#376 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Lost My 65
Let us know what you think of them.
#377 |
Re: Lost My 65
Just spent the better part of an hour here at work reading this thread. Awesome job finding your truck. Loved the whole google earth photos. Thats some good hunting. Looks like you are getting some work done to it. Keep it up and Congrats. Now off to read your service truck thread.
#378 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Lost My 65
Took the smaller Shrinking Disc to an area on my hood that had a small dent and some 'Oil-Canning'.
It worked fantastic. ![]() Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#379 | |
Re: Lost My 65
It is great having having it back. I tinker on it when I can. Posted via Mobile Device
#380 |
![]() Join Date: Sep 2011
Re: Lost My 65
I admire your willingness to undertake body work. I have zero confidence in that area. I have a buddy that's great at it, but I'm like number 12 in line to get his assistance.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#381 |
Re: Lost My 65
Great story look forward to seeing you bring it back to your own.
#382 |
Re: Lost My 65
cool truck story,I bought the truck my Grandfather gave me 14 years later after I sold it so it is cool to see your progress
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
#383 |
Re: Lost My 65
Glad to see this still Movin!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#384 |
Re: Lost My 65
Shrinking with friction discs is great! I do a lot of metal shaping and sheet metal repair at work and I use the big disc a bit. The little one is great if you know exactly where you need to shrink already, the big one will help you find the spots. Have you made or bought a good slapper? I find I grab mine more than any other hand tool when working out dents.
#385 | |
Re: Lost My 65
I do have a leaf spring I can make one out of. I plan on attacking the body panels this winter. I'm anxious. to get started. Right now I'm working on getting some concrete down in my pole barn. Posted via Mobile Device
#386 |
Senior Enthusiast
Re: Lost My 65
The patch repairs looks fantastic! There are so many things that can be achieved if a person has welding skills. Looking forward to more updates.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#387 | |
Re: Lost My 65
Good luck with the barn and the sheetmetal! |
#388 |
Re: Lost My 65
I have finally settled on a method I'm happy with for repairing the body panels.
Until I retire, (longways down the road) I won't be doing a frame off restore. Also, I don't want too much tore down for too long. I want to keep it a driving restoration. Also, i dont like different panels different colors. Also, I didn't want a primer gray, red or black truck. I like blue. Captn' suggested blue primer, but I read that primer doesn't protect metal. Later I realized he might have meant epoxy primer. My truck is parked inside, so fading is no immediate concern. Now, the next criteria for my attempt to tackle these repairs is equipment - I don't have the spray equipment - and even if i did, I don't feel comfortable spraying toxins (poison) in my garage. Even if I dress up in a full bunny suit, where do I ventilate these toxins? Also, I'll be doing a small repair, then moving onto another small repair. I dont feel like setting up everything for every small repair, and then cleaning everything up. The solution; roll-on epoxy primer. In my research, I found that the really fine foam rollers do a nice job. Now, I do realize that rolled on primer on my truck will still look like primer on a truck, but I like the look of trucks in primer. http://67-72chevytrucks.com/vboard/s...84#post5077484 Also, getting the repair areas to blend with the overall truck would be a challenge. But about a month ago I remembered a look that I really like for a driving restoration. MisterC's 66: ![]() So, I now I have a method/direction/procedure that I'm happy with. This way as I repair an area it's done correctly for when I decide to do a frame off restore and give it a paint job with quality paint. . I had a local paint store mix up some enamel the same color as the blue epoxy. The bottom right is the epoxy. - good match: ![]() Here is my first attempt to emulate MisterC's truck: (I really like how it's turning out.) ![]() ![]() ![]() ![]() Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 09-15-2013 at 10:50 PM. |
#389 |
Re: Lost My 65
Looks nice! Keep up the great work, bud. I almost feel bad for starting to sand mine now. I needed to get down to the white parts underneath so that I could see if I wanted to go with the two tone.
#390 |
Re: Lost My 65
You know, that's kinda neat. Almost like built in patina. And well protected. Nice work!
#391 | |
Re: Lost My 65
Thanks guys.
Yeah, MjsterC's is blue primer with a black guide coat. I'm just faking it for now. ![]() Posted via Mobile Device
#392 | |
Re: Lost My 65
Another huge reason for the direction I'm going with the paint and body is when I first decided on getting a classic to tinker on, I settled on a truck for the practicality of it.
I want to be able to use it as a truck. This last Wednesday was the perfect example. I went to pick up a big steel gate. It didnt quite fit in the bed. It caused some pretty good scratches. No big thing. Just hit it with some sandpaper, and touch it up. I own a truck. ![]() . Here is a post Mark made quite some time back that stuck with me and convinced me of the direction I wanted to take for the body and paint: Quote:
#393 |
![]() Join Date: Jan 2011
Re: Lost My 65
Looks great! Reminds me of the flat denim blue that was all the rage on Harleys a couple years ago.
I do love a blue stepside..... |
#394 | |
Re: Lost My 65
I hadn't heard of denim blue as a paint color. I googled it and found these: (I like it) ![]() ![]() ![]() Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 09-25-2013 at 10:36 PM. |
#395 |
Re: Lost My 65
One of my riding buddies has a Fat Bob that's denim blue, looks good but it really shows fingerprints and stuff.
#396 |
Re: Lost My 65
Winter Goal
I've decided to go with an Automatic Tranny. Driving around this summer in the curvy hilly stop-and-go Portland OR area was the clincher. I'm tired of shifting up and down and up and down. So this winter I'll be putting in an Auto. My 65 is on a 62 Frame, so this will go a little different than those who have the 63-66 frame. I'm currently rounding up the parts needed to go from my sm420 to the th350. I acquired a nice original 3-speed auto column sometime back. I'm sure glad the offers I got for it were lower than I knew it was worth, otherwise I might not of held on to it. I'm looking forward to this upgrade. Here are some pics of the column: ![]() ![]() ![]()
#397 |
The 60-66 GMC/Pontiac guy....
Re: Lost My 65
I am building a 62. Using a 350/700R4. Modified a Camaro trans x-member to hold the trans.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#398 | |
Re: Lost My 65
How bout some pic's of the '62, Chris...?
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#399 |
Re: Lost My 65
I have the chassis almost done.
Static coil drop. (no more torsion suspension) ![]() Disk front and rear and epoxy coat chassis paint. ![]() It's a ground up build... ![]() Nothing is done on the cab, bed or front clip... ![]()
#400 | |
Re: Lost My 65
I'm going to need the same thing beings I need to get past the heater box in the engine compartment. Do you remember which one you have? Do you know if the th350 will accept the same one?
