Old 04-27-2013, 06:10 PM   #376
mrivera28
Re: How about some pics of Static dropped 60-66
Forest, that's a photoshopped pic. I know I won't be sitting that low but just got everything ordered from Sid so I'm excited. She should be done in about a month.
Apologies for posting on here, just realized it wasn't for 59's but it's a great forum!
MR
mrivera28 is offline   Reply With Quote
Old 05-01-2013, 03:31 PM   #377
J.Cagle
J.Cagle's Avatar
Anyone have a pic of a 2-3 drop? Got a set of 3" rear springs coming, and thinking about ordering some 2" for the front.
1964 c-10 Long stepside, 230 I6 ,3spd, dealer add-on air.
J.Cagle is offline   Reply With Quote
Old 05-07-2013, 12:40 PM   #378
glos55
glos55's Avatar
Originally Posted by J.Cagle View Post
I've got a stock set of front springs and a set of jeep tj springs for the rear. How many coils do I need to cut off the stock fronts to make my truck sit level with jeep springs in the rear?
The TJ Jeep rear springs brought mine down a full 4" in the rear and I cut 2 coils off of stock fronts
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
Old 05-12-2013, 03:52 PM   #379
TxRat
TxRat's Avatar
4-6 drop
TxRat is offline   Reply With Quote
Old 05-12-2013, 10:34 PM   #380
Fastest32
Fastest32's Avatar
I cut 1 1/2 off of the front of mine with the tj springs in the rear. it still has a little rake but I had to cut the bump stops off the front or they would hit. The front still has good suspension but the back has almost none. I can't put anything in the back without it bottoming out. My bike makes the truck totally bottom out and that was one of the main reasons I lowered it. I have some load leveling bags that I plan to install but I'd "splurge" and buy the real lowering springs for the rear if I had it to do over again.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 05-13-2013, 05:46 AM   #381
mark 66
trucks looking good txrat.
mark 66 is offline   Reply With Quote
Old 05-17-2013, 09:20 AM   #382
jmack91z28
jmack91z28's Avatar
I really like your interior, is that a tilt column or do you have to bend your head down to see the tach? It's almost like you could glance at the speedometer and co-witness the tach at the same time, I like it.
You should get some gauges that match the tach to replace the dummy lights, that would be perfect, plus it'd get rid of the add on gauges below the radio and clean everything up.
Love the stance of your truck too.
1961 C60 Viking 8' Dump 261 SM420 2-Speed Rear
1966 C10 Fleetside 350 W/ Saginaw 4 speed
1985 K10 Chevy 6.2 diesel 700r4 longbed
2001 Dodge 3500 Dually 24v NV5600 4x4
USMC Reserves
Jason
jmack91z28 is offline   Reply With Quote
Old 05-18-2013, 07:41 PM   #383
steve'62
steve'62's Avatar
Cpp notch in, disc brakes done, 3 in drop spring front, 2 1/2 drop spindle, 5 in rear drop spring, 2 in block, 235/75/15
steve'62 is offline   Reply With Quote
Old 05-18-2013, 07:42 PM   #384
steve'62
steve'62's Avatar
Old 05-20-2013, 06:26 PM   #385
stealth_weapons
thanks for the comments. it is the factory non tilt steering column. i have no issues seeing the tach sitting normal (i am 6'0"). i am saving for the Fastlane west dash to eliminate the under dash gauges the PO installed. as for the stance i am debating on bags or staying static.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome!
http://67-72chevytrucks.com/vboard/s...d.php?t=438235
stealth_weapons is offline   Reply With Quote
Old 05-26-2013, 03:54 PM   #386
Sin Cal 66
Sin Cal 66's Avatar
Sin Cal 66 is offline   Reply With Quote
Old 05-26-2013, 05:17 PM   #387
likaroc13
Rollin' Old Skool
looks nice!
Also, nice truck Sin Cal 66!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 05-27-2013, 09:29 PM   #388
Sin Cal 66
Sin Cal 66's Avatar
Thanks!
Old 05-28-2013, 06:49 AM   #389
mark 66
Originally Posted by Sin Cal 66 View Post
Thanks!
what are the drop stats, and what size tires and rims. nice stance.
Old 05-29-2013, 11:43 PM   #390
Sin Cal 66
Sin Cal 66's Avatar
McGaughys 4.5x6 lowering kit. Stock wheels and tires.
Old 05-30-2013, 01:59 AM   #391
WCHLVR
WCHLVR's Avatar
4-3 Drop. Cut Coils all the way around.
WCHLVR is offline   Reply With Quote
Old 06-03-2013, 12:03 PM   #392
robber grin
I hate to bug you but I have to ask what you think about the rear tank conversion - given you are on the road with a similar drop to what I've got on my truck ( 5 1/2 front - 6 rear).
I just finished mocking it up on my 62 C10 and would like to know more before I proceed with eliminating tank in cab.
9 1/2 inches to the ground with body off seems close - likely clearance issues for actual drivability.
Thank you - rg
robber grin is offline   Reply With Quote
Old 06-05-2013, 12:24 PM   #393
jcramsey
jcramsey's Avatar
First pic is where I started on Saturday, and second pic is where I ended up.
1st one is all spring 3/5 drop.
2nd one is with 5/5 drop with 2" spindles added up front.
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 06-05-2013, 10:10 PM   #394
moon77
61 apache 10
moon77 is offline   Reply With Quote
Old 06-05-2013, 10:11 PM   #395
j3564wost
Just got the bed back on to see the actual stance with the drop. 3/5 cpp coils.
1964 C20 Custom
3"/5" cpp coil drop
SS 396 TH400
j3564wost is offline   Reply With Quote
Old 06-06-2013, 02:29 PM   #396
gotsand30
[attach]Name:  IMG_20130426_203929_231.jpg
Size:  27.8 KB[/attach]
gotsand30 is offline   Reply With Quote
Old 06-12-2013, 04:47 AM   #397
offlimts502
offlimts502's Avatar
Love your truck. Nice and clean. What I'm looking to buy.
offlimts502 is offline   Reply With Quote
Old 06-15-2013, 12:18 AM   #398
Chase-1966 Chevy
Chase-1966 Chevy's Avatar
Hey guys new to the board and trying to post some pics any advice? thanks
Chase-1966 Chevy is offline   Reply With Quote
Old 06-15-2013, 12:29 AM   #399
Chase-1966 Chevy
trying to post more pics...whats a token?
Old 07-09-2013, 10:08 PM   #400
19666Trucker
19666Trucker's Avatar
Posted via Mobile Device2" blocks in the back, and 1.5 cut coils in the front.
19666Trucker is offline   Reply With Quote
