated well.
Good luck with your Sunday goal. I know how it goes. It sounds simple, but there is always something to get you in a bind and slow down the progress.
Ryan
Old 01-26-2011, 01:18 AM   #391
drewskiren
drewskiren's Avatar
A quick thought on body mounts: I have seen some discussion about using the new truck floor pan and thus being able to leave the frame mounts. What a complete pain in the rear. It was so easy to cut off the mounts on the new frame and make 4 new ones, I'll have about 2 feet of total welding to attach them, and it's so easy to weld thick material. The alternative solution of using the new truck cab floor involves so much work: cutting both floors out, figuring out how to mate them back together (they don't exactly line up!), making sheet metal filler parts to cover the gaps where they don't meet, over 28 feet of welding - sheet metal!, making sure all of your welds are complete and water tight, seam sealing the 28 feet of welds because you know they aren't water tight, and on and on. A COMPLETE AND UTTER NIGHTMARE with no real benefits.
Front body mount hole - done
Mid and rear body mounts - cut, ready to weld
Remaining bed mounts and braces - all cut and ready to weld
Underside of bed sectioned and channeled
Still have to: Finish grinding down old mounts, build rad. support mounts, weld rest of brackets on, prep for paint, build carrier bearing mount. No problem!
Drew
Old 01-26-2011, 01:25 AM   #392
VA72C10
VA72C10
VA72C10's Avatar
Nice progress! Keep at it! Living vicariously until I get my next project underway....just cleaning and selling parts right now
Old 01-26-2011, 01:31 AM   #393
thelonerife
thelonerife's Avatar
Nice work Drew. Can't wait to see the cab and bed on the frame. So get the girls to help
thelonerife is offline   Reply With Quote
Old 01-26-2011, 07:53 PM   #394
(joey)
(joey)'s Avatar
lookin good.great idea for the rear box mounts.as for the wax on the newer frames working,im from canada eh and im going to be ashamed to get pics of mine after seeing yours.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 01-27-2011, 01:24 AM   #395
drewskiren
drewskiren's Avatar
Call me a slacker if you want, I got 2 mounts welded and then ran out of wire.
Spent the rest of the time figuring out how Frankie is going to look with TWENTIES !!!!
Drew
Old 01-27-2011, 01:46 AM   #396
Slick67
Sofa King Crazy!!
Slick67's Avatar
Niiicceee. I love this thread, it makes me feel like a new catalog came in the mail.......you know the feelin. Nice work on the frame!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 01-27-2011, 02:35 AM   #397
VA72C10
VA72C10
VA72C10's Avatar
Nice MacGyvering with the rims Gonna look sweet!
Old 01-27-2011, 02:53 AM   #398
Pop's C-10
Pop's C-10's Avatar
i love thoese wheels
Pop's C-10 is offline   Reply With Quote
Old 01-27-2011, 03:01 AM   #399
Dieselwrencher
Very nice! You are making great progress!
Ryan
Old 01-27-2011, 10:12 AM   #400
67cheby
67cheby
67cheby's Avatar
my favorite factory wheels ....bar none!! i think they look good on everything
